Finding vertices C and D of a square with A(1,2) and B(2,4)
2 replies · 3K views
Julian102
If two vertex of a square of the side AB is A(1,2) and B(2,4) find other two vertex C and D?
1. y-y1 = m ( x-x1)
2. m=y1-y2 / x1-x2
3. m1*m2= -1
4. (x-x1) / (x1-x2) =(y-y1)/(y1-y2)
5. m=tanA
6. If ax+by+c=0 then its parallel line is ax+by+k=0
Equation of AB is can be found using formula 4 , then slope is found using formula 2 . Then slope of perpendicular is -1/m (formula 3) . Now perpendicular AD and BC can be found using formula 1 . Now CD is parallel to AB . I need to find CD ...The distance between AB and CD is root 5 (of course since distance between AB is root 5 and it is a square) ...Please tell me how to find the side CD ...and diagonals AC and BD ...
1. y-y1 = m ( x-x1)
2. m=y1-y2 / x1-x2
3. m1*m2= -1
5. m=tanA
Compute the equation of the line AB.
You can then easily write down the equations of the lines AD and BC (you gave the correct rules).
Then you can locate C and D (two possible solutions) on these lines using the distance.
Said differently: don't use words to describe a possible solution, just compute what you said.
Alternatively, if you have studied vectors you don't need to deal with equations of straight lines and their slopes. Start with ##\vec{AB} = \langle 1,2\rangle##. Can you write down a perpendicular vector of the same length? That would get you started.
