Finite Element Method: Find Total Mass Matrix of Coupled Element
To find the total mass matrix of two coupled flexible links connected by a revolute joint using the Finite Element Method, it is essential to define the mass matrices for each link. The mass matrix for link 1 (M1) and link 2 (M2) are provided, detailing their respective states, including joint angles and flexural displacements. A recommended resource is an article that specifically addresses this topic, which can be found through a simple Google search. Understanding the relationship between the elements and their states is crucial for accurately computing the total mass matrix. This approach will facilitate the analysis of the coupled flexible manipulator system.
S K
Does anyone know how to find the total mass matrix of two coupled element by using Finite Element Method?
You haven't been specific enough in your question. What kind of elements, and for what purpose?
Actually I am trying to find the total mass matrix of flexible two link which are coupled by revolute joint. The figure of two flexible links can be found in the following website.
https://www.google.com.au/search?q=...UICSgC&biw=1680&bih=930#imgrc=osAePmWFf2unEM:The mass matrix of link 1 is given by
M1=[m11 m12 m13 m14 m15 ;
m21 m22 m23 m24 m25 ;
m31 m32 m33 m34 m35 ;
m41 m33 m34 m44 m45 ;
m51 m52 m53 m54 m55 ];
theta1, w1, alpha1, w2, alpha2 are the states where theta1 is joint angle of link 1 w is flexural displacement and alpha is flexural slopeSimilarly, the mass matrix for link 2 is given by
M2=[M11 M12 M13 M14 M15 M16 M17 M18 ;
M21 M22 M23 M24 M25 M26 M27 M28 ;
M31 M32 M33 M34 M35 M36 M37 M38 ;
M41 M33 M34 M44 M45 M46 M47 M48 ;
M51 M52 M53 M54 M55 M56 M57 M58 ;
M61 M62 M63 M64 M65 M66 M67 M68 ;
M71 M72 M73 M74 M75 M76 M77 M78 ;
M81 M82 M83 M84 M85 M86 M87 M88 ]
Theta1, w2, alpha2, theta2, u2, phi2, u3, phi3 are the states for link 2.
So, anyone knows how to find the total mass matrix of the system?
I recommend taking a look at this article, it looks like it covers exactly what you want (and only required a simple Google search): http://www.colorado.edu/engineering/CAS/courses.d/MFEMD.d/MFEMD.Ch16.d/MFEMD.Ch16.pdf
Thank you very much
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 0 ·
