From de Broglie's postulates to Shrödinger's equation
  • Level: Undergrad
  • Thread starter quasar987
    Postulates
Homework Helper
TL;DR
Trying to make sense of a vague comment by Susskind
So I was watching one of Susskind's lecture on Youtube* and about the 37:00 mark he has this equation relating the frequency of a matter wave to its wavelength:
$$\nu = \frac{h}{2m\lambda^2}.$$
This is arrived at by assuming that matter has a wavelike nature and that the energy and momentum formula for the photon ([itex]E=h\nu[/itex] and [itex]p=h/\lambda[/itex]) still hold true for the matter wave. Then Susskind said that this is essentially just Shr¨ödinger's equation, or at least that Schrödinger was looking for an equation which would result in this relation between [itex]\nu[/itex] and [itex]\lambda[/itex]. But if I set [itex]\psi(x,t) = e^{i(x-vt)}[/itex] and use [itex]v=\lambda\nu[/itex], then feeding [itex]\psi[/itex] into Shrödinger's equation
$$\frac{1}{2m}\frac{\partial^2}{\partial x^2}\psi = -\frac{i}{h}\frac{\partial}{\partial t}\psi,$$
I find instead
$$\nu = \frac{h}{2m\lambda}.$$
What am I missing??
The Schrödinger equation for a free particle will read (I think you have dropped a factor of ##2\pi##)$$i\hbar \frac{\partial \psi}{\partial t} = -\frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial x^2}$$Then if you let ##\psi(x,t) = Ae^{i(kx-\omega t)}##, you have ##\frac{\partial \psi}{\partial t} = - i \omega \psi## and ##\frac{\partial^2 \psi}{\partial x^2} = -k^2 \psi##. If you plug those results in, and use that ##\hbar k = p##, you will notice that$$\hbar \omega = \frac{\hbar^2 k^2}{2m} \implies h\nu = \frac{p^2}{2m}$$Now the velocity of a particle is identified as the group velocity, ##v_g = \frac{\partial \omega}{\partial k}##, which is twice the phase velocity, ##v_p = \frac{\omega}{k}##, i.e. ##v_g = 2v_p = 2\nu \lambda##, which means that$$h\nu = \frac{(mv_g)^2}{2m} = \frac{4\nu^2 \lambda^2 m^2}{2m} = 2\nu^2 \lambda^2 m$$ $$\nu = \frac{h}{2m \lambda^2}$$which is the equation in the video.
etotheipi, thanks for your answer! You made me realize that I made two mistakes. The first was to start from [itex]\psi(x,t) = e^{i(x-vt)}[/itex] and not realizing this implies [itex]\lambda=2\pi[/itex] and the other was to forget a factor of [itex]2\pi[/itex] in the SE. These mistakes "cancel out" in a sense because the computations with the correct factor of [itex]2\pi[/itex] lead to $$v = \frac{h/2\pi}{2m\lambda}$$ but since [itex]2\pi = \lambda[/itex] we get the desired form $$\nu = \frac{h}{2m\lambda^2}.$$ Or, in other words, if we (correctly) start from the more general expression[itex]\psi(x,t) = \exp\left[i\frac{2\pi}{\lambda}(x-vt)\right][/itex] then the SE implies $$v=\frac{2\pi\hbar}{2m \lambda}=\frac{h}{2m \lambda}$$ and finally the fundamental relation [itex]v=\lambda\nu[/itex] gives the desired result.
But you also make the observation that if we trust that [itex]p=h/\lambda[/itex] holds for massive particles as it does for photons, then we get $$v=\frac{p}{2m}=\frac{v_{particle}}{2}.$$ I.e. the velocity of the plane wave "attached" to the particle is half that of the particle itself!
This is the phase velocity. If you take the group velocity, you'll get ##v=p/m##, as expected. That makes some sense, because the velocity of the particle is rather the velocity of the center of the wave packet rather than the phase velocity.
