Functional gages cannot be used to inspect features specified at LMC.
  • Thread starter Thread starter dav2008
    Functional
Functional gages are not suitable for inspecting features specified at Least Material Condition (LMC) because they are designed to reject parts that are borderline Maximum Material Condition (MMC). The concept of bonus tolerance is introduced, where the tolerance increases as the feature size moves from LMC to MMC, allowing for greater flexibility in part dimensions. Functional gages do not measure sizes but instead check for interference, meaning if a part fits through the gage, it is not rejected. An example illustrates this with a gage pin used to test if a shaft fits through a hole, emphasizing that the gage only rejects parts that exceed allowable tolerances. Understanding the role of functional gages is crucial for proper application in mechanical design.
dav2008
"Functional gages cannot be used to inspect features specified at LMC."
What does that statement mean?
I am going through "GD&T for Mechanical Design" by Cogorno (McGraw-Hill) and it makes that statement on page 24.
As the size of the feature departs from LMC toward MMC, a bonus tolerance
is gained in the exact amount of such departure. Bonus tolerance
is the difference between the actual feature size and the LMC of the feature.
The bonus tolerance is added to the geometric tolerance specified in
the feature control frame. LMC is used to maintain a minimum distance
between features. The LMC is seldom used. Functional gages cannot be
Functional gages aren't meant to take measurements. They're only intended to reject parts that are borderline MMC. If there is any interference between the functional gage and the part, the part is rejected.
An example would be using a gage pin to see if a shaft will fit through a hole. The size of the gage pin corresponds to the maximum diameter allowed for the shaft. If the hole is anywhere below MMC, and therefore larger than its smallest allowable size, the gage pin would not interfere with the hole. If the hole is larger than your allowable tolerance, the gage would not reject it.
I would be surprised if there isn't a chapter on gages in that book somewhere that could probably explain it a little better.
Ah ok thanks. I glossed over the word "functional", and the book does explain a bit more about them later on. I guess I should have figured out what a functional gage is before asking about it ;)
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 19 ·
