Fuzzball proposal talk by my advisor at CERN
  • Context: Graduate
  • Thread starter Thread starter Ben Niehoff
20 replies · 6K views
This is ths stuff I do. My advisor recently gave a talk at CERN:
http://cds.cern.ch/record/1537034?ln=en
I don't usually post in this forum, but someone else expressed interest in firewalls, and this is somewhat connected. I thought maybe some people might be interested.
Are any of your papers on the arxiv about fuzzballs?
All of them are related to fuzzballs in some way, yes. A few of them are examples of fuzzballs.
It's an interesting talk - mainly I didn't know who else worked on fuzzballs apart from Mathur, and Warner says at the start there's not a monolithic "fuzzball people" group. It was a bit hard to read the blackboard on my screen, so I tried looking for a review by Warner. http://arxiv.org/abs/0810.2596 seems similar in spirit.
"In particular, a Microstate Geometry is defined to be any completely smooth, horizonless solution that matches the boundary conditions of a given black hole. One of the surprises of the last three years has been that there are a vast number of such geometries and a very rich underlying structure that matches very nicely with the dual holographic field theory description. It remains to be seen if these can provide a semi-classical accounting of the entropy but, as I will discuss, there is a reasonable chance that they might."
I'd say the canonical review is this one: http://arxiv.org/abs/hep-th/0701216
Although, things have progressed a bit since then. As he mentions in the talk, what we're especially interested in now are smooth, horizonless solutions in 6 dimensions that depend on arbitrary functions of 2 variables. We've actually got solutions that depend on arbitrary functions of 2 variables (http://arxiv.org/abs/1203.1348), but these ones are singular. The "smooth" requirement results in a very tricky nonlinear equation that has thus far defied solution.
Ben, I would actually like to ask some questions about this research direction if you have the time.
Is it correct that the basic idea is to look for geometries which, when counted appropriately, give the entropy of a black hole? If so, how do we know that the microstates have a geometric interpretation? Also, presumably such geometric microstates would be somehow related to the notion of eigenstate thermalization; can one, in a holographic context for example, compute the entanglement entropy of the microstate using something like the Ryu-Takayanagi formula and see that one recovers thermal scaling for small subsystems?
One can show, actually, that in the phase space of black hole microstates, the ones with a geometric interpretation are a set of measure zero. The rest are complicated string theory states. However, the hope is that the geometric ones are still a dense set, and thus are an appropriate sample of the phase space. This would lead at least to the correct scaling behavior for the entropy in terms of black hole charges.
In fact, we have yet to produce the correct scaling behavior. The next hope is that the "superstrata" microstates (that depend on arbitrary functions of 2 variables) will have enough entropy to give the correct scaling.
Furthermore, all of this so far is done only for extremal black holes (and usually supersymmetric also). Getting a non-extremal microstate geometry is very hard (and may be impossible).
These are things I don't know about. I can say that no has yet found any microstate geometries that are easy to study holographically. No one has been able to find a microstate geometry asymptotic to AdS_5, for example (because the equations are horribly nonlinear).
Oh I see, how interesting. It seems like it would be really fantastic to have a microstate geometry with the right asymptotics and then to see that the holographic EE gave thermal entropy. Can the nonlinear equations be solved numerically?
I've actually done a bit of work to try to get microstates in AdS_5. The equations of motion can be reduced to a coupled system of 6th-order nonlinear PDEs in 3 independent variables. So it is not amenable to numerical solution. :p
Ben, are your answers for Physics Monkey's questions only for the three-charge system, or also for the two-charge system?
All my work has been in 3-charge systems. I don't know much about 2-charge systems, but I think the correct entropy scaling has been obtained in that case, using supertubes (which allow arbitrary functions of 1 variable).
Maybe you've already answered this, but I wasn't clear if your comments covered the two charge case as well. Is there an asymptotic AdS solution in the 2 charge case? If so, has anything about the entanglement entropy been considered?
There are no asymptotically-AdS_5 solutions at all.
However, in both the 2-charge and 3-charge case, you can get asymptotically AdS_3 x S^2. I'm not sure what holographic studies have been done on such systems, but I assume it's been done.
You can also get other near-horizon metrics with less symmetry; for example, in one of my papers we have asymptotically-near-horizon-BPMV, with rotation parameters strictly bounded above zero.
It looks like the AdS_3 case has been pretty extensively studied by Skenderis and Taylor. They have a number of papers on fuzzballs from a holographic perspective.
I found several papers by Skenderis and Taylor, but they seem to make no mention of entanglement. I found checks of one point functions, for example, but given that one seems to have explicit solutions it might be very interesting to look at the entanglement. I guess unfortunately I don't have too much sense for what these solutions "look like".
I'm not sure who's the joker. I have also met Bena, they both have a sense of humor. They both have plenty of papers with serious titles. But Warner is responsible for "Hair in the back of the throat" in my first paper.
I've noticed actually most people are jokers, occasionally, especially if a topic has just caught on. Look at Joe Polchinski and Clifford Johnson, for example. Joe has some old TASI lectures that mention in the introduction "There will be no puns".
Maybe http://arxiv.org/abs/1108.2510 ? They mention the eigenstate thermalization hypothesis, and try to follow up Takayanagi and Ugajin's speculative paper, but with the D1-D5 system instead. (They are mentioned in Hartman & Maldacena's tensor network paper.)
:smile:
Ben mentioned that all the solutions so far are for extremal black holes. Would "thermalization" work with extremal black holes, which are at T=0? In their paper on thermalization in the D1-D5 system, Asplund and Avery presume that the process is dual to forming a non-extremal black hole. I suppose that for extremal black holes one would do something more like your http://arxiv.org/abs/0908.1737, with the Ryu-Takayanagi formula still expected to hold?
BTW, hope you aren't affected by the terrible events in Boston.
This is a good point. Perhaps my hope is somewhat misguided, although I do still wonder what the entanglement looks like.
Fortunately, despite many friends running in the marathon, no one I knew was hurt. The explosions were just steps from the church where my wife often sings, so we got very lucky. All the crimes in cambridge last night took place very near where we live, so it's all rather disturbing and crazy.
