Geometric progression sum with constraint nh = 1
  • Thread starter Thread starter Maatttt0
    Geometric
5 replies · 2K views
Maatttt0
This isn't the whole question, I understand the prior parts but somehow stuck on the "easy" part :( Need to solve a geometric progession problem.. find the sum of:
h(1 + 3^h + 3^2h + ... + 3^(n-1)h)
Where nh = 1
The sum should equal to (2h)/((3^h) -1) which is given as is a prove question
N/A
h(1 + 3^h + 3^2h + ... + 3^(n-1)h) --- this is the list
(h(1-(3^h)^(n-1)))/(1-3^h) --- using the formula Sn = a(1-r^n)/(1-r)
simplify slightly (using nh = 1)
= (h(1-3^(1-h)))/(1-3^h)
times top and bottom by -1 to match the denominator of answer
= (h(3^(1-h) - 1))/((3^h) -1)
and now I can't seem to get the final answer out.
Hopefully I've included enough info for you guys to understand what I'm going on about lol - and apologise for the excess of brackets :S
Thank you in advance :D
Hi Maatttt0! :smile:
Where nh = 1
N/A
That is not the correct formula, is it? Isn't the correct formula
[tex]S_n=a\frac{1-r^{n+1}}{1-r}[/tex]
so with an n+1 instead of an n...
Advice: don't memorize any geometric series formula. Instead, try this:
If you have a geometric progression in r, i.e. S = a + ar + ar2 + ar3 + ... + arn, compute S - rS = S(1 - r) and then re-arrange. This leads you exactly to the formula micromass posted, but it really helps you see what's going on. I prefer to memorize a technique than a formula.
For your problem, you should start by re-writing S = h(1 + 3h + 32h + 33h + ... + 3(n-1)h) as S/h = 1 + 3h + 32h + ... + 3(n-1)h. Noting that this is a geometric progression in 3h, multiply both sides by 3h. Then, compute the difference (S/h) - (S/h)3h. Can you go from there?
Hey guys,
Thank you for both of the replies :)
micromass; I'm didn't think it was n+1 :S my formula booklet just has n by itself.
Unit; I got the answer to come out I think xD
3[itex]^{h}[/itex] * [itex]\frac{S}{h}[/itex] = 3[itex]^{h}[/itex] + 3[itex]^{2h}[/itex] + ... + 3[itex]^{nh}[/itex]
3[itex]^{h}[/itex] * [itex]\frac{S}{h}[/itex] = (3[itex]^{h}[/itex](1-3[itex]^{1}[/itex])) / (1-3[itex]^{h}[/itex])
S = -2h / (1-3[itex]^{h}[/itex]) then just times top and bottom by -1.
Is this what you were suggesting? Hinting to divide through by h and times through by 3^h was useful.
Yes, that's exactly it! Well done :)
Aha yay! Thank you Unit - muchly appreciated :D
