Getting a solution from a system of PDEs
  • Thread starter Thread starter CrosisBH
    Pdes System
5 replies · 2K views · last reply
CrosisBH
From Griffith's E&M 1.50b
Show that [tex]\vec{F}_3=yz\hat{x}+zx\hat{y}+xy\hat{z}[/tex] can be written both as the gradient of a scalar and as the curl of a vector. Find scalar and vector potentials for this function.
None specifically (I think), all I need is the definition of the gradient of a scalar function, and the curl of a vector function.
I want to start off here saying I took the problem has finding a potential function, and not a general solution, so I worked to only find one function that works.
I already confirmed that this function can be written as a curl of a vector function and the gradient of a scalar function.
Since it can:
[tex]\vec{F}_3 = \nabla v[/tex]
and so
[tex]yz = \frac{\partial v}{\partial x}[/tex]
[tex]zx = \frac{\partial v}{\partial y}[/tex]
[tex]xy = \frac{\partial v}{\partial z}[/tex]
Here's where the physicist rigor comes in. I only took the first function and integrated it with respect with x (treating the partial derivative as a normal derivative) and got that v = xyz + C(y,z), and I just set the constant = 0 and got a solution of v = xyz.
The second part is what's tripping me. Where I have to write this as a curl of a vector function.
[tex]\vec{F}_3 = \nabla \times \vec{C}[/tex]
I expanded the right hand side out to vector components and got this system:
[tex]yz = \frac{\partial C_z}{\partial y} - \frac{\partial C_y}{\partial z}[/tex]
[tex]xz = \frac{\partial C_x}{\partial z} - \frac{\partial C_z}{\partial x}[/tex]
[tex]xy = \frac{\partial C_y}{\partial x} - \frac{\partial C_x}{\partial y}[/tex]
I have no idea how to force a solution out of this, and I don't have the mathematical knowledge to solve this system of PDEs for a general solution. I'm kinda stuck. Any help is appreciated.
The first part is fine, but you cannot do the second part without additional argumentation, i.e., inserting your v into the remaining differential equations and finding out that the partial derivatives of C(x,y) are both zero, actually making C a constant. It is otherwise somewhat confusing to call a function (which C(x.y) is) a constant.
For your remaining question, note that the vector potential is not going to be unique so you are going to need additional constraints in order to find it unambiguously. A common approach is to introduce an additional constraint, for example ##C_z = 0##, try it out and see where it gets you.
I did your suggestion, and worked out the system and got a vector of [itex]\vec{C} = \left(\frac{1}{2}xz^2 - \frac{1}{2}xy^2\right)\hat{x} - \frac{1}{2} yz^2 \hat{y}[/itex] as a potential function and worked it out and the curl of the function is the original function. So for these types of problems that demand a solution but not a specific one, I can keep imposing reasonable constrants until a solution pops up? (By the way, thanks a bunch)
If by ”reasonable” you mean that they are not so stringent that they rule out all solutions. Otherwise there is nothing ”physically reasonable” in a particular choice of constraint other than that it might make it easier to find a solution.
Dr Transport said:
For a vector [itex]\vec{B} = \vec{\nabla} \times \vec{A}[/itex], isn't the solution [itex]\vec{A} = \frac{1}{2} \vec{B} \times \vec{r}[/itex]?
No, this is true if ##\vec B## is constant, which is not the case here. Furthermore the solution is not unique neither for the scalar nor for the vector potential.
