Good ole hemispherical dome differentials problem
  • Thread starter Thread starter mlschiff
    Differentials
5 replies · 11K views
mlschiff
Use differentials to estimate the amount of paint needed to apply a coat of paint 0.03 cm thick to a hemispherical dome with diameter 54 m. (Round the answer to two decimal places.)
V = 1/2(4/3(pi*r^3)) = 1/2(4/3(pi*(1/2D)^3)) = 1/2(4/3*pi(1/8D^3)) = 1/12pi*D^3
How does V change if we change d from 54m to (54 = 0.03*10^-2)m?
dV/dD = 1/4*pi*D^2
dV = 1/4*pi*D^2*dD
= 1/4*pi*(54)^2(0.03*10^-2)
I got 0.679 as an awesome and got it wrong...
Okay, using 2/3 seems a lot easier, but my professor gave an example in class of converting radius to diameter. Furthermore, I had a problem on a previous homework where I had to solve for the rate at which a sphere increased, and I got the right answer after converting the radius in the formula into diameter after attempting to solve for the rate at which the radius changed. If I do go about solving for the radius in this problem, what all needs to be done to address the problem of solving for diameter?
okay. thanks for the help, all!
Your original differential seems to be correct, you used sound mathematical principles, the only problem I see is the final answer. When I put .25*pi*(54)^2*.0003 I get .687. I have tried to figure out what you might have miss entered, but the formula you used was good.
