Gravitation deep hole physics problem
brad sue
Hi I am stuck with this problem:
A deep hole in Earth reaches a depth of one half of Earth's radius. How much work is done when a 1-kg mass is slowly lifted from the bottom of the hole to Earth's surface?
I use the expression of the gravitation force, F=GMm/R3
so the work would be:
integral (F*(R/2)) from R=R/2 to R=R
I am not sure I am right so I need your input please.
Thank you
Brad
Make sure you include the dependence that M has on r (the integration variable).
Your Force function is incorrect.
The Gravitational Force has an INVERSE SQUARE form [tex]F = m \frac{GM}{r^2}[/tex] .
The Force by Gravity will only be due to the mass of Earth that is
INTERIOR to the mass being lifted - presume uniform mass density, that is [tex]M = M_E \frac{V_{inside}}{V_E}[/tex] .
Thank you.
But How can I compute the Vinside? we only have the length nothing else?
B
Volume? LxWxH !
Yeah, rxrxr = r^3 , the variable r ,
compared with [tex]R_E^3[/tex] , the maximum R .
lightgrav said:
Volume? LxWxH !
OK! I am sorry . sometimes I am a little bit way off!
thank you so much
I can finish this problem now.
B
