Gravitational Time Dilation: What is R in the Equation?
  • Context: Undergrad
  • Thread starter Thread starter ilikescience94
The discussion revolves around the concept of gravitational time dilation, specifically focusing on the variable R in the equation T=T0/(sqrt(1-2GM/(Rc^2))). Participants explore the meaning of R, its definition in the context of the Schwarzschild equation, and the implications of measuring distances in curved space.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants explain that R represents the distance from the center of a spherical object, such as a planet or star, when calculating gravitational time dilation.
  • Others introduce the idea that R can be derived from the circumference of a large ring centered on the gravitational body, emphasizing that this definition may differ from a simple radius measurement due to the effects of curved space in general relativity.
  • A participant notes that while the distinction between R and a simple radius may not be significant in weak gravitational fields, it becomes important in stronger fields.
  • One participant expresses confusion about how to determine this new R rather than just using the radius, prompting further clarification.
  • Another participant acknowledges the potential for missing responses in forum discussions, indicating a supportive community atmosphere.
Participants generally agree on the basic definition of R as a distance from the center of a gravitational body, but there is no consensus on the implications of measuring R in curved space versus flat space. The discussion remains unresolved regarding the nuances of these measurements.
The discussion highlights the limitations of applying Euclidean geometry in curved space and the potential complexities involved in defining R in different gravitational contexts.
ilikescience94
Hey, I'm trying to understand gravitational time dilation, but can not find a good explanation for what R equals in the equation:
That formula is for the time dilation in the gravitational field of a spherical object (like a star or a planet) compared with the time measured by a far away observer.
##R## is just the distance from the center of the object (although there is a subtlety here, which I won't go into until you're happy with the simple answer). So if you wanted to calculate the gravitational time dilation at the surface of the Earth you'd set ##R## equal to the radius of the earth, about 6400 kilometers.
If you had a large ring centred on the centre of a gravitational body and measured the circumference of the ring, then dividing the circumference by 2*pi gives R as defined in the Schwarzschild equation you mentioned. ##T_0## is the time measured by a clock attached to the (non rotating) ring and T is the coordinate time measured by an observer at infinity.
This is trivially true in flat space, but in general relativity, R as defined in this metric is not the same as what you would obtain if you measured the radius of the ring using a tape measure from the centre of the body to the ring. (This is probably the subtlety that Nugatory is alluding to). This is because Euclidean geometry no longer works in curved space.
yes, that's it. It's not a big deal for weak gravitational fields (planets, ordinary stars, ...) but it matters a lot in stronger gravitational fields.
Thank you, I like this, and how would I find this new R rather than simply the radius?
You might have missed the answer, yuiop gave it already though.
I am not a smart man.
No need to dis yourself for missing a response, it's easy enough to miss forum responses by being in a hurry, or by having them "sneak in" in front of something you've read.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 43 ·
  • · Replies 103 ·
  • · Replies 16 ·
  • · Replies 21 ·
