Help for solving a 2nd order non-linear ODE
10 replies · 3K views
AdrianZ
[tex]yy''-y'^2 = y^2lny[/tex]
well, since the equation is of the form [itex]f(y,y',y'')=0[/itex] I turn it into the form [itex]f(y,p,p dp/dy)=0[/itex].
After those substitutions are made, we'll have the following equation:
[tex]yp (\frac{dp}{dy})-p^2-y^2 lny=0[/tex]
which is a Bernoulli equation that can be solved easily. the solution of this ODE is:
[tex]p^2=y^2lny+cy^2[/tex]
Here's where I'm stuck, because If I substitute y'=p again I'll have an ODE that I don't know how to solve it, I guess the general solution will be parametric, but I don't know how to proceed from this step.
Stephen Tashi said:
One thought is:
[tex]D( \frac{y'}{y}) = ln(y)[/tex]
[tex]\frac{y'}{y} = \int ln(y)[/tex]
Would you explain more please?
dextercioby said:
Have you tried a substitution y(x)=eq(x) ?
I don't know how that would work. Would you explain more?
Stephen Tashi said:
One thought is:
Stephen has these backwards.
D(ln(y)) = y'/y
so ln(y) = ∫(y'/y)
D(ln(y)) = y'/y
so ln(y) = ∫(y'/y)
Yes, I understood that, but how does that help?
I think this is what he means:
[itex]y'^2 = y^2 lny + cy^2[/itex]→ [itex]y^{-2}y'^2-lny=C[/itex]
→ [itex]\frac{y'^2}{y^2} - lny = C[/itex]→ [itex](\frac{y'}{y})^2 - (\int{\frac{y'}{y}dy})=C[/itex]
Hence, the equation has turned into the form [itex]u'^2 - u = C[/itex]. Has anything changed? Can I solve this one?
D(ln(y)) = y'/y
so ln(y) = ∫(y'/y)
That's not my thought. My thought is that the original equation is equivalent to the equation [itex]D(\frac{y'}{y}) = ln(y)[/itex]
But employing what you said:
[tex]D(\frac{y'}{y}) = \int \frac{y'}{y}[/tex]
Ahh, now I see what you mean. That's a great way of doing this ODE once you know that D(y'/y)=(yy''-y'^2)/y^2. Is there anyway to proceed with my own method?
Your solution is wrong at this step!
The correct solution is:
[tex] p y^2 (C + \ln^2{y}) = 1, \ p = y'[/tex]
If you split the variables, the integral over y is expressible in terms of elementary functions.
