How Many Moles of Na+ Are Needed to Soften 1.0×10^3 L of Hard Water?
  • Thread starter Thread starter David112234
To soften 1.0×103 L of hard water containing 0.015 M Ca2+ and 0.0010 M Fe3+, a total of 0.033 moles of Na+ are required. This is calculated by recognizing that Ca2+ requires double the moles of Na+ for charge balance, and Fe3+ requires triple the moles. Specifically, 0.03 moles of Na+ are needed for Ca2+ and 0.003 moles for Fe3+. Understanding the distinction between concentration and total amount is crucial in this calculation.
  • Understanding of molarity (M) and its implications in solutions
  • Knowledge of ionic charge balance in chemical reactions
  • Familiarity with intensive and extensive properties in chemistry
  • Basic calculation skills for mole conversions
  • Research the concept of ionic charge balance in chemical reactions
  • Learn about molarity and its applications in solution chemistry
  • Study intensive vs. extensive properties in detail
  • Explore practical applications of water softening techniques
Chemistry students, water treatment professionals, and anyone interested in understanding water softening processes and ionic balance in solutions.
David112234
Please post this type of questions in HW section using the template.
Water “softeners” remove metal ions such as Ca^2+ and Fe^3+ by replacing them with enough Na+ ions to maintain the same number of positive charges in the solution. If 1.0×10^3 L of “hard” water is 0.015 MCa2+ and 0.0010 M Fe3+, how many moles of Na+ are needed to replace these ions?
Ok, So this is how I would do it, Since Ca is 2+ ion you will need twice as much Na to replace its charge since Na is 1+. And for Fe 3+ 3 time as much. So if you have 0.015moles of Ca^2+ you would need 0.03 moles of Na. For Fe^3+ , 0.003 moles of Na
0.015 * 2 = 0.03
0.0010 * 3 = 0.003
But when I googled this question, I found this answer, where someone multiplied the moles of Ca, and Fe times Liters of water. (https://answers.yahoo.com/question/index?qid=20081023184058AAPL21u)
I don't understand why? Is my version correct? Or theirs?
You don't have 0.015 moles of Ca2+. You have 0.015 moles of Ca2+ per liter.
That's the definition of the concentration. Concentration is an intensive property, amount is an extensive property (check what these mean if you have not heard about them these are very important concepts).
Likes David112234
Oh, I did not realize it was giving me the concentration, I thought it was giving me just the amount in total. Thank you
