Finding E(Y) for sample variance with N(μ,σ) distribution
  • Thread starter Thread starter cse63146
    Expectation
9 replies · 2K views
cse63146
Let X1,...,Xn denote a random sample from a [tex]N(\mu , \sigma)[/tex] distribution. Let [tex]Y = \Sigma \frac{(X_i - \overline{X})^2}{n}[/tex]
How would I find E(Y)?
Any help would be greately appreciated.
You need to be sure you can justify steps and perform the omitted work
[tex] (X_i - \bar X)^2 = X_1^2 - 2X_1 \bar X + {\bar X}^2[/tex]
When you compute [tex]E[(X_i - \bar X)^2][/tex]
[tex] E[X_i^2][/tex]
should be easily found, and doesn't depend on i.
[tex] 2E[X_i \bar X] = \frac 2 n E[X_i (X_1 + X_2 + \dots + X_n)][/tex]
should be easily determined (and will not depend on i). Also,
[tex] E[{\bar X}^2][/tex]
should be easy to find (since you know the distribution of the sample mean).
Work these out individually, then combine them.
[tex]X^2_i[/tex] is a chi-square distribution with n degrees of freedom (since there are n Xi) and it's expectation would be n
[tex]\overline{X} -> N(\mu, \frac{\sigma^2}{n})[/tex] is a noncentral chisquare distribution [tex]\frac{X^2_i}{\sigma^2 /n}[/tex] and it's expectation is n*sigma^2
Kinda stuck on this one: [tex]2E[X_i \bar X] = \frac 2 n E[X_i (X_1 + X_2 + \dots + X_n)][/tex]
I was just wondering, would I be able to use the following property of the chi square distribution:
It would be a non-central Chi-square - but you don't need that. For any random variable what do you know about an expression for [tex]E[X^2][/tex] in terms of the first two moments?
I would make a comment similar to the first one here: you know the distribution of the sample mean, what do you know about the expectation of its square in terms of the first two moments?
Write it as
[tex] \frac 2 n \left( E[X_i^2] + \sum_{j \ne i} E[X_i X_j]\right)[/tex]
and remember that for [tex]i \ne j[/tex] the Xs are independent.
You could - IF you have already obtained that result elsewhere in your class.
Is this what you wre talking about:
[tex]E((X_i - \overline{X})^2)= \sigma^2 = E(X)^2 - E(X^2)[/tex]
not sure how that helps
Actually, just the second part:
If
[tex] \sigma^2=E[X^2] - \left(E[X]\right)^2[/tex]
what does [tex]E[X^2][/tex] itself equal?
[tex]E(X^2_i) = \sigma^2 + E(X_i)^2 = \sigma^2 + (n \mu)^2[/tex]
Would the expectation for Xbar2 be equal to the expectation of of Xi?
Why do you have
[tex] E(X_i)^2 = (n\mu)^2[/tex]
Should the [tex]n[/tex] really be there?
For [tex]E[\bar X^2][/tex], remember that the sample mean is normally distributed with mean [tex]\mu[/tex] and variance [tex]\frac{\sigma^2} n[/tex].
Isn't it because [tex]\Sigma E[X_i] = E[X_1] + ... + E[X_n] = n \mu[/tex] and each E[X] = mu, so there are n of them?
I asked because you didn't have the sum. My point is that for any random variable that has a variance,
[tex] E[X^2] = \sigma^2_X + \mu^2_x[/tex]
that is - the expectation of the square equals the variance plus the square of the mean.
