The maximum force you can apply to your skateboard is determined by the wheel-road friction force ##\mu N##.
I don't think your friction coefficient ##\mu## will be higher than 0.7. If you are powering 2 of 4 wheels, then the normal force ##N## is about half the supported weight, i.e. ##50\ kg \times 9.81\ m/s^2 = 490.5\ N##.
So the maximum force your skateboard can produce is ##0.7 \times 490.5\ N = 343.35\ N##. At the velocity you want, you then need ##1.1\ m/s \times 343.35\ N = 378\ W## of power or about ½ hp. That is what your maximum motor output should be (or less).
At 1.1 m/s, your wheel will revolve at ##\frac{1.1\ m/s}{0.030\ m}\times\frac{30}{\pi}\frac{rpm}{\frac{rad}{s}} = 350\ rpm##. So, for the gearing, whatever rpm your motor is, the gear ratio ##GR## will be ##GR = \frac{rpm_{motor}}{350}##.
