How Can a Frog's Jumping Pattern Lead to Normal Distribution Behavior?
2 replies · 2K views
Let X be a random variable with a Laplace distribution, so that its probability density function
is given by
[tex]f(x) = \frac{1}{2}e^{-|x|}[/tex]
Sketch f(x). Show that its moment generating function MX (θ) is given by
[tex]M_{X}(\theta) = \frac{1}{1 - \theta^2}[/tex]
and hence find the variance of X.
A frog is jumping up and down, attempting to land on the same spot each time. In fact, in
each of n successive jumps he always lands on a fixed straight line but when he lands from the ith jump (i = 1 , 2 , . . . , n) his displacement from the point from which he jumped is Xi cm, where Xi has the Laplace distribution described above. His displacement from his starting point after n jumps is
Y cm, so that [itex]Y = \sum_{i=1}^{n} X_{i}[/itex].
Each jump is independent of the others.
Obtain the moment generating function for [itex]\frac{Y}{\sqrt{2n}}[/itex] and, by considering its logarithm, show that this moment generating function tends to [itex]e^{\frac{1}{2}x^{2}}[/itex] as n → ∞.
Given that [itex]e^{\frac{1}{2}x^{2}}[/itex] is the moment generating function of the standard Normal random variable, estimate the least number of jumps such that there is a 5% chance that the frog lands 25 cm or more from his starting point.
[itex]M_{X}(t) = E(e^{tX}) = \int_{-\infty}^{\infty} e^{tx}f(x)dx[/itex]
I've sketched f(x), which looks like the graph of [itex]\frac{1}{2}e^x[/itex] for x < 0 and [itex]\frac{1}{2}e^{-x}[/itex] for x > 0.
I've found the moment generating function, and deduced that it has mean 0 and variance 2.
However, I'm unable to obtain the moment generating function for [itex]\frac{Y}{\sqrt{2n}}[/itex]. The mark scheme says this:
If [itex]T = \frac{Y}{\sqrt{2n}}[/itex], then [itex]M_{T}(\theta) = E(e^{T\theta}) = E(e^{\theta \sum \frac{X_{i}}{\sqrt{2n}}}) = \prod_{i=1}^{n}E(e^{\frac{\theta}{\sqrt{2n}}X_{i}}) = \left( 1 - \frac{\theta^{2}}{2n} \right)^n[/itex]
I understand everything up until where the last part; how are they turning that product into that neat (1 - theta^2 / 2n)^n term? My approach was to say that all the Xi have the same distribution, so every term in the product is the same, and you get this:
[itex]\left( \frac{1}{\sqrt{2n}}M_{X}(\theta) \right)^n = \left(\frac{1}{\sqrt{2n}(1 - \theta^{2})} \right)^n[/itex]
but this is clearly not equivalent to their answer. What have I done wrong here and what have they done to collapse their product into something so simple?
is given by
Careful: ##M_{X/\sqrt{2n}}(\theta) = E \exp(\theta X /\sqrt{2n})= M_X(u), \: u = \theta /\sqrt{2n}.## This is NOT equal to ##(1/\sqrt{2n}) M_X(\theta).## However, you are partly right: they should not have written ##(1- \theta^2/2n)^n##; it should be ##(1- \theta^2 / 2n)^{-n}.##
Sorry, that was my typo -- they did write that term to the negative power of n.
Okay thanks, I think that makes sense -- so [itex]M_{X}(a \theta) \neq aM_{X}(\theta)[/itex]?
Thanks, it makes so much sense now, they've just replaced the theta with theta / sqrt(2n) :)
