How can I create realistic gravity code for my video game?
4 replies · 5K views
AlbertRenshaw
Hello! I am a programmer and I am working on a video game, up until now I have used "gravity" to make objects fall just based off simple positioning code. I want to create realistic gravity code though!
Here is how the code works...
You simply create a variable and assign it a value..
ex. If I wanted to create a gravity constant I would say:
gravity = 5.485024534535
Now whenever I want to use this constant in my code / equations I will just type "gravity" instead of typing "5.485024534535"
You can set as many variables as you need..
I already have, height (the height of the object in the game), width (width in game), y (the y position (x-y cartesian coordinates) of the object, and a few other un-important things..
To set the y value of the ball you can say something like:
y = -50;
And the ball will move on the y-axis to -50 (coordinates of the top left corner of the screen = (0,0)
Dont worry about setting x-coordinate values in this code, it is falling in a straight path.
To define variables simply say:
variableName = variableNumber
I also have a function that is called every 0.01 seconds..
So inside this function if I were to say:
number1 = number1 + 5
and number1 starts out equal to 1, after 0.01 seconds it equals 1+5, another 0.01 seconds pass and it equals (1+5)+5, and so on.
Code should be in the following format:
Define variables here (each variable on a new line)
stuff that happens every 0.01 seconds here
Anyone up for the challenge?
Or even just want to help me understand how gravity works in moving things?
Have you had any exposure to kinematics? If not, it sounds like you are ready to run with something without the fundamentals under your belt.
All I need is a falling code, everything else will "fall" into play! (pun intended)
Not sure I can help you understand "how gravity works in moving things", but, however it works, I will say its consistent enough to be described by the following formula which you will need to implement in your code:
y=y0 + vy0t + 0.5ayt2
y : y position as a function of time, t
y0 : y postion when time = 0
vy0 : initial velocity in the y direction when time = 0
ay : acceleration constant in the y direction (on Earth it is -9.81 m/s2)
Use proper units: meters (m), seconds (s).
This should get you started. Have fun!
Since the downward direction is positive in most GUI coordinate systems, the value of g in MKS will be ~9.81 m/s2 (positive), unless you manually implement another coordinate system.
The kinematics equations describe motion about the center of mass, so you'll need to also take the shape of the object into account if you want to model collisions.
