MHB How can I find the kernel of a homomorphism of finite groups?
  • Thread starter Thread starter onie mti
    Finite Groups
onie mti
i was given that Z8 to Z4 is given by
f= 0 1 2 3 4 5 6 7
0 1 2 3 0 1 2 3
where f is homomorphism. how can i find the kernal K
f= 0 1 2 3 4 5 6 7
0 1 2 3 0 1 2 3
The kernel is the set of elements that map to 0...
It would be more compact to write:
$f(k\text{ (mod }8)) = k\text{ (mod }4)$
or even more succinctly:
$f([k]_8) = [k]_4$.
Also, usually one doesn't just "declare" a map to be a homomorphism, one has to prove it. In this example that means showing:
$f([k]_8+[m]_8) = f([k]_8) + f([m]_8)$ where the addition on the left is mod 8, and the addition on the right is mod 4.
I would start by showing:
$f([k]_8 + [m]_8) = f([k+m]_8) = [k+m]_4$.
Now clearly every $k = 8t$ (every integral multiple of 8) is also a multiple of 4: $k = 4(2t)$.
This means that $f([0]_8) = [0]_4$, so we know the kernel will at least contain $[0]_8$.
Are there integral multiples of 4 that are NOT multiples of 8?
(Hint: what are odd multiples of 4 reduced mod 8? Start with:
(2n+1)(4) = 8n + 4 =...? mod 8)
$f([k]_8) = [k]_4$.
I do not follow from the point where you said k=8t, why are we saying that
Presumably, we are dealing with the groups $\Bbb Z_8$ and $\Bbb Z_4$.
Do you recall how these groups are defined?
The reason I put brackets around the "$k$", is because the "1" (for example) in $\Bbb Z_8$ is not "the same 1" as we have in the integers.
I "tag" the brackets with a subscript, so we know "which group they came from".
So when I write $k$ (or some other letter) without the brackets, I mean the actual integer.
Here is how we create $\Bbb Z_8$:
we send the sets:
$\{...-24,-16,-8,0,8,16,24,...\} \to [0]_8$
$\{...-23,-15,-7,1,9,17,25,...\} \to [1]_8$
$\{8n+k: n \in \Bbb Z\} \to [k]_8$.
So if an integer $m$ is in the SET $[k]_8$ (these are COSETS of the multiples of 8, that is cosets of the subgroup $8\Bbb Z \subseteq \Bbb Z$), this means $m = 8n + k$, for some integer $n$.
The group $\Bbb Z_8$ is referred to variously as:
"The cyclic group of order 8"
"The integers modulo 8"
"The quotient group $\Bbb Z/8\Bbb Z$".
Do you have more questions?
we send the sets:
thanks a lot. :o
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
