MHB How can I find the kernel of a homomorphism of finite groups?
  • Thread starter Thread starter onie mti
    Finite Groups
onie mti
i was given that Z8 to Z4 is given by
f= 0 1 2 3 4 5 6 7
0 1 2 3 0 1 2 3
where f is homomorphism. how can i find the kernal K
f= 0 1 2 3 4 5 6 7
0 1 2 3 0 1 2 3
The kernel is the set of elements that map to 0...
It would be more compact to write:
$f(k\text{ (mod }8)) = k\text{ (mod }4)$
or even more succinctly:
$f([k]_8) = [k]_4$.
Also, usually one doesn't just "declare" a map to be a homomorphism, one has to prove it. In this example that means showing:
$f([k]_8+[m]_8) = f([k]_8) + f([m]_8)$ where the addition on the left is mod 8, and the addition on the right is mod 4.
I would start by showing:
$f([k]_8 + [m]_8) = f([k+m]_8) = [k+m]_4$.
Now clearly every $k = 8t$ (every integral multiple of 8) is also a multiple of 4: $k = 4(2t)$.
This means that $f([0]_8) = [0]_4$, so we know the kernel will at least contain $[0]_8$.
Are there integral multiples of 4 that are NOT multiples of 8?
(Hint: what are odd multiples of 4 reduced mod 8? Start with:
(2n+1)(4) = 8n + 4 =...? mod 8)
$f([k]_8) = [k]_4$.
I do not follow from the point where you said k=8t, why are we saying that
Presumably, we are dealing with the groups $\Bbb Z_8$ and $\Bbb Z_4$.
Do you recall how these groups are defined?
The reason I put brackets around the "$k$", is because the "1" (for example) in $\Bbb Z_8$ is not "the same 1" as we have in the integers.
I "tag" the brackets with a subscript, so we know "which group they came from".
So when I write $k$ (or some other letter) without the brackets, I mean the actual integer.
Here is how we create $\Bbb Z_8$:
we send the sets:
$\{...-24,-16,-8,0,8,16,24,...\} \to [0]_8$
$\{...-23,-15,-7,1,9,17,25,...\} \to [1]_8$
$\{8n+k: n \in \Bbb Z\} \to [k]_8$.
So if an integer $m$ is in the SET $[k]_8$ (these are COSETS of the multiples of 8, that is cosets of the subgroup $8\Bbb Z \subseteq \Bbb Z$), this means $m = 8n + k$, for some integer $n$.
The group $\Bbb Z_8$ is referred to variously as:
"The cyclic group of order 8"
"The integers modulo 8"
"The quotient group $\Bbb Z/8\Bbb Z$".
Do you have more questions?
we send the sets:
thanks a lot. :o
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
