How can I solve this normed inner product space problem without a prefix?
  • Thread starter Thread starter Sheldinoh
    Vectors
The discussion revolves around a problem involving a normed inner product space, specifically focusing on the calculation of the norm of the vector expression ||3v + w|| given certain properties of the vectors v and w, including their magnitudes and their dot product.
  • Participants explore the geometric interpretation of the dot product and its relationship to vector lengths and angles. There are attempts to derive the expression for ||3v + w|| using properties of inner products and distributivity.
The discussion is active, with participants providing hints and building on each other's contributions. Some participants express uncertainty about the geometric interpretation of the dot product, while others clarify its significance. There is a focus on deriving the norm expression through mathematical properties, but no consensus on a numerical answer has been reached.
Participants mention the context of a math exam and express varying levels of familiarity with inner product spaces, indicating that some foundational concepts may not have been fully covered in their prior studies.
Sheldinoh
This question was on my math calc and analytical geometry final and i couldn't figure out how to do this. Its probably something pretty simple but i couldn't figure it out
1. Homework Statement [/b]
||v|| = 1 ||w|| = 2 v•w= (-1/2)||v|| ||w||
||3v+w|| = ?
Thanks in advance for the help
Geometrically, what does the dot product represent?
im not really sure. is it that the dot product geographically represents the length of one vector over another vector
Geometrically, the lengths of the vectors are involved in the dot product, but so is the angle between the two vectors.
Do you know what this relationship is?
v•w = ||v|| ||w|| cosθ
but how would i get to ||3v+w|| from knowing this
For inner products (including the dot product), we have a few definitions that we use.
The first one is that we define the norm of a vector through its inner product to be
|v| = SQRT(<v,v>) >= 0.
We also define the inner product to be distributive ie <(v + w),x> to be <v,x> + <w,x>
Given these definitions, can you now solve the problem?
would it be:
||3v+w||= ( 16x2+(3vy + wy)2 ) 1/2 .
If so, i was kinda under the impression that the professor wanted an numerical answer.
Sheldinoh said:
would it be:
I'll give you a hint:
||3v + w|| = SQRT(<3v + w,3v + w>) (using the fact that |v| = SQRT(<v,v>)).
Think about the other properties of the dot (and in general inner) products.
I think you are trying to say it is the length of the projection of one vector on the other.
Yes, correct. With inner products, we have:
[tex]v \cdot w = |v| |w| \cos \theta[/tex]
where theta is the angle between the two vectors.
In your original problem statement, you also indicated that:
[tex]v \cdot w = \left(-\frac{1}{2}\right) |v| |w|[/tex]
Now, as a next step, using these two facts, are you able to deduce what the cosine of the angle between the two vectors is? And from there, deduce what the actual angle is?
Sheldinoh said:
would it be:
Building on my first hint, we can use the property of distributivity:
||3v + w|| = SQRT(<3v + w, 3v +w>) = SQRT(<3v + w,3v> + <3v + w,w>)
= SQRT(<3v,3v> + <3v,w> + <3v,w> + <w,w>)
= SQRT(9<v,v> + <w,w> + 6<v,w>)
Given what you know, you should be able to find the numeric answer to your question.
This is the quick and, in some ways, "simple" way to get the answer.
But I'm also thinking that most people don't see normed inner product spaces until they get to a course on real analysis, which might be a bit ahead of where the OP is at.
But yes, you've basically laid out the right answer here..
Ohhh ok. In my math degree we were introduced to inner product spaces in a second year one semester linear algebra course and all the definitions like distributivity, linearity, positive definiteness and so on were done in about 10 minutes.
To the OP, if you haven't done things in this way and you've done linear algebra, get out a book and learn about inner product spaces and the criteria for an inner product to have. The inner product spaces build on vector spaces.
  • · Replies 26 ·
