How Can We Comprehend the Concept of a Finite Universe?
  • Thread starter Thread starter wolram
    Finite Universe
Imagining a spatially finite universe poses significant challenges, as it requires conceptualizing dimensions beyond our typical experience. The discussion draws parallels between understanding a finite universe and historical misconceptions about Earth's shape, emphasizing that our brains may struggle with higher-dimensional concepts. Analogies involving lower-dimensional beings illustrate how humans might grasp the idea of a finite universe, such as a "threesphere," where traveling in one direction eventually leads back to the starting point. The conversation also touches on the implications of cosmic inflation, suggesting that while the universe appears flat locally, its true geometry may be more complex. Ultimately, the difficulty lies in visualizing these abstract ideas within the limitations of human cognition.
  • #51
setAI said:
ultimately I think that the very idea of a universe finite or infinite with a 'boundary' is wrong-headed- a thing like a universe emerges from the relationships of a causal network- the metrics of distance/duration are established by the relationships of the elements in the network- a boundary is only an arbitrary concept of where one can fit the abstract map of such a causal set in an imaginary mathematical space- but there is no reason for that map-space to exist in any physical way- the elements and events that arise in a causal network don't connect to any kind of outside boundary- causality and the metrics of space and time that emerge from it propagate locally through the elements/events in the network ONLY- there is no spatial/temporal analog of a 'boundary' to be fenced-in by-
given this- my thinking is that emergent systems of relationships that arise form causal networks -like universes [whether they are infinite or finite]- are boundary invariant
Theories for finite univeres I've researched have a shape whether its a hypersphere or a dodecahedron and a way for it to seem boundless whether its mirrors or traveling so far you return to where you started. A good example I feel is a pac man game (no offense). It has a shape and is boundless for pac man. As pac man travels he notices he always returns to his starting point even if traveling in a strait line, he correctly concludes that the curvature of digital space must be the cause. He also assumes the universe must be finite. However one day he tries an experiment. He finds a large dot and specialy marks it then travels in a strait line counting all the small dots till he returns to his large dot. He counted 1000 dots so he can rightfully assume that the distance across his universe is 1000 dots. He then repeats the experiment with other large dots and compares his finding thus being able to pin point where the warp occurs, or where the boundry of his possible travels. He can then do a thought experiment in which he travels 10,000 dots from the large one without traveling through the warped space. He then can consider the possibility of an infinite universe. My point is that a finite universe by nature has boundries. In the end I come to the same conclusion of universes being boundry invairiable and since a finite universe must have a boundry I personaly conclude that the universe must be infinite. Additionaly the hyperspere uses multiple dimensions to prove it correct. For one pac man is not 2D he is made of pixels which are 3D, they have length width and height regardless of how small. Second its impossible to conceive these dimensions because we are 3D (the theories own argument) therefore it seems scientificly unsound.
Space news on Phys.org
  • #52
VikingF said:
I don't quite understand this, because I thought it almost was a "proven fact" that our universe is finite, and not infinite...? :confused:
Finite universes is taught as almost proven fact by many teachers and professers. The idea of a finite universe is very comforting vs an infinite one because we can fully understand (over time) a finite universe. A infinite universe can have a large number of possible contradicting laws and is very chaotic thus limiting what we can hope to understand. Though I personaly believe over time we will find laws to explain the chaos. Additionaly history has shown man prefers to be as important as can be, an infinite universe makes us even smaller and more insignificant.
  • #53
SpaceTiger said:
Keep in mind that much of this stuff is a long way from experimental testing -- science is probably a long way from providing a definitive answer to the finite/infinite question.
I agree, only time will tell for sure. Hopefully though it will be rather soon so I can start my victory dance.
  • #54
Balence said:
...He counted 1000 dots so he can rightfully assume that the distance across his universe is 1000 dots. He then repeats the experiment with other large dots and compares his finding thus being able to pin point where the warp occurs, or where the boundry of his possible travels.
Care to explain how Mr. Pac-Man made this last deduction?
  • #55
Your ideas are not falsifiable and can't really be called science. Basically, it sounds like you're asserting that any self-contained finite universe must be embedded in a larger space (as per the "boundaries" you speak of). I disagree with you on philosophical grounds, but we can never disprove your assertions any more than we can disprove the existence of a "creator". If this infinite space you speak of is out of causal contact with our universe, then there's nothing we can do to detect it.
  • #56
He conveniently has a living space in which every straight line of dots going horizontaly have 1000. Conveniently each big dot is one small dot down and to the right of the first big dot. Conveniently the horizontal dots are equal to the vertical so both dimensions are 1000. Using the big dots as markers packman can create a map that would show a declining line of big dots slanting through the center of his finite space. From this he can conclude where the warp is. You can also try drawing it out on graph paper. If this doesn't work then he kept getting digispace sick and figured it must be that warped space. I really wanted to get to the point and wanted to get off pac man so I skiped how he might figure this out.
  • #57
At this point my theory does loose scientific value due to the fact we can not currently detect this infinite space. However, many current finite theories have even less scientific value and are widely accepted as known truth despite the inability to properly test them thus making them even more unscientific. According to occams razor an infinite universe is more feasible than a finite one. I only assume one thing that is rational, and keep it simple. Finite theories assume alot, much of which is "inconcievable" to us, (irrational) have simular instances in history, (earth being in the center, spontaneous generation) finnaly, and coinciding with my last point, the idea is very alluring as the universe is more predictable if its finite. Additionaly there are several different finite universe theories out there. My point is that while infinite universe theory can be compared to theories of a "creator" its much more closer to compare "creator" with finite theories.
  • #58
How does he know where to put the big dots such that they pass through the center?
Let's try a simpler example to ensure that we're on the same page. Suppose Pac-Man is confined to one dimension (a line). You see him on the screen, moving along the line. From your point of view, he keeps moving to the edge of your screen until he reaches the "warp" point and then comes out the other side. But does this warp point have any significance to Pac-Man? On an initially unmarked line, is there any point along the line that is different from the other? No, from his point of view, it's just a line seeming to extend off infinitely in either direction. He can determine the size of his finite universe by simply marking a point and seeing how long it takes to come back to it. However, there's way for him to know if that point is on the edge or the center of your screen.
The situation is similar in 2-D. The initially unmarked landscape is just a plane seeming to go off inifinitely in all directions. He can mark any set of points that he likes, but there's no way for him to know where these points lie in relation to the center of your screen or the "warp", as you put it.
  • #59
We could never detect infinity to start with, but what's worse is that there is no hypothetical observation that could prove your theory wrong. You could always just say that we're out of causal contact with this extra universe.
All current scientific theories are hypothetically testable, but many are beyond the reach of current technology. Your theory is not falsifiable even in principle.
Actually, occam's razor says nothing about an infinite versus a finite universe. If, however, we discovered that the universe was finite, one could invoke occam's razor to support the case for a universe with no boundaries.
I think you've misunderstood. I'm not comparing infinite theories to theories of a creator, I'm comparing your "universe with boundaries" idea to that of a creator. Infinite universes are commonplace in mainstream science.
  • #60
an odd thing- you can in principle prove the universe is finite- if it is- but can you EVER prove or even know if it is infinite? I would think that locality makes it impossible even in principle-
  • #61
To the best of my knowledge, there's no way to prove (or even find evidence for) an infinite universe. However, a proper scientific model can still be disproven even if it predicts an infinite universe.
  • #62
Hi SpaceTiger.
My intuition would say that the Universe is infinite in diameter although I know it could never be proven so it would always remain a mystery, A Universe with infinite Super Galaxies that never end.
I tend to believe this because to my knowledge an edge has never been found and that Nature abhores a Vacuum and likes to fill it's space.
I wanted to ask if Scientist are steering more to the infinite Universe concept?
  • #63
Infinite Super Galaxies? Where is that coming from?
There is a definite "edge" to the observable universe, but right now there's no way to know how much lies beyond that.
That's not really relevant, the question concerns the amount of space, not what fills it.
Not to my knowledge. I think the majority view is that the universe is much larger than we can currently observe, but it's still unclear how large.
  • #64
Hi SpaceTiger
It was a general self belief only, I don't believe a vast void exists with nothing in it, Strictly empirical.
Is Science saying that the observabale Universe is thinning out?
I never realized that Science had come that far as to see an edge, My apollogies if this is the case.
But doesn't the Universe follow the same rules as the rules of a Vacuum?
I understand, Thanks.
P.S
I really do respect your knowledge and position in this forum, I do look up to you.
  • #65
He doesn't place the big dots, theyre "convienently" placed. Pac man is still 3D, you can't see 1D without the other two. If nothing else he kept getting space sick at the same point.
  • #66
My theory isn't falsifiable so far because I could pose the question of what lays beyond.
Its based on principle.
A rule in science and philosophy stating that entities should not be multiplied needlessly. This rule is interpreted to mean that the simplest of two or more competing theories is preferable and that an explanation for unknown phenomena should first be attempted in terms of what is already known. Also called law of parsimony.
By deffinition occam razor doesn't directly state anything about infinite vs finite. However it applies to all theories of science and philosophy which include infinite vs finite. An infinite universe is much more simpler and goes by what has been observed for ages.
I did misunderstand. However the universe with boundaries is not my idea, it is the neccessity of a finite universe. Infinite universes is an oxymoron. If the term universe means all there is and it is infinite or even finite, there could never be more than one.
  • #67
I guess logic and thought experiments don't count?
  • #68
You can't prove a finite universe by principle. You can't disprove an infinite one by principle.
  • #69
Empirical implies that it has been observed...and it hasn't. In fact, galaxies never get any bigger than a hundred or so kiloparsecs (an observational fact). Larger gravitationally bound objects are known as galaxy clusters.
No, the edge of the observable universe is the maximum distance light could have traveled since the beginning of time (or recombination).
  • #70
And he receives the meaning of those dots from "on high"? Come on, this is getting ridiculous.
You can't be serious...
Nope, the number of free parameters in the finite models can be made to be the same as in the infinite ones.
There is no need for a boundary anymore than there is need for a creator. It's just a human concept being unnecessarily forced on the natural world.
The plural was referring to theories of infinite universes -- "Infinite universes are commonplace in mainstream science". That means there are many mainstream theories of the universe that are infinite.
  • #71
It is getting ridiculous. I never intended to debate it in the first place.
This is my serious face...
How so?
Finite- Having bounds; limited + Universe- All matter and energy, including Earth, the galaxies and all therein, and the contents of intergalactic space, regarded as a whole. Obviously words cannot describe a finite universe because by definition it contradicts its self.
Ah, I see what your saying, sorry bout that.
  • #72
Okay, it's obvious that there's no attempt at understanding here, so if you'd like to continue this line of "research", please do so in the independent research forum. Depending on how they're interpreted, your ideas are either non-scientific or just wrong, so further discussion does not belong here.
