How did the author transform the original equation into the Legendre equation?
The discussion revolves around the transformation of a second order ordinary differential equation into the Legendre equation, as presented in George F. Simmons' "Differential Equations with Applications and Historical Notes." Participants are exploring the mathematical steps involved in this transformation, focusing on the change of variable from ##\phi## to ##x = \cos(\phi)##.
  • One participant expresses confusion about the transformation from the original equation to the Legendre equation and seeks clarification.
  • Another participant suggests computing ##dx/d\phi## as a necessary step in the transformation process.
  • Further contributions involve applying the chain rule to relate derivatives with respect to ##\phi## and ##x##, with specific calculations provided for the first and second derivatives.
  • One participant notes that the term involving ##2## in the second derivative is not accounted for and questions its origin.
  • A later reply proposes that there may be a typo in the original equation, suggesting that the transformation may not have been accurately represented.
  • Another participant reiterates the calculations and emphasizes the need to consider that ##dx/d\phi## is not constant, leading to a more complex relationship between the derivatives.
Participants do not reach a consensus on the transformation process, as there are differing views on the accuracy of the original equation and the handling of the derivatives. The discussion remains unresolved regarding the specific steps leading to the Legendre equation.
There are limitations in the discussion, including missing assumptions about the continuity and behavior of the derivatives involved, as well as potential dependencies on the definitions used for the variables and functions.
Thomas Michael
TL;DR
How does one go from ##\phi## to ##x=\cos(\phi)##
I'm reading "Differential Equations with Applications and Historical Notes" by George F. Simmons and I am confused about something on pages 431-432
He has the second order ordinary differential equation
$$\frac {d^2v} {d\phi^2} + \frac {\cos(\phi)} {\sin(\phi)} \frac {dv} {d\phi} + n(n+1)v = 0 ~~~~~~~~~~~~~~~~~~~ eq. 1$$
And then using a change of independent variable from ## \phi ## to ## x = \cos(\phi) ## eq 1 is transformed into the Legendre equation
$$ (1-x^2) \frac {d^2v} {dx^2} - 2x \frac {dv} {dx} + n(n+1)v = 0 ~~~~~~~~~~~~ eq. 2 $$
But I don't see how he got from eq 1 to eq 2
Anyone feel like helping me out?
First you need to compute the ##dx/d\phi## given you know x in terms of ##\phi##
Ok, I think that makes sense. So just use the chain rule:
$$ \frac {d^2v} {dx^2} \frac {dx^2} {d\phi^2} $$
With ##x=\cos(\phi)## the first term will have
$$ \frac {d\cos(\phi)} {d\phi} = \frac {dx} {d\phi} = -\sin(\phi)$$
$$ \frac {d^2x} {d\phi^2} = \sin^2(\phi) $$
$$ \sin^2(\phi) = 1-\cos^2(\phi) $$
and with ##x=\cos(\phi)## it turns into ##(1-x^2)## and the second term will have
$$ \frac {\cos(\phi)} {\sin(\phi)} \frac {dv} {dx} \frac {dx} {d\phi} = -\sin(\phi) \frac {\cos(\phi)} {\sin(\phi)} \frac {dv} {dx} = -\cos(\phi) \frac {dv} {dx}$$
$$-\cos(\phi) = -x$$
Though now I still can't account for the ##2## in the second term ##-2x \frac {dv} {dx} ##
##x = \cos \phi \rightarrow dx = - \sin \phi d \phi \rightarrow - \frac{dx}{-\sin \phi} = d \phi \rightarrow \frac{-dx}{d \phi} = \sin \phi##
Thus, we have ##\frac{\sin^2 \phi d^2 v}{dx^2} - \frac{d \phi x}{dx} \frac{dv}{d \phi} +n(n+1)v = 0 ## Making the substitutions you mention, we get ##(1-x^2)\frac{d^2 v}{dx^2} -x \frac{dv}{dx}+n(n+1)v = 0 ##
So, maybe a typo.
Here dx/d\phi = -\sin\phi is not constant; thus \frac{d^2v}{d\phi^2} = <br /> \frac{d}{d\phi}\left(\frac{dv}{d\phi}\right) = <br /> \frac{d}{d\phi}\left(\frac{dx}{d\phi} \frac{dv}{dx}\right) = \frac{d^2 x}{d\phi^2} \frac{dv}{dx} + \left(\frac{dx}{d\phi}\right)^2\frac{d^2v}{dx^2} = -x \frac{dv}{dx} + (1 - x^2)\frac{d^2v}{dx^2}.<br />
  • · Replies 0 ·
  • · Replies 21 ·
