How do I solve torque-related problems involving multiple forces?
  • Thread starter Thread starter Romanian
The discussion focuses on solving torque-related problems in physics, specifically involving a boulder on a plank supported by two people. To find the forces exerted by each person, the principles of static equilibrium are applied, including the requirement that the sum of forces and torques must equal zero. The user initially struggles with calculating the actual forces after establishing a ratio and is advised to set a fulcrum point to simplify the torque calculations. A subsequent question involves determining the normal forces on an airplane's wheels, where similar torque principles are applied, but the user encounters discrepancies in their calculations. The importance of correctly choosing the reference point for torque calculations is emphasized, along with the need for clarity in posting new questions to avoid confusion.
Romanian
First off, I'd like to say I admire you all very much. At first, I thought I was pretty advanced in physics, and I am at my school. But looking through these forums... damn. Now my question seems stupid :rolleyes:
I had a problem in my AP Physics class which I just couldn't get. It was related with Torque. (Chapter 9, Page 270, #63 for those who have the 5th Edition Cutnell book). Basically, the problem has a boulder of weight 695.8N on a plank of length 2 meters. The boulder is 1.4 meters from one end. Person A and B support it at each end so that it is horizontal. Person A is nearest the boulder. If weight of the board is negligible, what force does person A apply to the board, and what is the force person B applies to it?
I got part of it correct. I found the ratios of the forces by using Tnet=Tcwise+Tccwise. That ended up giving me 0=-F(A)*1.4+F(B)*0.6, which gives me the ratio of FpersonA=2.33FpersonB. Now I don't know how to find the actual forces. A friend of mine in the class just set one of the endpoints as a fulcrum or something, and solved for one of the forces. I didn't understand this at all; I may not even have his basic concept down.
Some help would be appreciated. Thanks in advance.
Think about the requirements of equilibrium. What three things have to be true for something to be in equilibrium?
1. Vector sum of all external forces that act on the body must be zero.
2. Vector sum of all external torques that act on the body, measured about any possible point, must be zero.
3. The linear momentum of the body must be zero.
Since the boulder, plank and people aren't moving, the system is in static equilibrium.
Draw a FBD of the problem. You should see that the net force acting on the system is:
F1 + F2 - mg = 0
Where F1 is person A on the left and F2 is person B on the right. mg is the weight of the boulder in Newtons.
Since you have two unknowns, you must use fact number 2 above. That is, the net torque acting on the body must be zero as well. Hence...
0*F1 - 1.4*695.8 + 2*F2 = 0
Solve that equation for F2 and then plug F2 back into the first equation (F1 + F2 - mg = 0) to find F1.
Make sense?
Ah, yes sir, I forgot to put in mg of the boulder. Thank you. I've got my chapter 1-10 exam tomorrow. Cram, cram, cram. I'll post some more questions soon.
Bump
Back, with a very similar question. This time it's an airplane. I need to find the normal force of each of the two back wheels and the one front wheel.
The two back wheels are 15m behind the front wheel. The center of gravity is 12.6m behind the front wheel. It is a plane of weight 1.6x10^6 N.
So, I did as Stewart said. I've set F1 (back wheel) + F2 - mg = 0. Then I did the t1+t2-tmg=0, and set the "measured point" as F2. That makes it:
0*F1+15*F2-12.6*1.0x10^6=0, and therefore F1=8.4x10^5N. This is wrong. It is double of what it should be, according to the answer book. One possible explanation is that I somehow inverted it, where F2 should have been the "measured point". That means that I would have to divide it by two, for I need the force of one wheel.
Would you also be so kind as to explain how exactly you get the other information once you set your measured point? Using the last example, I'm assuming that it's just 1.4*695.8 because it is 1.4m away from the non-measured point. If it were switched, would this be 0.6*695.8?
Thanks in advance.
Look back at condition number 2. It says that the vector sum of all external torques that act on the body, measured about any possible point, must be zero.
So, in that example, I picked the left end of the beam (you could have picked the right if you wanted to instead). The distance from the applied force (F1) is 0 meters, hence, 0*F1 = T0. Now for the boulder, it is 1.4 meters from the reference point I picked. Hence, 1.4*mg = T1 about the reference point due to the boulder. However, it is applied in the downward direction, so using the standard sign convention for torques, it will be negative (i.e. clockwise = negative, and counter-clockwise = positive). The last point was the length of the beam (the end point on the right where F2 was applied). Hence, 2*F2 = T2. Now, remembering condition 2 again, the vector sum of those must be zero, so set the vector sum of those to 0 and solve for the unknown variable.
This particular question indicated that the forces were perpendicular to the beam, so it works out nice and easy. If they were not perpendicular, the you would have to multiply by the cos(theta). Where theta is the angle the force is applied at.
BTW, please post your new question's under a new topic if it is not related to the old one (i.e. it's a new question). You'll get more responses. Just don't double post in other forums, you'll get yelled at.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
