How Do Proper Acceleration and Gravity Affect Time Dilation in Free Fall Orbits?
87 replies · 10K views
jbriggs444 said:
What does "unified" mean?
Sorry that should be "uniform"
Dale said:
Please re read the definition I gave previously: "Local means close enough in space and time so that tidal effects are negligible. I.e. a uniform gravitational field". Is the gravitational field uniform in the region containing both clocks? Are tidal effects negligible?
Would they not be once the radiation had passed the distant clock a million years before at c?
name123 said:
If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
Yes, but note that the metric will have a different form in these different charts. With a correct expression for the metric, all invariants will be correctly calculated.
A.T. said:
The energy distribution affects the gravitational potential and thus the clock rates between distant points.
So considering just the distant clock
1) Before the shell had radiated (imagine it was a light year away)
2) A year after the radiated had passed it at c.
What energy distribution difference between 1 and 2 were you thinking would explain the affect?
Gravitational time dilation is always between two separated clocks. With just one clock there is nothing to explain.
These two clocks are not local:
name123 said:
(the clock in flat spacetime in distant space outside the shell and the clock in flat spacetime in flat spacetime inside the shell)
These two clocks are local:
The distribution of the energy in the shell
Then consider both the clocks.
1) Clock 1 in the shell in flat spacetime before the shell had radiated, and Clock 2 a light year outside the shell
2) Clock 1 two years after the shell has radiated away, the space time flat as it was in scenario 1, Clock 2 a year after the radiation from the shell had passed it.
So the gravitational energy causes the time dilation?
Dale said:
name123 said:
Consider satellites A and B, going at different velocities, in free fall orbit around a massive body C at different altitudes for a million years, then being brought together and the clocks on them compared. Presumably the bringing them together would become less significant the longer they orbited, and the amount of time dilation due to curvature would be frame of reference independent, but what about the observed velocities from the mass being orbited's perspective? If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
If each had a ruler and a clock on board, when they were at rest together could they not all go by their own clock and ruler, and agree that their clocks and rulers were metrically equivalent?
name123 said:
Also regarding A, B and C being at rest, I am not quite clear how A or B could be considered at rest and not rotating, as while C (the mass) could be considered to orbit A or B, if it was so considered, would it not also need to be considered that it was rotating, for an explanation of why the same section of C was not always facing A (or B), and could it not be objectively measured that it was not rotating?
Could you explain this please?
Also energy due to "stuff" like matter or light or whatever.
Yes, completely.
The question is ambiguous. I cannot tell if you are asking about proper rotation or coordinate rotation.
Proper rotation assuming that it what causes the proper acceleration that can be measured.
Whether or not a given object is undergoing proper rotation is an invariant. It does not depend on the coordinates chosen. You can choose coordinates where a proper-rotating object is at coordinate-rest. In such coordinates there will be "fictitious forces" which will lead to the correct amount of proper rotation.
Dale said:
Yes, completely.
So A would agree with B about the expected differences between their clocks due to gravitational time dilation. And the affect due to bringing the clocks together could be considered insignificant if the orbiting had gone on for long enough.
Would not A think, using the metric of A's clock, that B's clock had ticked less than would have been expected (taking gravitational time dilation into account) if it had been in A's rest frame, and B, using the metric of B's clock, think that A's clock had ticked less than would have been expected (taking gravitational time dilation into account) if A had been in B's rest frame?
So with the A, B, and C coordinates it seems arguable that while the maths can model the relative motion regardless of which is thought to be at rest, only one rest frame would give the coordinate rotation which corresponds to the correct measurable proper rotation, without the addition of fictitious forces? Also I have read that fictitious forces are used with non-intertial frames of reference, but would not both A and B at rest both be intertial frames of reference (what intertial frame are they undergoing accceleration relative to)?
Yes, as edited.
I have no idea how to parse the other question. In GR, the proper time on any clock undergoing any motion in any frame in any spacetime is given by ##\int \sqrt{ g_{\mu \nu} dx^{\mu} dx^{\nu}}##
Could you make up some figures for the scenario, and use them in the equation to demonstrate please (just so I can see how it works)?
P.S. Regarding where I had written: "So A would agree with B about the expected differences between their clocks due to gravitational time dilation." I had thought it was invariant how much difference would be expected due to gravitational time dilation. I thought in the Hafele-Keating experiment they had split the affects expected due to gravitational time dilation and kinematic time dilation to come up with their estimates, and so was thinking that you might be able to explain whether the expected gravitational time dilation affects would be same regardless of frame of reference, and if they were, and the coming together was insignificant (given long enough orbit), then simply explain why the kinematic time dilation expectations would be the same from each perspective, or how else they came to the same answer when added to the gravitational time dilation effects.
Dale said:
Why don't you work through the first few chapters of Sean Carroll's lecture notes on general relativity first.
Are they free and do they contain a worked example of the equation you quoted? I think, I or other basic level followers could probably follow where the numbers were plugged in, but might not so easily follow how to correctly use the equation in the situation otherwise.
I hope you do not mind me re-replying to the post but I had asked:
name123 said:
Also I am not quite clear how A or B could be considered at rest and not rotating, as while C (the mass) could be considered to orbit A or B, if it was so considered, would it not also need to be considered that it was rotating, for an explanation of why the same section of C was not always facing A (or B), and could it not be objectively measured that it was not rotating?
and you asked me to clarify what I meant proper rotation or coordinate rotation, I explained that I had meant proper rotation (I was referring to the measurement, not the coordinate rotation that would appear if A or B were considered to be at rest) and you replied:
But that still does not seem to answer my question. As I now understand it "fictitious forces" have a special meaning in physics and refer to forces added for explanation when describing motion from a non-inertial frame of reference. But the question was about from the frame of reference A or B which as I understand it are both inertial frames of reference. While they considering them at rest, C would show coordinate rotation (though there would be no measurable rotation). So the measurements would not seem to support how it would be expected to be if A or B were actually at rest relative to C. If they were, and C were actually rotating then you would expect to measure proper rotation on C.
Also from the perspective of the inertial frames A and B if there were distant stars, wouldn't they appear to be moving faster than the speed of light?
Dale said:
Yes, they are free
https://arxiv.org/abs/gr-qc/9712019
Working an example without the background would require a lot of effort on my part and result in very little gain for you. But reading the first couple of chapters of the lecture notes will result in a lot more gain for you.
Thanks for the link, and for the help so far. I don't know whether you noticed, but I posted a new reply #52 to one of your earlier replies.
Which is a good hint that they aren’t inertial.
They are only locally inertial. And even locally it is only inertial if the object is not undergoing any proper rotation.
Neither the stars nor the other objects are local.
So I then assume A relative to B and C in the scenario should be considered as non-inertial even though an accelerometer at rest with respect to A would measure no acceleration?
If so then with A being non-inertial a fictitious force would be added to describe the coordinate rotation of C from A's rest frame. What is the fictitious force that would explain it?
When the considerations of A, B, and C being at rest are compared, does not only the consideration of C being at rest give a proper rotation for C in line with its coordinate rotation?
In curved space-time there is no such thing as a global inertial frame of reference.
Rotating frames are not inertial.
Yes, if you want to make any non-local measurements then you need to consider them to be non inertial.
They are called "Christoffel symbols" (I know, it is a weird name). The lecture notes describe them in detail.
