How Does a Flea Jump Over a Cylinder Using Parabolic Motion?
  • Thread starter Perpendicular
    Motion
14 replies · 3K views · last reply
Perpendicular
a hyper-intelligent flea jumps over a trunk with radius R lying on the ground assuming the shape of a cylinder. What minimum velocity must it exert to land on the other side , clearing the trunk ?
displacement along x-axis = v2/g sin2x where x = angle of projection.
I assume that the circular cross section of the trunk cuts the parabolic trajectory at its highest point, but this gives me an equation for the y-component of the vector. How do I get the x-component equations ?
Hi Perpendicular! :smile:
Hint: what is the largest circle that will fit at the bottom of a parabola? :wink:
so that in that much time it just clears of a horizontal distance of 2R
the end and start points of the parabola have a distance 2R ? but the circle is in the middle of the parabola, isn't it ? that means the horizontal diametric distance along the circle can at best approach the parabola, and equal it when the whole diagram looks like a pulley system. but how is that the case ?
not sure what you mean. I've placed the circular tree trunk in the middle to maximize that, and as the flea needs to just jump over I'm assuming the parabola's peak point is at the circle's highest point too.
can you clarify what data is given,means if the angle of projection or something else.in what terms do you want v
v should be in terms of g and R.
but how wide does the parabola have to be?
>2R.
Answer given as 2.197 x Sqrt(gR). Not exactly root of 17/4...what was your method, though ?
that answer is wrong.sorry,but at my best i can find 2.236√gR WHICH IS IN FACT √5gR which I have gotten using the vertical eqn you are using.and for horizontal I have fitted a parabola
which passes through the topmost point and for any given vertical distance the difference in value of horizontal (x) for parabola and the circle is minimum parabola lying always outside the circle.the answer seems to imply that your vertical eqn does not hold perhaps in some way getting a compromise in horizontal and vertical will give a minimum velocity which is somewhat smaller than I am getting when I am using your answer the parabola goes inside of cylinder.moreover can you give me reference for the problem and i hope tim will have some way out of it.
say you have the parabola y = x2
obviously a tiny circle will easily fit in the bottom (at the origin), but a large circle won't …
so what is the largest circle that will fit? :smile:​
the problem is from a NSEP paper...national standard exam in physics in India.
anyway nevermind, turns out there is a solution online :
http://scitation.aip.org/journals/doc/PHTEAH-home/challenges/nov2010.pdf
all right,I was thinking that through as I have written there that there will be a compromise between vertical and horizontal motion.your vertical direction assumption was wrong.nevertheless that was a good one.
