How does T rotate points in \mathbb{R}^2?
  • Thread starter Thread starter flyingpig
5 replies · 2K views
flyingpig
Find the standard matrix of T
[tex]T: \mathbb{R}^2 \to \mathbb{R}^2[/tex] rotates points (about the origin) through [tex]\frac{3 \pi}{2}[/tex] radians counterclockwise
I just substitute [tex]\frac{3 \pi}{2}[/tex] into the rotation matrix and I got [tex]\begin{bmatrix}<br /> 0 & 1 \\ <br /> -1 & 0 <br /> \end{bmatrix}[/tex]
The book got this answer too, but they did something weird
They did [tex]T(\vec{e_1}) = -\vec{e_1}[/tex] and [tex]T(\vec{e_2}) = \vec{e_1}[/tex]
I don't understand how they got [tex]T(\vec{e_1}) = -\vec{e_1}[/tex]
It looks like a typo. What did you find for [tex]T(\vec{e_1})[/tex]?
I meant [tex]T(\vec{e_1}) = -\vec{e_2}[/tex]
I'm confused whether that's what you obtained or what the book obtained. In either case, that's correct, since
[tex]\vec{e}_1 = \begin{pmatrix} 1 \\ 0 \end{pmatrix}, ~~ \vec{e}_2 = \begin{pmatrix} 0 \\ 1 \end{pmatrix}.[/tex]
You can explicitly rotate these by [tex]+3\pi/2[/tex] to find the action of [tex]T[/tex]. The matrix form can then be deduced straightforwardly.
[STRIKE]Incidentally, you should be using [tex]\theta = -3\pi/2[/tex], since it's a counterclockwise rotation. You got the signs correct somehow anyway, but if the angle were different, you'd have gotten the wrong answer.[/STRIKE]
Edit: Sorry, counterclockwise corresponds to a positive rotation, so ignore what I said here.
No That's what the book meant
I don't understand what they are doing. The way I did it is plug them into
[tex]\begin{bmatrix}<br /> cos\theta & -sin\theta \\ <br /> sin\theta & cos\theta <br /> \end{bmatrix}[/tex]
OK, it's easy if you draw a picture that I'll explain in words. [tex]\vec{e}_1[/tex] is the unit vector in the direction of the [tex]+x[/tex]-axis, while [tex]\vec{e}_2[/tex] is that for the [tex]+y[/tex]-axis. We put the bases of both vectors at the origin for convenience. Now, if we rotate [tex]\vec{e}_1[/tex] by [tex]3\pi/2[/tex] radians counterclockwise, that corresponds to [tex]270^\circ[/tex], which corresponds to the [tex]-y[/tex]-axis or [tex]-\vec{e}_2[/tex]. We can do the same thing for [tex]\vec{e}_2[/tex] to find [tex]T(\vec{e}_2)[/tex].
Now if you know the action of [tex]T[/tex] on the basis vectors, that's enough information to solve for all of the entries of the matrix by writing the system of equations
[tex]T(\vec{e}_i) = \sum_j T_{ij} \vec{e_j}.[/tex]
This is just a decomposition of whatever we compute for [tex]T(\vec{e}_i)[/tex] in terms of a linear combination of the basis vectors. The coefficients [tex]T_{ij}[/tex] are precisely the matrix elements of [tex]T[/tex]. Because we are using the Cartesian orthonormal basis for [tex]\mathbb{R}^2[/tex] this is the standard form.
