How Does Traveling at .9999c Affect Human Time Perception?
  • Context: Graduate
  • Thread starter Thread starter nuby
    Time
The discussion revolves around the effects of traveling at 0.9999c on human time perception, exploring both the theoretical implications of special relativity and the subjective experience of time for individuals moving at such high speeds. Participants consider the relationship between physical laws and mental perception, as well as the implications of time dilation on human experience.
  • Some participants assert that time perception in a moving frame would be the same as in a stationary frame, while others question how this is known.
  • One participant argues that time ticks at a constant rate, but perceptions differ based on speed, suggesting that while time may be perceived the same in one's own frame, it differs from the perspective of an observer.
  • Another participant cites experimental evidence, such as time dilation observed in particles and atomic clocks, to support claims about time dilation in special relativity (SR), but clarifies they are not questioning SR itself.
  • There is a discussion about whether human mental perception of time aligns with physical time dilation effects, with some suggesting that if the mind is viewed as a physical entity, it should be "in sync" with physical laws.
  • Participants explore hypothetical scenarios regarding how a traveler might perceive time differently, including the effects of relativistic length contraction on their experience.
  • Some participants express skepticism about the ability to measure personal experiences of time at relativistic speeds, likening it to philosophical discussions about the nature of existence and perception.
  • One participant emphasizes that all things are affected by relativity, questioning the ability to detect time dilation in everyday life.
  • Another participant argues that there is no objective frame of reference, suggesting that one could be considered to be traveling at relativistic speeds at all times, depending on the chosen frame of reference.
Participants express a range of views, with no clear consensus on how human time perception relates to the effects of traveling at relativistic speeds. Some agree on the principles of time dilation as described by SR, while others challenge the applicability of these principles to human experience.
Limitations in the discussion include the lack of empirical methods to measure subjective time perception at relativistic speeds and the dependence on philosophical interpretations of consciousness and physical laws.
nuby
Hello,
If a human could travel at .9999c would their perception of time (in their own frame) be the same as the perception of time of a stationary observer (in their frame)?
yes of course
That's what I thought, but how is this known?
Time ticks by at a constant rate. At different speeds, the perceptions of the two times would be different. But in their own frame of reference they would be the same. If this wasn't true, then the equations on relativity would be incorrect. Since the majority of scientists trust the data from all of the experiments done on relativity, I think that we can believe that time would tick by the same at any speed in reference to someone going at that speed.
I know this isn't quite what you're looking for, but unless we send something that can take readings while going 0.999c, then I think we'll just have to trust science.
...unless we send something that can take readings while going 0.999c...
We have ample data of such things.
Particles with a known decay rate, when accelerated to near light speed, show a time dilation (i.e. live longer) exactly in accordance with SR.
Extremely accurate atomic clocks flown on jetliners high in the atmo (where gravity is weaker) have shown a dilation of time exactly in accordance with SR.
GPS satellite data takes SR into account when measuring distances. If SR were wrong, the GPS data would be wrong.
I'm not questioning SR time dilation, though.
what are you then asking about? you asked how observers would notice time when traveling at high speeds...
How is it known the observers (or travelers) mental perception of time is "in sync" with all other time dilation effects?
the Mind is not a subject of physics, but if one has the view that the mind is just particles and forces described in principle by physical law, then it should be "in sync".
And let us just play here, HOW would he notice things different, if the mind was detached from the physics: if the observer moving was raising his arm, would he thinking "gosh, what a long time it takes to raise my arm" ??
I have no idea... Maybe their movement would seem restricted?
I was also curious if the travelers size would increase with velocity relative to the observer, and if that could change their perception of time as well.
Depending on what direction the traveler was going and relative to the observer, the traveler would get skinnier if he/she was going directly forward or backward, shorter if he/she were going up or down (relative to him/her), or a combination if in some other direction. However, the traveler wouldn't change in his/her reference point.
Also, the traveler would appear to be moving slowly (from the observer's reference). As to what that traveler would experience would be nothing more than if he/she weren't moving at all.
But whether you realize it or not, you're questioning the first postulate of relativity which says all laws of physics work the same in all inertial frames, and that along with the second postulate that light moves at c in all inertial frames is what all the predictions of relativity (including time dilation) are derived from. It's also possible to show that any law of physics will respect these postulates as long as its equations when expressed in one inertial frame have a mathematical property called "Lorentz invariance" (meaning the equation is unchanged under the Lorentz transformation which relates different SR frames), and if you look at all the most fundamental laws of physics with good experimental support that are known today, they do all have Lorentz-invariant equations.
Again, I'm talking about human time perception, and this probably isn't the appropriate place to discuss it unless SR talks about it specifically.
nuby said:
Again, I'm talking about human time perception, and this probably isn't the appropriate place to discuss it unless SR talks about that specifically.
Unless you think human time perception isn't based on events happening in the physical brain which obey the laws of physics, then the first postulate should apply to human time perception too.
Maybe if you gave an specific problem related to your question we can be more helpful?
ALL things are affected.
you need to realize that you are right this very moment undergoing time dilation due to relativity. Do you notice anything out of the ordinary?
Heh.. No, but I could argue that there's nothing to compare the feeling of my frames "time dilation" to... We've all pretty much evolved in it.
If there is no way to detect something then how can one say exists at all?
We're talkin' invisible, intangible, backyard elves here...
Right, I guess that's why someone mentioned this is more of philosophy discussion... How could you measure a personal experience traveling at .9999c?
No. Nonono.
You are traveling at .9999c right now.
The whole point of relativity is that it's relative. There is no experiment you can do that can say that you are not moving at .9999c right now. Your velocity is only relative to a point of reference of your choice. You might choose the Earth as your frame of refence, but there is no way you can claim that the Earth is not moving at relativistic velocities.
And it's not that you "can't tell" if you've moving; it's that there is no such thing as an objective frame of reference. It is all relative.
Well, how about with gravitational time dilation effects instead of velocity? If you could feel the gravity of 100 suns (and the "time" in that frame), would this be considered relative as well?
hell my mental perception of time is different traveling at 0.0000007C on Continental Airlines
Yes. The principle of equivalence.
If I put you in an elevator that was free-falling into a black hole, there is no experiment you could do, even in principle, to show that you were undergoing gravitational acceleration.
No Dave, since there are no observers, as we know, with human perception observing us when we move relative to them at very high speeds. It might happen, that the human mind live in another "space-time" (parallel universe) similar to the aether where to mind is not affected by the body moving with respect to the minds space-time :-)
This is not a physics question, it is not a question of time either, it is a question if and how the mind "live" in the physical reality and is hence a subject of philosophy. Everything we way about the mind will be circular in some sense, since the mind is saying something of the mind which is saying something of the mind etc..
to Nuby, the traveller will shrink in its direction of motion according to the observer.
The point of SR is that there are no special reference frame, according to the travaller, it is the observer who shrinks and have time running slower. Time is local.
Another question you could ask is if conservation of momentum would be measured by a very fast rotation observer (we neglected SR here) - you are asking if the effect of a symmetry generation is perceptible when the symmetry action itself is being turned on.
Philosophy is not just random idle thoughts vomited onto a keyboard. Philosophy is about facts and logic. And one cannot weasel out of a question that is most certainly scientific in nature by saying they are looking for a philosophical answer.
The question, as it is being presented, either has the simple, logical scientific and philosophical answer as already given or it is nothing but gibberish. A meaningless, pointless question with no answer at all because it isn't based in reality.
Oop, better lock this thread, people are starting to get nasty...
So logically, the mind COULD exists in another "frame" as I pointed out earlier..
But assuming this form of mind existed in a parallel universe of sorts (not just another 'frame' in the sense of a coordinate system on the same spacetime), unless it was totally passive and had no effects on behavior (like a person's speech about their own time perception), then if it would result in observers in different inertial frames consistently reporting different things about their time perception, then the new parallel universes you bring up would be interacting with normal spacetime in a way that violates the first postulate of SR.
yes, but does this extra parallel universe have to obey the postulates of SR?
Note: I am not serious when I write these things, I just want the discussion for the sake of the original post.
But I would interpret the first postulate to apply to all laws which concern events in our spacetime--the fact that these laws may also involve stuff outside of our spacetime doesn't change the fact (IMO) that it's a violation of the first postulate if an inertial observer can do an experiment in a windowless room that will give different results depending on what frame he's at rest in.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 125 ·
9K
  • · Replies 29 ·
