How Fast Are the Train and Automobile Separating After 2 Seconds?
11 replies · 4K views · last reply
louloulou
An elevated train on a track 30.0 m above the ground crosses a street (which is at right angles to the track) at the rate of 20.0 m/s. At that instant, an automobile, approaching at the rate of 30.0 m/s, is 40.0 m from a point directly beneath the track.
Find how fast the train and the automobile are separating 2.00 seconds later.
No equation was given.
[tex]dz/dt = 20 m/s[/tex]
[tex]dx/dt = 30 m/s[/tex]
[tex]h^2 = x^2 + y^2 + z^2[/tex]
[tex]h^2 = 40^2 + 30^2 + 20^2[/tex]
[tex]h^2 = 54 dh/dt[/tex]
[tex]h^2 = x^2 + 30^2 + z^2[/tex]
[tex]2h(dh/dt) = 2x(dx/dt) + 0 + 2z(dz/dt)[/tex]
[tex]2(54) dh/dt = 2(40) dx/dt + 0 + 2(20) dz/dt[/tex]
[tex]108 dh/dt = 80 dx/dt + 40 dz/dt[/tex]
*don't know what to do next*
Am I doing this right so far? Any suggestions are really appreciated, thanks a lot!
it's not 3 variables, you only have x/y, say.. x = the train going to the right, y = the car moving up
but your equation's right, also differentiate w/respect to t, you'll have to use the chain rule.
Write out (x,y,z) for each vehicle explicitly as a function of t. Use that to write h explicitly as a function of t.
I'm sorry, I don't quite understand. What do I need to change? Is the [tex]54 dh/dt[/tex] not correct (Should it just be [tex]30^2 + 20^2[/tex] ?)
it's
[tex]h^2 = x^2 + y^2[/tex]
Ok well that gives you 2 variables. I'm going to assume x is the train's direction, z is the car's direction.
[tex]2(54) dh/dt = 2(40) dx/dt + 0 + 2(20) dz/dt[/tex] is wrong, you're given the locations (30m, 40m) but you're asked for 2.0 s later, so you need to add the distance that they traveled in those seconds, so the speeds *2.0 + location and you plug that in for the x,z,h. And what is dx/dt? dh/dt? dz/dt?
it's
So...
[tex]h^2 = 30^2 + 20^2[/tex]
[tex]h = 36.1 dh/dt[/tex]
and then...
[tex]2h(dh/dt) = 2x(dx/dt) + 2y(dy/dt)[/tex]
I'm getting confused as to what the x and y is now..still 40(x) & 20(y)?
Ugh, I don't know! :confused:
no you need to plug-in 2h, 2x, 2y, what's h,x,y? after 2.0 Seconds, you're given the initial location and the speed they travel so you can find how far they've traveled in 2.0 s and add that to the initial location
Okay, well thanks for all your help i'll give that a try and post it again.
I know this is wrong...i'm getting 1.38 m/s later.
Can you please tell me your answer so I can at least compare with mine?
I got something like, the train/car are separating at a rate of 36.0 m/s.
Can you show your work? maybe you're write and I did some algebra mistake...
Suppose the car is going in the +y direction and the train in the +x and the (x,y) paths cross at (0,0). The position of the car is (0,-40+30*t,0). That's the hard one, can you do the train? So then what's h(t)? You seem to just be getting confused about what are x,y,z.
I'm not sure when I should be plugging in the "2.00 s"
Anyway, this is what I did.
[tex]2 (31.6) dh/dt = 2(30) + 2 (20)[/tex]
[tex]dh/dt = 1.38[/tex]
But something is not right because I still need to do something with the 2.00 seconds:rolleyes:
