How to Modify a Finite Difference Method Code for a Non-Zero Boundary Condition?
  • Thread starter Thread starter fahad20
7 replies · 3K views
fahad20
hello...i m trying to solve this ordinary differential equation problem..but it is giving errors..pleasezz help
problem: d^2 T/Dr^2 + (1/r) DT/Dr=1+ (r/R)^2
T'(0)=0 and T(R)=0
solve this problem for T(r),where R=1.0
SOLUTION I HAVE CUM UP WITH:
put R=1 in this equation...
now let v=T'
T''=V'
so
DT/Dr=v
Dv/dr=1+(T**2/V**2)-(V**2/T)
V(0)=0 and T(R)=0
and now here's the code...
dimension p(100,4),r(100),xn(100),xt(100)
write(*,10)
10 format(1x,'input number of equation:')
read(*,*)N
write(*,12)
12 format(1x,'enter the initial value of the independent variable:')
read(*,*)T
write(*,14)
14 format(1x,'enter the increment of the independent variable:')
read(*,*)dt
write(*,16)
16 format(1x,'enter the ending value of the independent variable:')
read(*,*)tend
write(*,18)
18 format(1x,'enter the initial value of the dependent variables:')
do 20 i=1,n
20 read(*,*)r(i)
write(*,22)
22 format(9x,'t',5x,'r(1) through r(n)')
write(*,24) T,(r(i),i=1,n)
24 format(f10.3,5e14.5)
26 call rkn(x,n,dt,t,p,xt,xn)
t=t+dt
do 30 i=1,n
30 r(i)=xn(i)
write(*,24)t,(r(i),i=1,n)
if (t.ge.tend) goto 50
goto 26
50 write(*,52)
52 format(1x,'r-k parameters are:')
do 54 i=1,n
54 write(*,56) (p(i,j),j=1,4)
56 format(4e15.5)
end
function f(r,t,i,n)
dimension r(n)
goto (10,20),i
10 f=r(1)
return
20 f=1+(r(2)**2/r(1)**2)-(r(1)**2/r(2))
return
end
subroutine rkn(xin,n,dt,t,p,xt,xout)
! solving n first-order ode d(xin)/dt=f(xin,t)
!knowing xin at t,this sub.finds xout at t+dt
!p are the runge-kutta 4th-order parameters
dimension p(n,4),xin(n),xout(n),xt(n)
do 5 i=1,n
5 p(i,1)=dt*f(xin,t,i,n)
do 15 j=2,3
do 10 i=1,n
10 xt(i)=xin(i)+p(i,j-1)/2.
do 15 i=1,n
15 p(i,j)=dt*f(xt,t+dt/2.,i,n)
do 20 i=1,n
20 xt(i)=xin(i)+p(i,3)
do 25 i=1,n
p(i,4)=dt*f(xt,t+dt,i,n)
25 xout(i)=xin(i)+(p(i,1)+2.*(p(i,2)+p(i,3))+p(i,4))/6.
return
end
but it is giving eror..please correct this..thank u
You made several errors, I have bolded them for your below.
fahad20 said:
hello...i m[/b trying to solve this ordinary differential equation problem..but it is giving errors..pleasezz help
T'(0)=0 and T(R)=0solve this problem for T(r),where R=1.0
now let v=T'
T''=V'
so
DT/Dr=v
V(0)=0 and T(R)=0
and now heres the code...
...but it is giving eror..please correct this..thank u
I didn't bother checking sentence structure or punctuation. If you'd like, I can correct those for you as well.
What kind of errors?
If the program doesn't even compile, what error messages does the compiler give you?
If the program compiles but doesn't run correctly, show us
(a) some sample input
(b) the output that the program should produce
(c) the output that the program actually produces
fahad20 said:
solve for T(r)
T'(0)=0 and T(R)=0
now let v=T'
T''=V'
so
DT/Dr=v
V(0)=0 and T(R)=0
write(*,10)
read(*,*)N
write(*,12)
read(*,*)T
write(*,14)
read(*,*)dt
write(*,16)
read(*,*)tend
write(*,18)
do 20 i=1,n
20 read(*,*)r(i)
write(*,22)
t=t+dt
do 30 i=1,n
30 r(i)=xn(i)
goto 26
50 write(*,52)
do 54 i=1,n
56 format(4e15.5)
end
function f(r,t,i,n)
dimension r(n)
goto (10,20),i
10 f=r(1)
return
return
end
do 5 i=1,n
do 15 j=2,3
do 10 i=1,n
do 15 i=1,n
do 20 i=1,n
do 25 i=1,n
return
end
You have several do loops that don't have continue statements. The loops should look something like this:
Code:
do 10 i = 1, n
     sum = sum + i
     write(*,*) 'i =', i
     write(*,*) 'sum =', sum
10  continue
Your code is very hard to read with statement labels on input and output statements that you probably don't need, and with gotos here and there.
i have this code for a 2nd ODE..but with boundary conditions.
this code is for ..
d^2 Z/dR^2 + (1/Z) dZ/dR=-p/T
Z(Ri)=0 and Z(Ro)=0
this is a finite difference method code in fortran..
please c...
!Fortran Version
! Program OdeBcpFD – Ordinary differential equation, boundary-value Problem
! Solved by finite-difference method . UP to 99 stations.
DIMENSION X(99),C(99,99),R(99)
WRITE (*,2)
2 FORMAT(1X,' Program OdeBvpFD finite difference solution of O.D.E. Boundary-Value Problem.'/)
Write (*,4)
4 Format(1X,'have you Edited The functions CIJ And RI for generating the elements of [C] and {R} in [C] {Y}={R}?')
READ (*,*) I1
Write (*,6)
6 format(1x,'enter the number of (in-between,excluding boundaries)stations and stepsize:')
read(*,*)n,dx
write(*,8)
8 Format (1X,'Enter the First (left Boundary) X Value :' )
READ (*,*) X1
! Calculate [C] and {R}
Do 10 I=1,N
X (I) =X1+I*DX
R (I) =RI(x(i),dx)
DO 10 J=1,N
10 c(i,j)=cij(x(i),i,j,dx)
CALL GAUSS (C,N,99,R)
! {Y} is in {R}.
WRITE (*,12) (R(k),K=1,N)
12 Format(1x,'The Solution is : '//5(5E16.5/))
STOP
END
Function RI (X,DX)
RI=-5*DX **2 /100.
Return
End
FUNCTION CIJ (X,I,J,DX)
CIJ=100.
IF (I.EQ.j) CIJ=-2.
IF (I.EQ.(j-1)) CIJ=1.-DX/2./X
IF (I.EQ.(J+1) ) CIJ = 1.+DX/2./X
RETURN
END
SUBROUTINE GAUSS ( C , N, M, R)
!SOLVES MATRIX EQUATION C(N,N) *X(N)=R(N) BY GAUSSIAN ELIMINATION.
!X and V share same storage. C is dimensioned (M,M) in the calling program.
DIMENSION C(M,M),r(N)
N1=N-1
DO 25 K=1,N1
KP1=K+1
!NORMALIZATION
DO 10 J=KP1,N
10 C(K,J)=C(K,J)/C(K,K)
r(K)=r(K)/C(K,K)
!ELIMINATION
DO 25 I=KP1,N
DO 20 J=KP1,N
20 C(I,J)=C(I,J)-C(I,K)*C(K,J)
25 r(I)=r(I)-C(I,K)*r(K)
!BACKWARD SUBSTITUTION
r(N)=r(N)/C(N,N)
DO 35 I=1 ,N1
IR=N-I
IR1=IR+1
DO 35 J=IR1,N
35 r(IR)=r(IR)-C(IR,J)*r(J)
RETURN
END
now i have this problem...
d^2 T/dr^2 + (1/r) dT/dr=0
and B.C's are T(1)100 and T(2)=0
how will this code change..especially ..how to cater for these two B.Cs with r non-zero...
thank u ..
Is this a programming course? Are you required to use that program?
If, after taking v= T', you multiply the original equation, [itex]v'+ v/r= 1+ r^2[/itex] by r, you get [itex]rv'+ v= (rv)'= r+ r^3[/itex] and can solve for v just by integrating both sides:
[itex]rv= (1/2)r^2+ (1/4)r^4+ C[/itex] so that [itex]v= T'= (1/2)r+ (1/4)r^3+ C/r[/itex] and T can be found by integrating again.
please tryy to understnd...
the code i have is for ..
Z(Ri)=0 and Z(Ro)=0
(both B.C's are ZERO)
in which the B.C's are not zero... ----> T(1)100 and T(2)=0
i.e ar r=1,T=100 and at r=2,T=0
how will this code change for above problem..
