How to Prove a Sequence by Induction
The discussion revolves around proving a sequence defined recursively, where the sequence is given by a1 = 3, a2 = 6, and an = 5an-1 - 6an-2 + 2 for n ≥ 3. Participants are tasked with proving a closed form for the sequence, specifically that an = 1 + 2n-1 + 3n-1.
  • Participants attempt to establish a base case for n=1 and n=2, and then assume the statement holds for k > n. There are discussions about the validity of certain algebraic manipulations and the correctness of expressions derived from the recursive definition.
Some participants have provided examples of similar problems that may offer insight into the current problem. Others have pointed out potential errors in the algebraic steps taken. The discussion remains open, with participants seeking clarification and further guidance on their approaches.
There is an indication that participants are grappling with the algebraic manipulation of terms involving powers, and some express uncertainty about their current progress. The original poster has requested further assistance after encountering difficulties.
silina01
Define the sequence of integers a1, a2, a3,... as follows:
a1 = 3
a2 = 6
an = 5an-1 - 6an-2 + 2 for all n ≥ 3
Prove that an = 1 + 2n-1 + 3n-1
my attempt:
base case:
n=1
1+ 20 +30
= 1
= a1
therefore n=1 holds
n=2
1+ 21 +31
= 6
= a2
therefore n=2 holds
Assume k holds for all k > n, n≥3 then
= 5(1+2n-2 + 3n-2) -6(1 + 2n-3+ 3n-3) +2
= 1 + 10n-2 + 15n-2 -12n-3 -18n-3
I have no idea what to do from here.
= 1 + 10n-2 + 15n-2 - 12n-3[/color] - 18n-3
5 \cdot 2^{n-2} \ne 10^{n-2}
5 \cdot 3^{n-2} \ne 15^{n-2}
...and so on.
I don't know if this will help, but note that
2^{n-2} = 2\cdot 2^{n-3}
and
3^{n-2} = 3\cdot 3^{n-3}
Your second line is incorrect.
a\cdot b^n = a^1b^n \neq (ab)^n = a^nb^n
okay, but I am still stuck
Best I can do is give you some other examples that use the properties that you may need to continue:
4(2+5^{n-3}) = 8 + 4 \cdot 5^{n-3}
-7 \cdot 4^{n-1} = -7 \cdot 4 \cdot 4^{n-2} = -28 \cdot 4^{n-2}
12 \cdot 10^{n-5} - 4 \cdot 10^{n-5} = 8 \cdot 10^{n-5}
Study the above and try your problem again.
(Mods: hope I am not giving too much away here.)
Please post your corrected working, as far as it goes. (Maybe you still have a wrong equation.)
I found the answer, thank you all so much!
  • · Replies 19 ·
