Mentor
- Messages
- 37,458
- Reaction score
- 16,576
My previous response was a little rushed and therefore incomplete. Let me expand a bit on why it is an utterly silly objection.xinhangshen said:The problem is that you do not have a clock to measure the speed u' because the time is defined by the clock.
Suppose you had a pendulum clock and nothing else. And suppose that you thought that your pendulum was calibrated for 1s per tick, but your pendulum length was a different length, so it was actually measuring a different amount of time. Then, as long as that is the only thing in the universe then you will never know that it is keeping the wrong time. Just like with the y-axis clock.
Now, suppose that you want to use your pendulum clock to measure decay rates or calculate accelerations and forces or even bake bread. You will find that your measured half life is off, the accelerations and forces are different than what you expected, and the bread is burnt. Just like with the y-axis clock.
From that evidence you will be able to tell that your pendulum clock doesn't keep correct time. It will be physically discernable that the laws of physics are not correctly described with your clock. Just like with the y-axis clock.
So the idea that you could be tricked into thinking that your pendulum clock because there is no other reference to compare it to requires that you not use your clock for ANYTHING, because anything that you do will let you know that it is miscalibrated. You can't even just sit there and watch it tick because of all of the biological processes involved in watching and living that it will get wrong. Just like with the y-axis clock.
So, your objection is absurd because (a) it applies to any clock (b) it relies on an absurd level of ignorance. A clock for which that objection would stand would necessarily be so disconnected from the rest of the universe that you can simply ignore anything about it.
