How to Solve a Linear ODE BV Problem with Boundary Values?
  • Thread starter Thread starter mistereko
    Linear Ode
18 replies · 3K views
mistereko
I nearly have this problem solved
x2d2y/dx2 + 3x*dy/dx + 5y = 8x
y(1) = 2, y(exp(pi/4)) = 2sinh(pi/4)
I've found the general solution, but I'm not sure how to get the answer with the boundary values
My general solution is y(t) = C1 e-t cos(2t) + c2 e-t sin(-2t) + 2t
I understand how to use BV's it just I'm getting weird answers
C1 - C2 = 6
C1 - C2 = 2sinh(pi/4) - 8epi/4
It looks like you did a change of dependent variable like x=e^t to get a solution like that, right? And I'm not sure I agree with the ' + 2t' part. The initial conditions they are giving you are initial conditions for x, not for t. What values of t correspond to x=1 and x=exp(pi/4)?
Yes, I used e^t. I'll try and work out new boundary values. I think you're right about the 2t part. Thanks
t = 0 and t = pi/4.
mistereko said:
t = 0 and t = pi/4.
Sure, now if you correct the '+ 2t' part to the correct expression you actually should be able to work out nice values for C1 and C2. Remember what the definition of sinh is.
My general solution is y(t) = C1 e-t cos(2t) + c2 e-t sin(-2t) + e^t, but I don't know how to chnage the boundary values from x to t. Having a slow moment.
can anyone verify that the final solution is y(t) = (cos(pi/2) + 2 + exp(pi/2)) e-t sin(2t) + e-t cos(2t) + e^t please?
Show how you got that.
2 = c1*e^0*sin(0) + c2*e^0*cos(0) + e^0
that works out nicely to
C2 = 1
For C1 it's a bit messier. I let 2Sinh(pi/4) = (e^(pi/2) -1)/ e^(pi/4)
Therefore
(e^(pi/2) -1)/ e^(pi/4) = C1*exp(-pi/4)*sin(pi/2) + exp(-pi/4)*cos(pi/2) + exp(-pi/4)
multiplied by exp(pi/4)
and found c1 to be Cos(pi/2) + 2 -exp(-pi/2)
No need, I just realized a huge mistake I made and figure it out. Thanks anyway :)
I'm taking it on trust you've got the right general solution there. But if so, shouldn't the last term be exp(pi/4) instead of exp(-pi/4)?
Final solution is e^(-pi/4)*e^(-t)sin(2t) +e^(-t)cos2t + e^t
Apparently it has been a long night. I just get C1=1 and C2=(-1), though you have been switching C1 and C2 around. And it might be good to express your final answer in terms of x rather than t.
Just looked at it with fresh eyes.
y(x) = 1/x * cos(2ln(x)) - 1/x * sin(2ln(x)) + x
Looks ok. You can always try substituting into the original ODE if you've got any doubts.
