How to write a proof: from (A + B) = C to (A - B) = (C - 2B)
751 replies · 91K views · last reply
reenmachine said:
In the second one , does it mean that each ordered pair would look like [all real numbers , 1]?
I don't see what that would mean. The union in parentheses is equal to ##\mathbb R##, so the set is
$$\mathbb R\times [1,0] =\{(x,y)\in \mathbb R\times \mathbb R:0\leq y\leq 1\}.$$
$$\mathbb R\times [1,0] =\{(x,y)\in X\times Y:0\leq y\leq 1\}.$$
I know what you mean , but wasn't aware it was possible to say ##(x,y)\in X\times Y##.This doesn't give any indication of what X is.
So is this version correct?
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an element ##x \in R## and an element ##y \in [0,1]##.The notation of the set implies that ##z = (x,y)##.Since ##y \in [0,1]## and ##x \in R## , that the union of all elements of ##R = R## , this implies that ##z \in \bigcup_{a \in R}\{a\} × [0,1]##.
thanks!
Sorry, I don't know why I typed X and Y. I meant ##(x,y)\in\mathbb R\times\mathbb R##. But even if we do, what we get is just a more complicated way of saying ##\mathbb R\times[0,1]##.
reenmachine said:
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an element ##x \in R## and an element ##y \in [0,1]##. The notation of the set implies that ##z = (x,y)##
The second sentence tells us nothing other than that ##\mathbb R\times[0,1]## is non-empty. The statement ##z \in\mathbb R × [0,1]## doesn't say anything about x or y.
Let ##z \in R × [0,1]## be abitrary.This implies that z is an element of the form (a,b).For all ##x\in R## and ##0≤y≤1## , ##z=(x,y)## and ##(x,y) \in R × [0,1]##.Since ##x \in R## , it implies that ##x \in \bigcup_{a\in R}\{a\}## and since ##0≤y≤1## , it implies that ##y\in[1,0]##.Since ##z=(x,y)## for all x and y , it implies that ##z \in \bigcup_{a\in R}\{a\} × [0,1]##.hmmm , I'm not sure at all about that one , it is pretty hard to connect the dots for some reasons.
This is true, but after this you never mentioned a and b again.
Here you're saying that z is equal to infinitely many things.
It is pretty difficult to do these proofs until you get used to them. One tip is to leave the proof for a while, and then read what you have written. If you don't understand your own argument then, no one else will either.
Ok , I'm going to take a dinner break and try to come up with something after.
thanks man!
If I were to say that a is in R and b is in [0,1] , would that make sense or would it be irrelevant because a and b are dummy variables?
I'm not sure I understand this , doesn't it say that z=(x,y) and that those x and y are the x in R and y in [0,1] I was talking about?
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an ##x \in R## and a ##y \in [0,1]## such that ##z \in (x,y)##.This implies that ##x \in \bigcup_{a\in R}\{a\}## and that ##y \in [0,1]## such that ##(x,y) \in \bigcup_{a \in R}\{a\} × [0,1]##.Since ##z \in (x,y)## , this proves that ##z \in \bigcup_{a \in R}\{a\} × [0,1]##
Here I have a feeling I'm missing something between ##z \in (x,y)## and the conclusion , but I just can't find it.
edit:ok I am done editing
I would interpret your statement as "there exists a,b such that z=(a,b)", so both variables are the target of a "there exists", and strictly speaking, that makes them dummy variables, and a reference to a or b in the next sentence doesn't make sense. However, since of the abuse of language I described earlier is so common, I would have interpreted a reference to a or b in the next sentence as if you had made two separate statements: "There exists c,d such that z=(c,d)" and "Let a and b be such that z=(a,b)".
It makes sense to change "This implies that z is an element of the form (a,b)" to "This implies that z is an element of the form (a,b) with ##a\in\mathbb R## and ##b\in[0,1]##", and I consider this an improvement. But what's really missing from your statement is something that makes it clear that you are assigning values to the variables a and b. (So that it makes sense to refer to them later).
You could e.g. say "define ##a\in\mathbb R## and ##b\in[0,1]## by ##z=(a,b)##" or "let a,b be the unique real numbers such that z=(a,b)"
You said that for all real numbers x,y with y in [0,1], we have z=(x,y). This implies that all of the following equalities and infinitely many more are all true: ##(1,0)=z,\ (-1/12,0)=z,\ (\pi,1/2)=z##...and they all contradict each other.
The last ##\in## should be an equality, but I assume that was just a typo (hmm...repeated at the end of the proof). The statement is fine apart from that. You could say that there's a unique ##x\in\mathbb R## and a unique ##y\in[0,1]## such that z=(x,y) if you want to emphasize that the values of x and y are fully determined by z, but it's not necessary to do that in this proof.
The "such that" makes the sentence weird. You can end the sentence after ##y\in[0,1]##, and then say "this implies that...". But you don't actually have to mention that ##y\in[0,1]##, since you did that earlier.
It looks like what you're trying to do here is what I would say like this: Since ##\mathbb R=\bigcup_{a\in R}\{a\}##, this implies that we have ##z=(x,y)\in\left(\bigcup_{a\in R}\{a\}\right)\times[0,1]##.
But this right-hand side isn't the one we're interested in. We want to prove that ##z\in \bigcup_{a\in R}\left(\{a\}\times[0,1]\right)##.
I meant z = (x,y) , both times.Sorry about that.Also not sure if you saw the edited version.
Yes this is pretty much what I tried to do.Seems I confused everything again.
In that case , it should be easier to prove in the sense you only have to prove that ##z=(x,y)## and that ##(x,y) \in {a} × [0,1]##
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an ##x \in R## and a ##y \in [0,1]## such that ##z = (x,y)##.This implies that ##(x,y) \in \bigcup_{a \in R}\{a\} × [0,1]## which implies that ##z \in \bigcup_{a \in R}\{a\} × [0,1]##.
Is this sufficient? The truth is it looks like much of the same of what I previously attempted.I'm hitting a wall.
OK, I'll tell you.
All you need to say after that is that
$$z=(x,y)\in\{x\}\times[0,1]\subseteq\bigcup_{a\in\mathbb R}\{a\}\times[0,1].$$
Fredrik said:
OK, I'll tell you.All you need to say after that is that
$$z=(x,y)\in\{x\}\times[0,1]\subseteq\bigcup_{a\in\mathbb R}\{a\}\in[0,1].$$
$$z=(x,y)\in\{x\}\times[0,1]\subseteq\bigcup_{a\in\mathbb R}\{a\} ×[0,1]?$$
× instead of ##\in## at the end no?
Okay so I had to go through the ##(x,y) \in \{x\} × [0,1] \subseteq\bigcup_{a\in\mathbb R}\{a\} ×[0,1] ...##.
But why is it necessary to say that ##(x,y) \in \{x\} × [0,1]## , isn't implied in ##(x,y) \in R × [0,1]## when it was already said that ##z=(x,y)## and that ##z \in R × [0,1]## ?
I guess my next move is to sleep on it and see what happens tomorrow :smile:
This has been one of my roughest day in this thread.
Yes. (I have edited that now).
Actually, what you said in #560 is fine. I just think it's clearer with the extra step. I mean, it follows immediately from the definition of ##\times## that ##(x,y)\in\{x\}\times[0,1]##, and now the definition of "union" implies that ##(x,y)\in\bigcup_{a\in\mathbb R}\left(\{a\}\times[0,1]\right)##.
Fredrik said:
Yes. (I have edited that now).Actually, what you said in #560 is fine. I just think it's clearer with the extra step. I mean, it follows immediately from the definition of ##\times## that ##(x,y)\in\{x\}\times[0,1]##, and now the definition of "union" implies that ##(x,y)\in\bigcup_{a\in\mathbb R}\left(\{a\}\times[0,1]\right)##.
This was the problem , I wasn't sure what was missing.I would lie if I told you I'm 100% confidant in my understanding of everything we've discussed today.But I'll get there eventually.
Not sure that it was the easiest exemple to try either.
thank you infinitely for the patience!
By the way , it's been a month now since this thread has been created!
I am extremely satisfied with the help I've received.This has been an incredibly positive experience for me to the point where I deeply regret not doing it years ago.
Learning some completely unknown mathematics has been tough and remains tough , especially with my poor background , but I'm impressed by the quality of the helpers helping me getting through these concepts despite my lack of knowledge.
A special thank to you Fredrik , who has been the most active helper all along , you truly deserve to be called a mentor! I think I should also name micromass who has been extremely helpful to me.
thank you very much to everybody who helped me in the thread!
When we said ##(x,y)\in\{x\}\times[0,1]## yesterday , what does ##\{x\}## truly mean here? I know it's suppose to be any real number , but what difference does it make to put an ##x## out there instead of ##R## or ##a## like in the union notation? Is it because we want to pinpoint that ##x## is there as ##\{x\}## confirming both the position of ##x## and the position of ##y## in the formula ? Isn't ##(x,y)## enough? I'm trying to understand the importance of this statement.Is it because we want to pass through ##\{x\} × [0,1]## to reach ##\subseteq\bigcup_{a\in\mathbb R}\{a\} ×[0,1]##? If so , why is that crucial? Why not ##\{a\}## instead of ##\{x\}##?
Fredrik said:
I would interpret the notation on the right here as
$$\bigcup_{a\in \mathbb{R}} \left(\{a\}\times [0,1]\right),$$ not as
$$\left(\bigcup_{a\in \mathbb{R}} \{a\}\right)\times [0,1].$$ The notation is kind of ambiguous though. I don't know if one of these interpretations are "standard". I'm also not sure how you're interpreting it.
I think this was the most problematic aspect of how I handled the whole thing yesterday.
I think I even confused which notations I was trying to prove in the middle of my whole thought process.Here we want to prove the first one correct?
So by saying that ##(x,y)\in\{x\}\times[0,1]## , we're saying that ##z \in (G)## and that ##z \in \bigcup (G)## if ##z = (x,y)## and ##(G)=\{\{x\}×[0,1]\}##.Is that a correct way of viewing things? Because in my mind , if that's correct , it's much clearer now than yesterday.
A very simple thing seems to confuse me at this very moment , what's the difference between a set ##A## and ##\bigcup A##?
Suppose ##A=\{ (0,1) , (1,2)\}##.
The reason I'm asking is I'm not sure of the difference between
and
##\{a\} × [0,1]## with ##a \in R##
x and y are the unique real numbers such that z=(x,y). {x} is the singleton set with x as its only element. I'm not sure where you would like to put an ##a## instead of ##x##.
We want to prove that every element of ##\mathbb R\times [0,1]## is an element of ##\bigcup_{a\in\mathbb R}\left(\{a\}\times[0,1]\right)##. So we start by saying "Let ##z\in\mathbb R\times[0,1]## be arbitrary", and set out to prove that z is an element of the set on the right-hand side.
We define x and y by z=(x,y). Since ##z\in\mathbb R\times[0,1]##, this ensures that ##x\in\mathbb R## and ##y\in[0,1]##. The three statements ##z=(x,y)##, ##x\in\mathbb R## and ##y\in[0,1]##, together imply that ##z\in\{x\}\times[0,1]##. Since ##x\in\mathbb R## and ##y\in[0,1]##, this result implies that ##z\in\bigcup_{a\in\mathbb R}\left(\{a\}\times[0,1]\right)##.
Another way of saying that last bit: Since x is a real number and z is an element of ##\{x\}\times[0,1]##, z is an element of one of the infinitely many sets ##\{a\}\times[0,1]## with ##a\in\mathbb R##, and by definition of "union", that implies that z is an element of the union of those sets.
You're making it complicated by choosing a set with ordered pairs as elements, but maybe you meant { when you wrote (? I will consider the example with { instead.
If ##A=\{\{0,1\},\{1,2\}\}##, then ##\bigcup A=\{0,1\}\cup\{1,2\}=\{0,1,2\}##.
Okay , but what if ##A = \{1,2\}##? Is it the same set?
Everything in mathematics is a set, so ##(0,1)## and ##(1,2)## are sets. So ##(0,1)\cup (1,2)## makes sense. So the answer is
[tex]\bigcup A = (0,1)\cup (1,2)[/tex]
However, while it does make sense, it is something you never really want to do. If you ever encounter a situation where you would have to evaluate ##(0,1)\cup (1,2)##, then you made a mistake somewhere.
That said, I absolutely hate the notation ##\bigcup##. I think it's a very bad notation. But it's used quite a lot.
In that case, you have
[tex]\bigcup A = 1\cup 2[/tex]
Again, this makes perfect sense since ##1## and ##2## are sets. But it is not something you ever want to do.
$$\bigcup A = 1\cup 2$$
So if ##1=\{u,y\}## and ##2=\{z,x\}## , then
$$\bigcup A = 1\cup 2 = \{u,y,z,x\} ?$$
Basically it's just not good to reach the level where you can't split sets into elements.
