Identify these surfaces- quick vector question
8 replies · 3K views · last reply
Lucy Yeats
Identify the following surfaces:
i) r.u=L
ii) r.u=mlrl for -1[itex]\leq[/itex]m[itex]\leq[/itex]1
where k, L, m are fixed scalars and u is a fixed unit vector.
The first one is in the same form as the equation of a plane, but u is not necessarily the normal, so I'm confused. For the second one, I have no idea.
Hi Lucy Yeats! :smile:
Lucy Yeats said:
Is part i just an ordinary plane?
Yes.
r.u is the distance of point r to the surface perpendicular to u through the origin.
With r.u=L you get all points with distance L to this surface, which is again a surface.
As for part ii, you would get all points with distance m|r| to the plane normal to u and through the origin.
Let's start with m=0. What is it?
Now m=1: can you say in words which points you get?
Since m is a fixed scalar, I don't think it changes. However, the modulus of r is increasing with distance from the origin. So do you get a kind of 3d parabola/ bowl shaped surface??
Ah, you're ahead of me (but no, it is not a bowl :wink:).
With m=0, you'd get r.u=0 which is a plane through the origin.
With m=1, you'd get all points r with a distance to the plane that is equal to the distance of r to the origin.
Which points would that be?
All the points halfway between the origin and the surface?
No. The surface we're talking about contains the origin.
So there's no such thing as halfway.
Perhaps you can make a drawing in 2 dimensions.
Instead of a plane we'll have a line, but the principle remains the same.
Let u=(0,1).
What is the "plane" in this example?
Can you find a point that has an equal distance to the origin as to the line representing the "plane"?
How do you get r˙uusing the length of the vectors and the angle they enclose? Try to use this formula.
ehild
