If Earth's orbital speed doubled, would its mass and gravity double?
The discussion centers on the implications of doubling Earth's orbital speed, specifically regarding changes in its mass and gravitational pull. Participants explore concepts from relativity, gravitational force, and the nature of mass, with a focus on theoretical and conceptual understanding rather than practical outcomes.
  • Some participants assert that as an object approaches the speed of light, its relativistic mass increases and size decreases, referencing E=mc² and Lorentz contraction.
  • Others argue that the concept of relativistic mass is outdated and that the effects of Earth's speed on its mass and gravity would be negligible unless approaching relativistic speeds.
  • One participant suggests that if Earth's speed doubled, its mass and gravitational pull would also double, questioning the proportionality of these changes.
  • Another participant counters that to achieve a doubling of mass, Earth would need to reach speeds much closer to the speed of light, approximately 90% of it.
  • There is a discussion about the distinction between gravitational force and mass, with some clarifying that gravitational acceleration (g) is a measure of acceleration due to gravity, not mass.
  • Some participants note that even if Earth's speed doubled, it would not result in significant changes to its gravitational effects, and any increase in relativistic mass would not equate to an increase in gravity.
  • Clarifications are made regarding the use of "g" to denote both grams and g-force, with some participants asserting that the statements about g-force are accurate.
Participants express multiple competing views regarding the relationship between speed, mass, and gravity, with no consensus reached on whether doubling Earth's speed would lead to a proportional increase in mass or gravitational pull.
Participants highlight limitations in understanding relativistic effects at non-relativistic speeds and the need for precision in discussing gravitational concepts. The discussion also reflects varying interpretations of fundamental physics concepts.
Scootty83
I am not all that great at mathematics or physics or anything like that, though it does interest me a great deal and I am just trying to better understand the theories, so please bare with me here.
I have read that the closer an object gets to traveling at the speed of light its mass increases and its size decreases. Am I correct? E=mc^2 and the Lorentz Contraction.
The more mass an object has, the stronger its gravitational pull. Yes?
If Earth's speed through space doubled, I assume that its mass and gravitational pull would increase as well. Yes? Would its mass and gravitational pull be proportional to the increase of speed? In other words, would they double as well too?
Earth's orbital speed relative to the sun: 66,700mph. Doubled it's: 133,400mph
Earth's mass = 5.9742 × 10^24 kilograms. Doubled it's: 1.19484 × 10^25.
1g is equal to 9.80665 m/s^2. Doubled it's: 2g = 19.6133 m/s^2
Is this information correct?
I am about to unload a lot of questions, so please be patient with my ignorance.
Hi and welcome to PF!
The relativistic mass you're referring to is an antiquated concept -- nobody uses it anymore. Rather, we simply refer to the mass of an object and say that the kinetic energy and momenta are given by different formula from what Newton said.
That said, unless an object is moving at a speed comparable to that of light, its energy will be completely dominated by its rest energy, i.e. just it's mc^2 energy. So the effect of the Earth's orbital speed is completely negligible, so if it doubles nobody cares.
Secondly, you cannot naively mesh special relativity and gravity by saying that if an object's relativistic mass increases then so too does its gravity. If you want to discuss gravity and special relativity, then you must discuss general relativity, which is much more complicated. If you try to use simple notions, you end up saying things like if you are in a frame where an object is moving very rapidly, it will collapse into a black hole, but in that object's own frame it obviously is not moving so no black hole. The moral of the story is, gravity would not be changed by any appreciable amount.
As measured from another frame of reference, yes. In it own frame of reference, nothing changes.
Yes.
No. It would increase by an amount so vanishingly small it would take precision instruments to measure it.
To double the mass would require it to move approximately 160,000 miles per second about 90% of the speed of light - about 5000 times faster.
Here's a relativity calculator:
http://www.1728.com/reltivty.htm?b0=80000
Input a number on the text field, press the miles per scond button. Keep increasing the number until the change factor approaches 2.
Scotty83,
Your statement:1g is equal to 9.80665 m/s^2. Doubled it's: 2g = 19.6133 m/s^2 is incorrect as
1 gram is the mass if 1 cc of water and 9.8 m/s2 is a measure of acceleration of any freely falling mass very near the Earth's surface. Since these are measures of different things, they cannot be equated.
As orbital speeds, even doubled are nowhere near relativistic speeds, the effects proposed would not be observed.
However, if the orbital speed of the Earth were doubled, the Earth would move into an elliptical orbit taking it farther from the sun but returning to the distance it was when its speed doubled every "new" year.
Thanks all for the info. I have more questions still, but before I ask them, I'm going to see if I can answer them myself.
"Scootty" (2 o's 2 t's) is a nick name from high school... It just stuck. And I am sure you can guess the 83...
Not without dinner and flowers.
The mass doesn't really increase. "Relativistic mass" is a concept often used to teach relativity, as a kludge to make relativistic equations look more like Newton's Laws. But the reality is that Newton was wrong about those laws near the speed of light.
And this is why "Relativistic Mass" shouldn't be used at all--- the answer to your question is "not necessarily." Newton was wrong about gravity being the attraction of masses. At low energies, that's true, but the kinetic energy of a uniformly moving mass isn't purely attractive, no.
No. Speed is Relative. That's where the theory gets its name from. What that means is that speed is meaningless except in relation to other bodies. In other words, aside from looking at a body and saying "that thing is traveling at 100 MPH. Therefore I must be traveling at 100 MPH relative to it," there can be no experiment you can do without reference to outside bodies whose outcome depends on the speed of the observer. If Earth's gravity, as measured by Earthlings, increased with its speed, then that would be an experiment that could be performed that would yield Earth's speed without reference to other bodies, and that cannot be. Thus the answer to your question is "no."
:biggrin:
I saw what you did there...
daqddyo1 said:
Scotty83,
If I am not mistaken, "g" not only represents a gram but it is also the proper notation for g-force or gravitational force as well, which is how I was using it in this case.
Back to my question: Would these statements be accurate? 1g (or 1 g-force) is equal to 9.80665 m/s^2. Doubled it's: 2g = 19.6133 m/s^2. Can g-forces be comparable to the rate at which an object will fall towards the center of the Earth?
Is that what daqddyo1 was trying to say?
He misunderstands. You are correct.
For all intents and purposes, yes.
No, an object falling towards a gravitational source cannot and will not exceed c.
If Earth's speed doubled, there would be a very very slight increase in relativistic mass.
An increase in relativistic mass does not mean an increase in gravity.
From Earth's perspective it would have no relativistic effects, instead other objects would.
daqddyo1 said:
Scotty83,
1 g also is a measure of Earth's gravity. :rolleyes:
:smile:
This is a little tricky to define. In the case of a black hole, matter never exceeds c but space itself does.
Let's not complicate matters beyond the OP's question. He's asking about the velocity of Earth and the relativistic effect that will have on its mass and thus (albeit incorrectly) its gravity.
In addition to what others wrote: forces from objects at high speed, as inferred by us, are in general affected by speed. For example, the attraction between two charges that are in parallel motion reduces as a function of speed, although their charges remain the same. Thus it's wrong to think that one may extrapolate laws that are valid for objects in rest to objects in motion.
Harald
Good point.
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 23 ·
  • · Replies 64 ·
13K
  • · Replies 62 ·
