I'm getting two possible uncertainties for frequency
The discussion revolves around calculating the speed, period, and their uncertainties for a wave given its wavelength and frequency. The original poster expresses confusion regarding the application of propagation of errors, particularly in calculating the period from frequency and the discrepancies in results obtained through different methods.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the period and its uncertainty using two different methods, leading to different results. They question the validity of their approach and the formulas used for propagation of errors.
  • Some participants question the assumptions made regarding the treatment of uncertainties, particularly in the context of independent and dependent variables.
  • There is discussion about the appropriateness of using differentiation for uncertainty calculations and whether it simplifies the process.
Participants are actively engaging with the original poster's calculations, providing insights and alternative perspectives on the propagation of errors. There is a recognition of the need to clarify the treatment of uncertainties, but no consensus has been reached on a single method or approach.
Participants note the importance of including all relevant uncertainties in calculations and the potential pitfalls of omitting certain terms. The discussion reflects a learning environment where different interpretations and methods are being explored without definitive conclusions.
Andrew Tom
Find the uncertainty in the frequency of a wave
##v=\lambda f##
Calculate the speed and uncertainty in the speed for a wave with wavelength ##50\pm 3\mu s## and frequency ##30\pm 1kHz##. Also calculate the period and uncertainty in the period.
I am not sure about my answer to the second part. I used propagation of errors to get ##\Delta T=\Delta(1/f)=(\frac{1}{f})\sqrt{(\frac{\Delta 1}{1})^2+(\frac{\Delta f}{f})^2}=\frac{1}{f}(\frac{\Delta f}{f})=\frac{\Delta f}{f^2}=1.1111\mu s##. So ##T\pm \Delta T = 33.333\mu s \pm 1.111\mu s = 33\pm 1 \mu s##.
The reason I am not sure is because I did ##\Delta 1/1## which I have not seen before (but I only started learning uncertainties). Also the first part of the question is to calculate speed and its uncertainty, and if I use that to find uncertainty in period I get a different answer:
Using propagation of errors again with ##v=\lambda f## gives ##v\pm \Delta v = 1.5\pm 0.1029... =1.5\pm 0.1ms^{-1}##.
Then we can do ##\Delta T = \Delta (\frac{\lambda}{v})=\frac{1}{f}\sqrt{(\frac{\Delta \lambda}{\lambda})^2+\frac{\Delta v}{v})^2}=2.989...\mu s##. I.e. ##T\pm \Delta T = 33.3333\mu s \pm 2.989...\mu s = 33\pm 3\mu s##. This is different from the answer I got above without using ##v=\lambda f##, so I am a bit confused why there are different formulas using propagation of errors formula.
Also is there an easier way of doing this? Someone told me that the percentage error in ##f## would actually be the same as that in ##T## but I am not so sure.
Andrew Tom said:
Homework Statement:: Find the uncertainty in the frequency of a wave
Relevant Equations:: ##v=\lambda f##
I didn't calculate the percent error but in your first propagation of errors it's ##\Delta \lambda = 3 ~ \mu s## and ##\Delta f = 1 ~ kHz##. You dropped the wavelength uncertainty for some reason.
-Dan
Also is there an
-Dan
I didn't use the wavelength uncertainty in my first calculation. I just wrote T=1/f and used propagation formula for division, with 1 and f as the "variables". I dropped the first term under square root because I thought ##\frac{\Delta 1 }{1} =0##.
You have to calculate the uncertainty in the calculated dependent variable(s) using the uncertainty in the measured independent variable(s). Here, the measured independent variables are the frequency and the wavelength. Whatever uncertainty you calculate must have ##\frac{\Delta f}{f}## and ##\frac{\Delta \lambda}{\lambda}## only on the right-hand side. Putting the uncertainty of a dependent variable on the right-hand side compounds the uncertainty unnecessarily.
Also, ##\frac{\Delta 1}{1}## is a silly way to look at differences. Number ##1## is always ##1## even for small values of ##1##. The way to handle this is formally, using the meaning of ##\Delta## as a difference operator: $$\Delta T=\Delta \left(\frac{1}{f}\right)=\frac{1}{f+\Delta f}-\frac{1}{f}=\frac{f-f-\Delta f}{f(f+\Delta f)}=\frac{-\Delta f}{f(f+\Delta f)}\approx -\frac{\Delta f}{f^2}.$$The last approximation is valid in the limit ##\Delta f \rightarrow 0.##
You thought correctly.
So would I do ##\Delta T = \Delta \frac{\lambda}{\lambda f}=T\sqrt{(\frac{\Delta \lambda}{\lambda})^2+(\frac{\Delta \lambda}{\lambda})^2+(\frac{\Delta f}{f})^2}##? Somehow this doesn't seem right.
Ah ok, so would differentiation be better? I.e. ##\Delta T=\Delta \frac{1}{f}=\frac{dT}{df}\Delta f = -\frac{\Delta f}{f^2}##?
Yes, taking derivatives would be quicker if you are familiar with them. The derivation in post #4 is really taking the derivative using the formal definition $$\frac{dT}{df}=\lim_{\Delta f \rightarrow 0} {\frac {T(f+\Delta f)-T(f)}{\Delta f}}.$$
I guess that's one way to look at it.
