Inverse of a 7×7 permutation matrix
  • Topic:
  • Thread starter A.Magnus
    Inverse
7 replies · 3K views · last reply
A.Magnus
How do I go about find out the inverse of this giant $7 \times 7$ matrix? Do I need to evaluate it using the tedious Gauss-Jordan method? Any property, short-cut, trick that I can take advantage of?
$$\begin{pmatrix}
0 &1 &0 &0 &0 &0 &0\\
0 &0 &0 &1 &0 &0 &0\\
0 &0 &0 &0 &0 &0 &1\\
0 &0 &0 &0 &0 &1 &0\\
0 &0 &1 &0 &0 &0 &0\\
0 &0 &0 &0 &1 &0 &0\\
1 &0 &0 &0 &0 &0 &0\\
\end{pmatrix}$$
Your time and gracious help is very much appreciated? Thank you. ~MA
Lets call the matrix you gave $A$. What is the transpose of $A$? That's your answer but I'm not immediately sure how to prove that.
Are you supposed to be finding a shortcut or fast method? It would seem unlikely that finding the inverse of a matrix of this size would be a homework task to be done by hand?
I like Serena said:
Hey MaryAnn! ;)
Are you familiar, or do your notes say something about an Orthogonal matrix?
No, we don't have it. I checked textbook's index but could not find any orthogonal matrix entry. But anyway, I found out the least tedious solution: Assuming the matrix is $X$ and its inverse is $Y$, then $XY = I$. Then using the definition of multiplication of matrix, I expanded the seven entries of the diagonal of $I$ (since they are all non-zero) to come up with the $y_{ij}$ that are non-zero. The rest of $y_{ij}$ are zero. Thank you though for pitching in, thanks for your gracious help and time. ~MA
- - - Updated - - -
I did that, but its transpose did not take me anywhere. Thank you though for your gracious help, and time. ~MA
- - - Updated - - -
I think I found the least tedious solution, see my response to I Like Serena. Thank you though for your gracious help, and for your time. ~MA
That works as well.
For the record, your matrix is orthogonal because each column vector has unit length, and because each pair of column vectors is orthogonal.
As a consequence the inverse is simply the transpose as greg1313 mentioned. (Mmm)
It doesn't look to me like "Gauss-Jordan" will be all that tedious. You should be able to do some obvious "swaps" of two rows to get the matrix to the identity matrix,
I like Serena said:
That works as well.
Thank you again for your gracious help. ~MA
- - - Updated - - -
Thank you for your gracious comment. ~MA
