Is this Hessian/spectral viewpoint known?
  • Level: Graduate
  • Thread starter Thread starter Roberto Pavani
8 replies · 2K views · last reply
Roberto Pavani
TL;DR
Given a scalar field
## f(\mathbf{x})=\sum_a f_a(\mathbf{x}), ##
its Hessian satisfies
## H(\mathbf{x})=\sum_a H_a(\mathbf{x}). ##
Local observables are obtained from the eigendecomposition of the total Hessian,
## H\,\mathbf e_i=\lambda_i\,\mathbf e_i, ##
not by combining the eigenvalues of the individual contributions.
This seems like a trivial consequence of linear differential operators plus the spectral theorem, yet similar patterns appear in many areas of physics and applied
I recently encountered a situation where local observables are obtained from the eigendecomposition of a Hessian matrix.
A scalar field is written as a superposition of individual source contributions:
f(\mathbf{x}) = \sum_a f_a(\mathbf{x})
Therefore, by linearity of differentiation,
H(\mathbf{x})
\nabla\nabla f
\sum_a \nabla\nabla f_a
So in a multi-source (multi-body) configuration the total Hessian is simply
H(\mathbf{x}) = \sum_a H_a(\mathbf{x}).
The observables are then obtained from the spectral decomposition of the total Hessian:
H(\mathbf{x})\,\mathbf e_i(\mathbf{x})
\lambda_i(\mathbf{x})\,\mathbf e_i(\mathbf{x}).
In other words,
\text{sources}
\rightarrow
f
\rightarrow
H
\rightarrow
\{\lambda_i,\mathbf e_i\}
\rightarrow
\text{observables}.
Importantly, I am not asking about summing eigenvalues. In general,
\lambda_i(A+B)
\neq
\lambda_i(A)+\lambda_i(B).
The point is that the underlying geometric object (the Hessian) superposes linearly, while the physically relevant quantities are extracted from the spectrum of the resulting operator.
This feels almost trivial (linearity of differentiation plus the spectral theorem), yet similar patterns seem to appear in continuum mechanics, elasticity, fluid dynamics, tidal tensors in GR, etc.
Is there a standard name for this viewpoint, principle, construction, or framework? Or is it considered so trivial that it is usually left unnamed, as a straightforward consequence of operator linearity and spectral theory?
Could you give some examples?
I'm having a hard time seeing your post as anything more than writing out some mathematical facts. Like that symmetric matrices are diagonalizable and the linearity of the derivative.
When I think about physics I more commonly think about first order derivatives. So some examples might be helpful for me. :)
A very simple example is electrostatics.
The electrostatic potential obeys superposition,
V(\mathbf r)=\sum_a V_a(\mathbf r),
therefore its Hessian (the electric field-gradient tensor)
V_{ij}=\partial_i\partial_j V
also superposes linearly.
A similar situation occurs for the Newtonian tidal tensor
T_{ij}=\partial_i\partial_j\Phi,
and in elasticity with the strain tensor.
In all these examples the tensorial quantity is built from derivatives of a superposed field, while the physically meaningful principal directions and principal values are obtained from the spectral decomposition of the total tensor rather than from the spectra of the individual contributions.
My question is not about Hessians specifically, but whether this general "superposition → local tensor/operator → spectral observables" viewpoint has a standard name.
Perhaps another way to phrase my point is that second derivatives often seem geometrically more significant than first derivatives. A suitable local reference frame can eliminate first-derivative effects, whereas second-derivative structure generally remains.
Honestly, I don't know. Maybe something like principal axes/directions of curvature (of x,y,z field)?
When I think second derivatives I think curvature. When I think eigen decomposition I think principal axes. But I don't know if people put them together or if there's literature that has already named this.
I'm not sure I agree with the general statement. I can certainly think of examples of this being true, like in your gravitation example, the geodesic deviation being dependent on curvature. But the statement feels too general to me.
Fair enough. For charge density and similar field theories, first derivatives certainly play a direct physical role, so my statement was probably too broad.
I was also thinking in terms of Minkowski spacetime, where some first-derivative quantities remain physically meaningful and cannot simply be transformed away.
However, my main point is not really about the relative importance of first vs second derivatives.
What I am wondering is slightly different.
The Hessian superposition itself is trivial, and I am not claiming anything about eigenvalue additivity.
My question is whether there is a known name for the strategy:
multi-source system
→ linear superposition of local differential operators
→ construction of a local tensor/operator
→ eigendecomposition
→ observables.
In particular, for problems where a global closed-form solution is unavailable or impractical (such as generic N-body systems), this provides a local route to observables through the spectrum of the total operator.
I was wondering whether this viewpoint appears somewhere under a standard name.
multi-source system
→ observables.
Could you write this out in mathematics / symbols? I'm not sure I am able to parse this into a known thing.
One thing your posts reminded me of vaguely, though I doubt this is what you mean, normal oscillation modes around stable equilibria. E.g. Goldstein chapter 6. You expand an arbitrary potential around an equilibrium point where the first order derivatives vanish by definition. Hence, the lowest level approximation of the potential that enters into the E.o.M. is the Hessian. You then solve the eigenvalue decomposition problem on terms that include that Hessian to get oscillation normal modes.
It might just illustrate that your question is quite general/broad. Equality of mixed partials gives a symmetric Hessian which lends itself to eigenvalue decomposition.
Thanks for your answer.
What I have in mind can be written abstractly as follows.
Suppose a scalar field is generated by multiple sources,
## \Phi(\mathbf{x})=\sum_i \Phi_i(\mathbf{x}) ##.
Let ## L ## be a linear differential operator.
Define
## A(\mathbf{x}) = L[\Phi] ##.
Then, by linearity, ## A(\mathbf{x}) = L\!\left[\sum_i \Phi_i\right] = \sum_i L[\Phi_i] ##.
For the Hessian case,
## L=\nabla\nabla ##,
so that
## H(\mathbf{x})=\nabla\nabla\Phi(\mathbf{x})=\sum_i \nabla\nabla\Phi_i(\mathbf{x}) ##.
The observables are not taken from the individual contributions ## H_i ##, but from the spectrum of the total operator:
## H = Q\Lambda Q^{T} ##,
with ## \Lambda=\operatorname{diag}(\lambda_1,\lambda_2,\lambda_3) ##.
Schematically,
## \Phi\;\longrightarrow\;A=L[\Phi]\;\longrightarrow\;\operatorname{spec}(A)\;\longrightarrow\;\text{observables} ##.
Equivalently,
## \Phi=\sum_i\Phi_i \quad\Longrightarrow\quad A=\sum_i A_i ##,
while the physical quantities are functions of the spectrum,
## \mathcal O = F\!\bigl(\operatorname{spec}(A)\bigr) ##.
The Hessian is just one example (## A=H ##), but the same structure appears whenever a linearly superposed field is mapped into a local tensor or operator and the physically relevant information is extracted from its eigenvalues and eigenvectors.
I agree that the underlying mathematical operation is quite trivial, so it may simply be that it does not have a dedicated name.
My intuition was simply that the same pattern seems to recur in a variety of multi-source or multi-body settings: one first exploits linear superposition at the field/operator level, and only afterwards extracts the physically relevant quantities through the spectrum of the resulting tensor or operator.
So perhaps the answer is simply that this is regarded as a straightforward combination of superposition and spectral analysis, rather than a separate framework with its own name.
This will be the case only when your ##H## is symmetric (assuming it's real). It's true for the Hessian since mixed partials commute (mostly, though there are pathologies) but not true in general. ##H## also obviously has to be order 2 (2 indices) here.
Good point.
You're right that the step
## A = Q \Lambda Q^T ##
requires additional assumptions and does not hold for a completely generic operator.
My original motivation came from Hessian-based constructions, where
## H_{ij} = \partial_i \partial_j \Phi ##
is symmetric (assuming sufficient regularity so that mixed partials commute), and therefore admits an orthogonal eigendecomposition.
Perhaps the procedure itself does not have a dedicated name. However, your comment may have identified a common feature shared by the examples I had in mind: they all involve symmetric local tensors, so that principal directions and principal values are well defined.
