Is acceleration due to gravity a 4-vector?
5 replies · 2K views
pellman
We can write the geodesic condition as
[tex]\frac{d^2 x^\alpha}{d\tau^2}={-\Gamma^\alpha}_{\mu\nu}\frac{dx^\mu}{d\tau}\frac{dx^\nu}{d\tau}[/tex]
On the RHS we have two contravariant vectors ( or (0,1) tensors ) contracted with the connection. But the connection is NOT a tensor. So is the LHS a vector? And if so, how does that work?
##a^{\mu} = \ddot{x}^{\mu} + \Gamma^{\mu}_{\alpha\beta}\dot{x}^{\alpha}\dot{x}^{\beta}## is a 4-vector but the two individual terms on the RHS are not 4-vectors. It's very easy to show that they both fail to transform as 4-vectors but that their sum does transform as a 4-vector.
Thanks. Regarding [itex]\ddot{x}^\mu[/itex] ... where do I go wrong in the following?
Suppose we have a change of coordinates [itex]x^\mu={\Lambda^\mu}_\alpha x'^\alpha[/itex]. Elements of the tangent space are vectors and likewise transform according to [itex]V^\mu={\Lambda^\mu}_\alpha V'^\alpha[/itex]. In particular the tangent to a curve [itex]x^\mu(\tau)[/itex] is [itex]dx^\mu/d\tau[/itex] which as a tangent vector transforms as
[tex]\frac{dx^\mu}{d\tau} ={\Lambda^\mu}_\alpha \frac{dx'^\alpha}{d\tau}[/tex]
but if we take the derivative of both sides of
we get
[itex]\frac{dx^\mu}{d\tau}=\frac{d}{d\tau}\left({\Lambda^\mu}_\alpha x'^\alpha\right)[/itex]
This is equivalent to the previous expression only if [itex]\frac{d}{d\tau}{\Lambda^\mu}_\alpha =0[/itex]. In this case if we take the second derivative, we get
[tex]\frac{d^2 x^\mu}{d\tau^2} ={\Lambda^\mu}_\alpha \frac{d^2 x'^\alpha}{d\tau^2}[/tex]
and so [itex]\ddot{x}^\mu[/itex] transforms as a vector.
##x^{\mu}## are not position vectors. The transformation ##x^{\mu} \rightarrow x^{\mu'}(x^{\nu})## will not be the same as the transformation matrix ##V^{\mu} \rightarrow V^{\mu'}## which is where your error is; in fact if we write the former transformation as ##x^{\mu'} = x^{\mu'}(x^{\nu})## then ##V^{\mu'} = \frac{\partial x^{\mu'}(x^{\nu})}{\partial x^{\mu}}V^{\mu}## so clearly we are talking about different transformations for the two.
we get
To simplify the notation, I'm going to drop the indices. It should be clear how to put them back.
In general, if you converting from a coordinate [itex]x'[/itex] to a coordinate [itex]x[/itex], then it's a nonlinear, continuous, invertible function:
[itex]x = F(x')[/itex]
So,
[itex]\frac{dx}{d \tau} = \frac{\partial F}{\partial x'} \frac{dx'}{d\tau}[/itex]
So even if [itex]F(x')[/itex] is nonlinear, the relationship between velocities is linear:
[itex]\frac{dx}{d \tau} =\Lambda \frac{dx'}{d\tau}[/itex]
where [itex]\Lambda = \frac{\partial F}{\partial x'}[/itex]
But note: the transformation between coordinates is not the same as the transformation between velocities:
[itex]\frac{dx}{d \tau} =\Lambda \frac{dx'}{d\tau}[/itex] versus [itex]x = F(x')[/itex]
The only time that you can use the same matrix [itex]\Lambda[/itex] to transform coordinates or velocities is when:
[itex]F(x') = \Lambda x'[/itex]
which is only possible when [itex]\frac{\partial \Lambda}{\partial x'} = 0[/itex]
