- 16,103
- 9,307
I was looking at the AAPT 2023 Physics Bowl questions (and answers) found here
https://aapt.org/programs/physicsbowl/currentexam.cfm
and multiple choice question 6 caught my eye:
Consider one horizontal circular path that a ball makes on the inside surface of a cone. In this situation, the normal force on the ball
a. is mg.
b. is always greater than mg.
c. may be greater or less than mg.
d. is always less than mg.
e. depends upon the speed of the ball.
The posted correct answer is B
The normal vector has a greater magnitude than its vertical component (magnitude of mg). The magnitude of the normal vector is also greater than the horizontal component, the net force directed to the center of circular motion.
Only one answer is allowed which implies that the rest are incorrect. Not so. Since the ball moves in a horizontal circle, the vertical component of the normal force must be equal to the weight and the horizontal component provides the centripetal acceleration.
Let = the half-angle of the cone. Then $$\begin{align} & N\sin\!\alpha=mg \nonumber \\ & N\cos\!\alpha =\frac{mv^2}{r} \nonumber \\ & \sqrt{N^2\sin^2\!\alpha+N^2\cos^2\!\alpha}=N=\sqrt{(mg)^2+\left(\frac{mv^2}{r}\right)^2}.
\nonumber \end{align}$$It looks like both B and E are correct answers. I expected better from the AAPT.
(Edited to fix the equations' format.)
(Re-edited more than a year later to fix misconception. See post #9 below)
a. is mg.
