omarxx84
- 28
- 0
Can anyone help me to get the general solution of the linear partial differential equations with variable coefficients of any order?
The discussion revolves around the equation EI(x,t)U''''(x,t) + M(x,t)V''(x,t) and whether it is separable. Participants explore the nature of this partial differential equation (PDE), its linearity, and methods for solving it, including separation of variables.
Participants do not reach a consensus on whether the equation is separable. Multiple competing views are presented regarding the methods for solving the PDE and the implications of having two dependent variables.
Participants note the importance of specifying boundary or initial conditions and the roles of variable coefficients in the equations, which may affect the solvability and methods applied.
omarxx84 said:can anyone help me to solve this ODE:
A(x)Y''''(x,t)+M(x)W''(x,t)=0
where: A(x) and M(x) are variable coefficients
Y''''(x,t) 4th derivative with respect to x.
w''(x,t) 2nd derivative with respect to t.
A(x)\frac{\partial^4 Y}{\partial x^4}+ M(x)\frac{\partial^2M}{\partial t^2}= 0omarxx84 said:can anyone help me to solve this ODE:
omarxx84 said:this PDE is correct. but when i use the separation of variables principle to solve this equation, the resulting two equations are ODEs, which may as follows:
A(x)Y''''(x,t)+M(x)Y''(x,t)=0 ...(1) (main equation)
PUT : Y=F(x)W(t) AND SUBSITITUTING IN THE ABOVE EQUATION AND SEPERATING THE VARIABLES, WE GET THE TWO ODEs AS FOLLOWS:
W''(t)-aW(t)=0 ...(2)
where: a is arbitrary constant. this may be solved easily.and the second ODE is:
{A(x)/M(x)}F''''(x)-aF(x)=0 ...(3)
this equation is linear ODE with variable coefficient.
in which: A(x) and M(x) are variable coefficients along x-axis.
a is arbitrary constant, from separation of variable process.
by solving equation(3) and compiling with the solution of equation(2), we will get the solution of equation(1). so, the problem is how we can solve the equation(3). boundary or initial conditions, i don't we need now to solve equation(3).
However, I will say once more- if you have two dependent variables to solve for, you will need two equations.
