Killing Vectors (question on Problem)
  • Context: Graduate
  • Thread starter Thread starter Morgoth
    Vectors
The discussion revolves around the properties and implications of Killing vectors in the context of a given metric. Participants explore the conditions under which these vectors can be shown to be the gradient of a scalar field, their relationship to the Riemann tensor, and the implications of modifying the metric with Killing vectors.
  • One participant questions whether the conditions for Killing vectors were provided as part of the problem or if they are definitions.
  • Another participant suggests that to show the new metric describes the same space, one could calculate the Riemann tensor of the new metric and compare it to that of the original metric, although they express concern about the complexity of the calculations.
  • It is noted that the components of the Riemann tensor change under coordinate transformations, which may affect the validity of the original plan to show equivalence of metrics.
  • One participant asserts that having the same scalar curvature does not imply that two metrics describe the same space, emphasizing the need for a coordinate transformation to demonstrate equivalence.
  • A later post introduces a question about an alternative method to show that a parameter is not absorbable, referencing the Lie derivative and its relation to the metric.
Participants express differing views on the implications of scalar curvature and the necessity of coordinate transformations to establish metric equivalence. There is no consensus on the best approach to demonstrate the properties of the Killing vectors or the equivalence of the modified metric.
Participants acknowledge the complexity of the calculations involved in working with the Riemann tensor and the potential for errors in lengthy derivations. There are also discussions about the definitions and properties of Killing vectors that may not be universally agreed upon.
Morgoth
Well my main questions are colored in red...
Set of problem
Let's suppose we have a metric gab(x)
and the Killing vectors
Ia
( Ia;k=0, gμαIμIα= 0)
question
Show that those killing vectors are the gradient of a Scalar field, and that it satisfies the equation IαRαβγρ=0
Show that the new metric bellow describes the same space.
Gab= gab+IaIb
Attempt to solve
1. Since Ia;k=0, Ik;a=0
we get the equations
Ia,k - Γρak Iρ= 0 (1)
Ik,a - Γρka Iρ= 0 (2)
from (1)-(2) we get
Ia,k-Ik,a=0
can I say now that the Iα(x) is the gradient of a scalar?
I think I can.
2.
IαRαβγρ=0
by using the commutation of covariant derivative:
Ia;k;c-Ia;c;k=IdRdakc
but we know that Ia;b=0 so
0;c - 0;k =IdRdakc
IdRdakc=0
I think that this was an easy question.
3.
I have that
Gab= gab+IaIb
how can I show that it describes the same space?
one way I thought of is to calculate the R' riemann tensor of metric G and show that it is equal to R tensor of the metric g. But things get lost in calculations...
what is your opinion?
Morgoth said:
Ia
Were these two conditions given to you as part of the problem? Or are you claiming this is the definition of a killing vector?
Morgoth said:
3.
I have that
Gab= gab+IaIb
One way (the brute force but straightforward way) is you can start with the arbitrary metric and the coordinate transformation law for the metric tensor. Then try to play around with it until you show that the new components of the metric tensor are in fact what the problem wants.
1. yes they were given to me as part of the problem. they are what I know... One question was to show that I is indeed a killing vector, which I proved.
2. OK I will try this now...
Ok. Note that your original plan would not necessarily have to work because in general the components of the Riemann tensor change under a change of coordinates from one form of the metric tensor to another.
By the way, in terms of definitions, two metrics describe the same space if they are equivalent up to an isometry.
Yes but from the Rieman Tensor I can evaluate the Ricci tensor and the scalar curvature. The same S.curvature would describe the same space.
But the whole procedure is tough, tiring and of course might contain mistakes (when I tried it, just for the Riemann tensor I filled 3 pages and I was not sure if I calculated it correctly). So I wanted to know if there is a Killing vector identity that I was missing (since the new metric is your previous one + the term of two multiplied killing vectors).
Just because two spaces have the same scalar curvature does NOT mean they are the same space.
You need to do what WBN suggested: Show that the new metric is a coordinate transformation of the old one.
One more question, in case anyone knows...
If you have an I:
ds2= a (dθ2+sin2θ dφ2)
you can show that a is not absorbable parameter if the below equation has no solution:
Lξgαβ=∂gαβ/∂a
where L is the operator of Lie Derivative...
Is there an alternative way to show it?
  • · Replies 19 ·
