Is My OTF Knife Configuration Safe for Everyday Carry?
  • Thread starter Thread starter goldliger
    Knife Safety
The discussion centers on the safety of carrying an OTF knife, which has a blade that ejects straight out and is held closed by a magnetic force of 1 lb, 12 oz. The user conducted various tests to assess the knife's stability while carried in a pocket. However, the conversation shifted to the legality of such knives, as many jurisdictions, particularly in the U.S., have laws against switchblade and butterfly knives. Due to these legal concerns, further discussion on the knife's safety configuration was deemed inappropriate. The thread was ultimately closed due to these legal restrictions.
goldliger
Hey guys, brand new here but looks like I'm in the right place :D
I've got an OTF knife (a.k.a. "out the front," where the blade ejects straight out from the handle) that is held in the closed position with 1 lb, 12 ounces of magnetic force. I.e, upon measuring it takes 1 lb, 12 oz. of finger pressure against the knife switch to eject the blade (automatically). The blade itself weighs 1 oz.
Basically, I'm wondering how one would go about determining whether this is a reasonably safe configuration, considering the knife will be carried in the pocket and generally tip pointed down (within the handle, of course). I've done rudimentary testing such as jumping up and down, stomping, shaking my pockets, etc, with the knife in my pocket - pretty much everything short of jumping off a 100 foot cliff with rock slab at the bottom, since I figure knife safety would be the least of my concerns on the way down. :)
Any ideas, mathematical formulas, etc, are most welcome, and thanks for your time!
Welcome to PhysicsForums.
You need to check your local laws about that knife. Knife laws vary by country, state and local jurisdiction, but in many parts of the US at least, switchblade knives and butterfly knives are illegal (they are illegal in the part of the US where I live).
Yes you're correct about that - and thank you, good to be here. :)
Likes berkeman
Since the knife is most likely illegal, we can't really discuss it here (that's in the PF rules). I once bought a butterfly knife online many years ago before I found out they are illegal here in California. I thought it was a nice design and a handy way to be able to open a useful knife with one hand (I wanted to use it for hunting and fishing, etc.). Then I found out it was illegal (I still to this day do not understand why -- something about the tiny springiness that is used to help start opening it), and destroyed it and threw the pieces away. The risk was not worth the utility.
Anyway, sorry but this thread is now closed.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
