L-R-C circuit steady state solution: swapped coefficients in particular solution
2 replies · 2K views
Sparky_
In an L-R-C circuit, L = 1, R = 2, C = 0.25, E(t) = 50 cos(t)
Find the steady state solution
[tex]L \frac {di(t)}{dt} + R \frac {dq(t)}{dt} + \frac {q}{C} = 50cos(t)[/tex]
[tex]\frac {di(t)}{dt} + 2 \frac {dq(t)}{dt} + 4q = 50cos(t)[/tex]
[tex]q(t) = e^{-t}(c1cos(sqrt(12)t + c2sin(sqrt(12)t)[/tex]
next annihilate 50*cos(t)
[tex](D^2 +1) (D^2 + 2D + 4) = (D^2 +1)50cos(t)[/tex]
[tex]roots = +/- i[/tex]
[tex]qp(t) = Acos(t) + Bsin(t)[/tex]
[tex][-Acos(t) - Bsin(t)] - 2Asin(t) + 2Bcos(t) + 4Acos(t) + 4Bsin(t) = 50cos(t)[/tex]
[tex]cos(t)[-A+2B+4A] + sin(t)[-B-2A+4B] = 50cos(t)[/tex]
[tex]3A+2B = 50[/tex]
[tex]3B-2A = 0[/tex]
[tex]A = \frac {150}{13}[/tex]
[tex]B = \frac {100}{13}[/tex]
[tex]qp(t) = \frac {150}{13}cos(t) + \frac {100}{13}sin(t)[/tex]
The book gets
[tex]qp(t) = \frac {100}{13}cos(t) - \frac {150}{13}sin(t)[/tex]
I'm off with swapped coefficients and the sign.
Do I have something crossed?
Where is my error?
Thanks
-Sparky
Are we to assume that i= dq/dt?
How did you get that? If you took i= dq/dt so that di/dt= d2q/dt2, then characteristic equation is r2+ 2r+ 4= (r+2)2= 0 and the general solution (to the associated homogeneous equation) is
[tex]q(tt)= c1e^{-2t}+ c2 te^{-2t}[/tex]
The book gets
Where is my error?
Thanks
-Sparky
You are correct on the first (homogeneous solution) - I had an obvious error in my work. I didn't recognize the obvious solution and made a mistake in factoring.
(However, I don't need that solution to get the steady state) I need the particular qp(t)
the [tex](D^2 +1) (D^2 + 2D + 4) = (D^2 +1)50cos(t)[/tex]
the second term is the solution to the homogeneous - as you pointed out [tex]q(tt)= c1e^{-2t}+ c2 te^{-2t}[/tex]
The [tex](D^2 +1)[/tex]
with all the equating coefficients is where my error is.
Thoughts?
-Sparky
