Loop-and-allied QG bibliography
  • Level: Graduate
  • Thread starter Thread starter marcus
    Bibliography
2,547 replies · 789K views
http://arxiv.org/abs/1406.6021
Analytic Continuation of Black Hole Entropy in Loop Quantum Gravity
Jibril Ben Achour (APC - UMR 7164), Amaury Mouchet (LMPT), Karim Noui (APC - UMR 7164, LMPT)
(Submitted on 23 Jun 2014)
We define the analytic continuation of the number of black hole microstates in Loop Quantum Gravity to complex values of the Barbero-Immirzi parameter γ. This construction deeply relies on the link between black holes and Chern-Simons theory. Technically, the key point consists in writing the number of microstates as an integral in the complex plane of a holomorphic function, and to make use of complex analysis techniques to perform the analytic continuation. Then, we study the thermodynamical properties of the corresponding system (the black hole is viewed as a gas of indistinguishable punctures) in the framework of the grand canonical ensemble where the energy is defined à la Frodden-Gosh-Perez from the point of view of an observer located close to the horizon. The semi-classical limit occurs at the Unruh temperature TU associated to this local observer. When γ=±i, the entropy reproduces at the semi-classical limit the area law with quantum corrections. Furthermore, the quantum corrections are logarithmic provided that the chemical potential is fixed to the simple value μ=2TU.
31 pages, 2 figures
http://arxiv.org/abs/1406.5524
Black hole entropy with and without log correction in loop quantum gravity
P. Mitra
(Submitted on 2 Jun 2014)
Earlier calculations of black hole entropy in loop quantum gravity have given a term proportional to the area with a correction involving the logarithm of the area when the area eigenvalue is close to the classical area. However the calculations yield an entropy proportional to the area eigenvalue with no such correction when the area eigenvalue is large compared to the classical area.
6 pages; talk delivered at Light Cone conference, Delhi, 2012, to appear in Nucl. Phys. B, 251-252 (2014)
http://arxiv.org/abs/1406.5518
A 3.55 keV line from DM→a→γ: predictions for cool-core and non-cool-core clusters
Joseph P. Conlon, Andrew J. Powell
http://arxiv.org/abs/1406.5808
3.55 keV X-ray Line Interpretation in Radiative Neutrino Model
Hiroyuki Ishida, Hiroshi Okada
http://arxiv.org/abs/1406.7159
Gravitons and a complex of differential operators
Kirill Krasnov
(Submitted on 27 Jun 2014)
Gravity is now understood to become simple on-shell. We sketch how it becomes simple also off-shell, when reformulated appropriately. Thus, we describe a simple Lagrangian for gravitons that makes use of a certain complex of differential operators. The Lagrangian is constructed analogously to that of Maxwell's theory, just using a different complex. The complex, and therefore also our description of gravitons, makes sense on any half-conformally flat four-dimensional manifold.
http://arxiv.org/abs/1406.7304
Entanglement entropy and nonabelian gauge symmetry
William Donnelly
Entanglement entropy has proven to be an extremely useful concept in quantum field theory. Gauge theories are of particular interest, but for these systems the entanglement entropy is not clearly defined because the physical Hilbert space does not factor as a tensor product according to regions of space. Here we review a definition of entanglement entropy that applies to abelian and nonabelian lattice gauge theories. This entanglement entropy is obtained by embedding the physical Hilbert space into a product of Hilbert spaces associated to regions with boundary. The latter Hilbert spaces include degrees of freedom on the entangling surface that transform like surface charges under the gauge symmetry. These degrees of freedom are shown to contribute to the entanglement entropy, and the form of this contribution is determined by the gauge symmetry. We test our definition using the example of two-dimensional Yang-Mills theory, and find that it agrees with the thermal entropy in de Sitter space, and with the results of the Euclidean replica trick. We discuss the possible implications of this result for more complicated gauge theories, including quantum gravity.
12 pages. Invited article for Classical and Quantum Gravity special issue on Entanglement and Quantum Gravity
brief mention:
http://arxiv.org/abs/1406.7318
Cosmological Perturbations in Antigravity
Marius Oltean, Robert Brandenberger
We compute the evolution of cosmological perturbations in a recently proposed Weyl-symmetric theory of two scalar fields with oppositely-signed conformal couplings to Einstein gravity. It is motivated from the minimal conformal extension of the Standard Model, such that one of these scalar fields is the Higgs while the other is a new particle, the dilaton, introduced to make the Higgs mass conformally symmetric. At the background level, the theory admits novel geodesically-complete cyclic cosmological solutions characterized by a brief period of repulsive gravity, or "antigravity", during each successive transition from a Big Crunch to a Big Bang. We show that despite the necessarily wrong-signed kinetic term of the dilaton in the full action, its cosmological solutions are stable at the perturbative level.
15 pages.
http://arxiv.org/abs/1406.7713
Absence of cosmological constant problem in special relativistic field theory of gravity
Carlos Barceló, Raúl Carballo-Rubio, Luis J. Garay
The principles of quantum field theory in flat spacetime suggest that gravity is mediated by a massless particle with helicity ±2, the so-called graviton. It is regarded as textbook knowledge that, when the self-coupling of a particle with these properties is considered, the long-wavelength structure of such a nonlinear theory is fixed to be that of general relativity. However, …
...This special relativistic field theory of gravity implies the decoupling of vacuum zero-point energies of matter and passes all the known experimental tests in gravitation.
10 pages.
http://arxiv.org/abs/1407.0025
New action for simplicial gravity in four dimensions
Wolfgang M. Wieland
(Submitted on 30 Jun 2014)
We develop a proposal for a theory of simplicial gravity with spinors as the fundamental configuration variables. The underlying action describes a mechanical system with finitely many degrees of freedom, the system has a Hamiltonian and local gauge symmetries. We will close with some comments on the resulting quantum theory, and explain the relation to loop quantum gravity and twisted geometries. The paper appears in parallel with an article by Cortês and Smolin, who study the relevance of the model for energetic causal sets and various other approaches to quantum gravity.
26 pages, 2 figures.
http://arxiv.org/abs/1407.0032
Spin foam models as energetic causal sets
Marina Cortês, Lee Smolin
Energetic causal sets are causal sets endowed by a flow of energy-momentum between causally related events. These incorporate a novel mechanism for the emergence of space-time from causal relations. Here we construct a spin foam model which is also an energetic causal set model. This model is closely related to the model introduced by Wieland, and this construction makes use of results used there. What makes a spin foam model also an energetic causal set is Wieland's identification of new momenta, conserved at events (or four-simplices), whose norms are not mass, but the volume of tetrahedra. This realizes the torsion constraints, which are missing in previous spin foam models, and are needed to relate the connection dynamics to those of the metric, as in general relativity. This identification makes it possible to apply the new mechanism for the emergence of space-time to a spin foam model.
16 pages, 4 figures.
http://arxiv.org/abs/1407.0284
The Tensor Theory Space
Vincent Rivasseau
(Submitted on 1 Jul 2014)
The tensor track is a background-independent discretization of quantum gravity which includes a sum over all topologies. We discuss how to define a functional renormalization group flow and the Wetterich equation in the corresponding theory space. This space is different from the Einsteinian theory space of asymptotic safety. It includes all fixed-rank tensor-invariant interactions, hence generalizes matrix models and the (Moyal) non-commutative field theory space.
12 pages. This short note is intended as a complement to arXiv:1311.1461, to appear in the Proceedings of the Workshop on Noncommutative Field Theory and Gravity in Corfu September 2013, Fortshritt. Phys. 2014
http://arxiv.org/abs/1406.7237
Cosmic Jerk and Snap in Penrose's CCC model
Maciej Dunajski
We obtain a constraint on cosmological scalars for the FRW metric with a pure radiation fluid source and positive cosmological constant. We demonstrate that this constraint is conformally invariant in the context of Penrose's Conformal Cyclic Cosmology proposal, where the metrics of the late stages of the previous aeon and the early stages of the present aeon are described by FRW cosmologies.
Jerk: http://en.wikipedia.org/wiki/Jerk_(physics )
Snap: http://en.wikipedia.org/wiki/Jounce
http://arxiv.org/abs/1407.0130
Probing Beyond Standard Model via Hawking Radiated Gravitational Waves
Tomohiro Fujita
We propose a novel technique to probe the beyond standard model (BSM) of particle physics. The mass spectrum of unknown BSM particles can be scanned by observing gravitational waves (GWs) emitted by Hawking radiation of black holes. This is because information on the radiation of the BSM particles is imprinted in the spectrum of the GWs. We fully calculate the GW spectrum from evaporating black holes taking into account the greybody factor. As an observationally interesting application, we consider primordial black holes which evaporate in the very early universe. In that case, since the frequencies of GWs are substantially redshifted, the GWs emitted with the BSM energy scales become accessible by observations.
http://arxiv.org/abs/1407.0989
Black hole fireworks: quantum-gravity effects outside the horizon spark black to white hole tunneling
Hal M. Haggard, Carlo Rovelli
(Submitted on 3 Jul 2014)
We show that there is a classical metric satisfying the Einstein equations outside a finite spacetime region where matter collapses into a black hole and then emerges from a white hole. We compute this metric explicitly. We show how quantum theory determines the (long) time for the process to happen. A black hole can thus quantum-tunnel into a white hole. For this to happen, quantum gravity should affect the metric also in a small region outside the horizon: we show that contrary to what is commonly assumed, this is not forbidden by causality or by the semiclassical approximation, because quantum effects can pile up over a long time. This scenario alters radically the discussion on the black hole information puzzle.
10 pages, 5 figures
http://arxiv.org/abs/1407.0998
Cosmological perturbations in Hybrid Loop Quantum Cosmology: Mukhanov-Sasaki variables
Laura Castelló Gomar, Mikel Fernández-Méndez, Guillermo A. Mena Marugán, Javier Olmedo
We study cosmological perturbations in the framework of Loop Quantum Cosmology, using a hybrid quantization approach and Mukhanov-Sasaki variables. The formulation in terms of these gauge invariants allows one to clarify the independence of the results on choices of gauge and facilitates the comparison with other approaches proposed to deal with cosmological perturbations in the context of Loop Quantum Theory. A kind of Born-Oppenheimer ansatz is employed to extract the dynamics of the inhomogeneous perturbations, separating them from the degrees of freedom of the Friedmann-Robertson-Walker geometry. With this ansatz, we derive an approximate Schrödinger equation for the cosmological perturbations and study its range of validity. We also prove that, with an alternate factor ordering, the dynamics deduced for the perturbations is similar to the one found in the so-called "dressed metric approach", apart from a possible scaling of the matter field in order to preserve its unitary evolution in the regime of Quantum Field Theory in a curved background and some quantization prescription issues. Finally, we obtain the effective equations that are naturally associated with the Mukhanov-Sasaki variables, both with and without introducing the Born-Oppenheimer ansatz, and with the different factor orderings that we have studied.
45 pages
http://arxiv.org/abs/1407.1124
Cosmological Constant in a Regge State-sum Model of Quantum Gravity
Aleksandar Mikovic, Marko Vojinovic
(Submitted on 4 Jul 2014)
We study the quantum contributions to the classical cosmological constant in a Regge state-sum model of quantum gravity in the effective action approach. We use a special path-integral measure and we include matter, in the form of a massive scalar field. The effective cosmological constant is given as a sum of 3 terms: the classical CC, the quantum gravity CC and the matter CC. Since observations can only measure the sum of these 3 terms, we can choose the classical CC to be equal to the negative value of the matter CC. Hence the effective CC is given by the quantum gravity CC, which is determined by the path-integral measure only. Since the path-integral measure depends on a free parameter, this parameter can be chosen such that the effective CC gives the observed value.
http://arxiv.org/abs/1407.1391
Mutiny at the white-hole district
(Submitted on 5 Jul 2014)
The white-hole sector of Kruskal's solution is almost never used in physical applications. However, it might contain the solution to many of the problems associated with gravitational collapse and evaporation. This essay tries to draw attention to some bouncing geometries that make a democratic use of the black- and white-hole sectors. We will argue that these types of behaviour could be perfectly natural in some approaches to the next physical level beyond classical general relativity.
8 pages, 1 figure. Essay awarded a honorable mention in the 2014 Gravity Research Foundation essay competition
http://arxiv.org/abs/1407.1394
Regge Quantum Gravity Solution to the Cosmological Constant Problem
We show that it is possible to solve the cosmological constant (CC) problem in a discrete quantum gravity theory based on Regge calculus by using the effective action approach and a special path-integral measure. The effective cosmological constant is a sum of 3 terms: the classical CC, the quantum gravity CC and the matter CC. Since observations can only measure the sum of these 3 terms, we can choose the classical CC to be equal to the negative value of the matter CC. Hence the effective CC is given by the quantum gravity CC, which is determined by the path-integral measure. Since the path-integral measure depends on a free parameter, this parameter can be chosen such that the effective CC gives the observed value.
5 pages
http://arxiv.org/abs/1407.1784
Neutrinos from the Early Universe and Physics Beyond Standard Models
Daniela Kirilova
(Submitted on 7 Jul 2014)
Neutrino oscillations present the only robust example of experimentally detected physics beyond the standard model. This review discusses the established and several hypothetical beyond standard models neutrino characteristics and their cosmological effects and constraints. Particularly, the contemporary cosmological constraints on the number of neutrino families, neutrino mass differences and mixing, lepton asymmetry in the neutrino sector, neutrino masses, light sterile neutrino are briefly reviewed.
20 pages, invited review
http://arxiv.org/abs/1407.2428
Kantowski-Sachs spacetime in loop quantum cosmology: geometric scalars and the viability of quantization prescriptions
Anton Joe, Parampreet Singh
(Submitted on 9 Jul 2014)
Using effective dynamics, we investigate the behavior of expansion and shear scalars in different proposed quantizations of the Kantowski-Sachs spacetime with matter in loop quantum cosmology. We find that out of the various proposed choices, there is only one known prescription which leads to the generic bounded behavior of these scalars. The bounds turn out to be universal and are determined by the underlying quantum geometry. This quantization is analogous to the so called `improved dynamics' in the isotropic loop quantum cosmology, which is also the only one to respect the freedom of the rescaling of the fiducial cell. Other proposed quantization prescriptions yield geometric scalars which may not be bounded for certain initial conditions within the validity of effective spacetime description. These prescriptions also have a limitation that the "quantum geometric effects" can occur at an arbitrary scale. We show that the 'improved dynamics' of Kantowski-Sachs spacetime turns out to be a unique choice in a general class of possible quantization prescriptions, in the sense of leading to generic bounds on geometric scalars and the associated physics being free from fiducial cell dependence. The behavior of the energy density in the 'improved dynamics' reveals some interesting features. Even without considering any details of the dynamical evolution, it is possible to rule out pancake singularities in this spacetime. The energy density is found to be dynamically bounded. These results show that the Planck scale physics of the loop quantized Kantowski-Sachs spacetime has key features common with the loop quantization of isotropic and Bianchi-I spacetimes.
18 pages, 2 figures
General interest:
http://arxiv.org/abs/1407.2528
Faster than light motion does not imply time travel
H. Andréka, J. X. Madarász, I. Németi, M. Stannett, G. Székely
Seeing the many examples in the literature of causality violations based on faster-than- light (FTL) signals one naturally thinks that FTL motion leads inevitably to the possibility of time travel. We show that this logical inference is invalid by demonstrating a model, based on (3+1)-dimensional Minkowski spacetime, in which FTL motion is permitted (in every direction without any limitation on speed) yet which does not admit time travel. Moreover, the Principle of Relativity is true in this model in the sense that all observers are equivalent. In short, FTL motion does not imply time travel after all.
http://arxiv.org/abs/1407.2909
Linking shape dynamics and loop quantum gravity
Lee Smolin
(Submitted on 10 Jul 2014)
Shape dynamics is a reformulation of general relativity, locally equivalent to Einstein's theory, in which the refoliation invariance of the older theory is traded for local scale invariance. Shape dynamics is here derived in a formulation related to the Ashtekar variables by beginning with a modification of the Plebanski action. The constraints of shape dynamics and their algebra are reproduced in terms of these new variables.
12 pages,
http://arxiv.org/abs/1407.3027
Convergent Y ̃-Map for a new covariant Loop Quantum Gravity formulation and Implicit Reality Condition
Leonid Perlov
(Submitted on 11 Jul 2014)
One of the most important elements in a new spin-foam loop quantum gravity formulation is the map Y: HSU(2)→HSL(2,C). In this paper we provide an alternative improved map Y ̃ . The image of a new map Y ̃ contains the weighted infinite sums of SL(2,C) matrix coefficients. The sums are convergent and their limits are the square integrable functions of SL(2,C) with the measure L2(g,e−|Y|2/ℏη(g)dudY) according to the recently proved Holomorphic Peter-Weyl theorem [2]. We also discuss the consequence of a choice of a unitary principal series instead of the general principal series (sometimes called non-unitary) in EPRL model. The general principal series contains the unitary principal series as a sub-representation and becomes unitary when its parameter ν is real rather than complex. The solution of the simplicity constraint then implicitly makes the Barbero-Immirizi parameter real instead of complex. We call this - an implicit reality condition.
7 pages
http://arxiv.org/abs/1407.3768
Loop Quantum Cosmology with Complex Ashtekar Variables
Jibril Ben Achour, Julien Grain, Karim Noui
(Submitted on 14 Jul 2014)
We construct and study Loop Quantum Cosmology (LQC) when the Barbero-Immirzi parameter takes the complex value γ=±i. We refer to this new quantum cosmology as complex Loop Quantum Cosmology. We proceed in making an analytic continuation of the Hamiltonian constraint (with no inverse volume corrections) from real γ to γ=±i in the simple case of a flat FLRW Universe coupled to a massless scalar field with no cosmological constant. For that purpose, we first compute the non-local curvature operator (defined by the trace of the holonomy of the connection around a fundamental plaquette) evaluated in any spin j representation and we find a new close formula for it. This allows to define explicitly a one parameter family of regularizations of the Hamiltonian constraint in LQC, parametrized by the spin j. It is immediate to see that any spin j regularization leads to a bounce scenario. Then, motivated particularly by previous results on black hole thermodynamics, we perform the analytic continuation of the Hamiltonian constraint defined by γ=±i and j=−1/2+is where s is real. Even if the area spectrum is now continuous, we show that the so-defined complex LQC removes also the original singularity which is replaced by a quantum bounce. In addition, the maximal density and the minimal volume of the Universe are obviously independent of γ. Furthermore, the dynamics before and after the bounce are no more symmetric, which makes a clear distinction between these two phases of the evolution of the Universe.
22 pages
http://arxiv.org/abs/1407.3384
Why do we remember the past and not the future? The 'time oriented coarse graining' hypothesis
Carlo Rovelli
(Submitted on 12 Jul 2014)
Phenomenological arrows of time can be traced to a past low-entropy state. Does this imply the universe was in an improbable state in the past? I suggest a different possibility: past low-entropy depends on the coarse-graining implicit in our definition of entropy. This, in turn depends on our physical coupling to the rest of the world. I conjecture that any generic motion of a sufficiently rich system satisfies the second law of thermodynamics, in either direction of time, for some choice of macroscopic observables. The low entropy of the past could then be due to the way we couple to the universe (a way needed for us doing what we do), hence to our natural macroscopic variables, rather than to a strange past microstate of the world at large.
5 pages. Few equations. An idea
http://arxiv.org/abs/1407.3577
Astrophysical Black Hole horizons in a cosmological context: Nature and possible consequences on Hawking Radiation
George F R Ellis, Rituparno Goswami, Aymen I. M. Hamid, Sunil D. Maharaj
This paper considers the nature of apparent horizons for astrophysical black hole situated in a realistic cosmological context. Using semi-tetrad covariant methods we study the local evolutions of the boundaries of the trapped region in the spacetime. For a collapsing massive star immersed in a cosmology with Cosmic Microwave Background Radiation, we show that the initial 2 dimensional marginally trapped surface bifurcates into inner and outer horizons. The inner horizon is timelike while the continuous CMBR influx into the black hole makes the outer horizon spacelike. We discuss the possible consequences of these features for Hawking radiation in realistic astrophysical contexts.
13 pages, 4 figures
http://arxiv.org/abs/1407.3457
Multiple choices of time in quantum cosmology
Przemyslaw Malkiewicz
(Submitted on 13 Jul 2014)
It is often conjectured that a choice of time function merely sets up a frame for the quantum evolution of gravitational field, meaning that all choices should be in some sense compatible. In order to explore this conjecture (and the meaning of compatibility), we develop suitable tools for determining the relation between quantum theories based on different time functions. First, we discuss how a time function fixes a canonical structure on the constraint surface. The presentation includes both the kinematical and the reduced perspective, and the relation between them. Second, we formulate twin theorems about the existence of two inequivalent maps between any two deparameterizations, a {\it formal canonical} and a {\it coordinate} one. They are used to separate the effect of choice of clock from other effects. We show, in an example, how the spectra of quantum observables are transformed under the change of clock and prove, via a general argument, the existence of choice-of-time-induced semiclassical effects. Finally, we study an example, in which we find that the semiclassical discrepancies can in fact be arbitrarily large for dynamical observables. We conclude that the values of critical energy density or critical volume in the bouncing scenarios of quantum cosmology cannot in general be at the Planck scale and always need to be given with reference to a specific time function.
21 pages, 7 figures
http://arxiv.org/abs/1407.3977
Minimal Coupling and Attractors
David Sloan
(Submitted on 15 Jul 2014)
The effects of minimally coupling a gravity to matter on a flat Robertson-Walker geometry are explored. Particular attention is paid to the evolution of the symplectic structure and the Liouville measure it defines. We show that the rescaling freedom introduced by choice of fiducial cell leads to a symmetry between dynamical trajectories, which together with the Liouville measure provides a natural volume weighting explanation for the generic existence of attractors.
11 pages
"...from the perspective of an observer who only has access to homogeneous local field configurations there is no physical observation of the fields from which this length scale can be deduced. This freedom to rescale leads to a symmetry on the space of solutions. This has been discussed in the context of inflation in Loop Quantum Cosmology [1, 2] and its result in explaining inflationary attractors in [3]…"
refs [1-3] are to LQC papers by Ashtekar, Sloan, and others
http://arxiv.org/abs/1407.4444
Effective constraint algebras with structure functions
Martin Bojowald, Suddhasattwa Brahma
(Submitted on 16 Jul 2014)
This article presents the result that fluctuations and higher moments of a state do not imply quantum corrections in structure functions of constrained systems. Consequences for canonical quantum gravity, whose structure functions encode space-time structure, are discussed. In particular, deformed algebras found in models of loop quantum gravity provide reliable information even in the Planck regime.
16 pages
To see what Bojowald is driving at, note this final passage in the conclusions:
==quote==
...Such ordering terms may affect the details of concrete models based on constraint algebras with deformed structure functions, especially in strong quantum regimes. Nevertheless, our main result that moment-dependent quantum back-reaction terms do not affect the leading structure functions has an important consequence also in this context: In all consistent effective models found so far in the presence of holonomy corrections, the deformed structure functions change sign around any local maximum of holonomies as functions of the connection or extrinsic curvature. (The structure functions are proportional to the second derivative of holonomy modification functions [24, 28, 33].) This change of sign can be interpreted as signature change, with a quantum version of 4-dimensional Euclidean space replacing Lorentzian space-time when the structure functions take the opposite sign [6, 7, 8]. Even if holonomy modification functions are subjected to ℏ-corrections from factor ordering terms, this general conclusion about signature change remains unaltered. (The only assumption in its derivation is that the classical quadratic dependence of the Hamiltonian constraint on the connection or extrinsic curvature is replaced by some function of the basic expectation values, not necessarily of any specific form such as a sine function often used in this context.) Our results therefore show that moment terms do not affect the central statements about signature change.
As we have discussed in Section 2.2, results about effective constraint algebras are reliable in regimes in which semiclassical approximations of the dynamics may be expected to be poor. One can therefore trust implications of deformed algebras even in the Planck regime. The main such result is signature change at high curvature or density.
==endquote==
http://arxiv.org/abs/1407.4792
On the Second Law of Thermodynamics: The Significance of Coarse-Graining and the Role of Decoherence
Mahdiyar Noorbala
(Submitted on 17 Jul 2014)
We take up the question why the initial entropy in the universe was small, in the context of evolution of the entropy of a classical system. We note that coarse-graining is a an important aspect of entropy evaluation which can reverse the direction of the increase in entropy, i.e., the direction of thermodynamic arrow of time. Then we investigate the role of decoherence in the selection of coarse-graining and explain how to compute entropy for a decohered classical system. Finally, we argue that the requirement of low initial entropy imposes constraints on the decoherence process.
4 pages
==quote from conclusions==
Note added. At the time of completion of this work, an independent paper by Rovelli with similar ideas appeared on arXiv [5]. While some of the basic ideas are shared in our works, there are differences as well. The notion of coarse-graining employed in Ref. [5] is different from the one used here. It is related to coarse-graining with fixing macroscopic variables, as discussed in the first paragraph of Section II here. Then the macroscopic observables that are to be used for coarse-graining are picked by interactions among subsystems. Thus in Ref. [5], interactions play the role that decoherence plays here. As we discussed at the end of Section III, decoherence plays this role through interactions as well as system/environment splitting and the quantum state. So there is quite a similarity here.
[5] C. Rovelli, “Why do we remember the past and not the future? The ‘time oriented coarse graining’ hypothesis,” arXiv:1407.3384 [hep-th].
==endquote==
see post #2212 of this thread:
https://www.physicsforums.com/showthread.php?p=4797616#post4797616
http://arxiv.org/abs/1407.4748
Perturbative Quantum Gravity Comes of Age
R. P. Woodard (University of Florida)
I argue that cosmological data from the epoch of primordial inflation is catalyzing the maturation of quantum gravity from speculation into a hard science. I explain why quantum gravitational effects from primordial inflation are observable. I then review what has been done, both theoretically and observationally, and what the future holds. I also discuss what this tells us about quantum gravity.
64 pages, 6 figures, review article written for "One Hundred Years of General Relativity"
http://arxiv.org/abs/1407.4615
Discrete Renormalization Group for SU(2) Tensorial Group Field Theory
Sylvain Carrozza
This article provides a Wilsonian description of the perturbatively renormalizable Tensorial Group Field Theory introduced in arXiv:1303.6772 [hep-th] (Commun. Math. Phys. 330, 581-637). It is a rank-3 model based on the gauge group SU(2), and as such is expected to be related to Euclidean quantum gravity in three dimensions. By means of a power-counting argument, we introduce a notion of dimensionality of the free parameters defining the action. General flow equations for the dimensionless bare coupling constants can then be derived, in terms of a discretely varying cut-off, and in which all the so-called melonic Feynman diagrams contribute. Linearizing around the Gaussian fixed point allows to recover the splitting between relevant, irrelevant, and marginal coupling constants. Pushing the perturbative expansion to second order for the marginal parameters, we are able to determine their behaviour in the vicinity of the Gaussian fixed point. Along the way, several technical tools are reviewed, including a discussion of combinatorial factors and of the Laplace approximation, which reduces the evaluation of the amplitudes in the UV limit to that of Gaussian integrals.
36 pages, 20 figures
http://arxiv.org/abs/1407.5848
Propagating gravitons vs. dark matter in asymptotically safe quantum gravity
Daniel Becker, Martin Reuter
(Submitted on 22 Jul 2014)
Within the Asymptotic Safety scenario, we discuss whether Quantum Einstein Gravity (QEG) can give rise to a semi-classical regime of propagating physical gravitons (gravitational waves) governed by an effective theory which complies with the standard rules of local quantum field theory. According to earlier investigations based on single-metric truncations there is a tension between this requirement and the condition of Asymptotic Safety since the former (latter) requires a positive (negative) anomalous dimension of Newton's constant. We show that the problem disappears using the bi-metric renormalization group flows that became available recently: They admit an asymptotically safe UV limit and, at the same time, a genuine semi-classical regime with a positive anomalous dimension. This brings the gravitons of QEG on a par with arbitrary (standard model, etc.) particles which exist as asymptotic states. We also argue that metric perturbations on almost Planckian scales might not be propagating, and we propose an interpretation as a form of `dark matter'.
http://arxiv.org/abs/1407.5678
Super-radiance and flux conservation
Petarpa Boonserm (Chulalongkorn University), Tritos Ngampitipan (Chulalongkorn University), Matt Visser (Victoria University of Wellington)
(Submitted on 21 Jul 2014)
The theoretical foundations of the phenomenon known as super-radiance still continues to attract considerable attention. Despite many valiant attempts at pedagogically clear presentations, the effect nevertheless still continues to generate some significant confusion. Part of the confusion arises from the fact that super-radiance in a quantum field theory [QFT] context is not the same as super-radiance (super-fluorescence) in some condensed matter contexts; part of the confusion arises from traditional but sometimes awkward normalization conventions, and part is due to sometimes unnecessary confusion between fluxes and probabilities. We shall argue that the key point underlying the effect is flux conservation, (and, in the presence of dissipation, a controlled amount of flux non-conservation), and that attempting to phrase things in terms of reflection and transmission probabilities only works in the absence of super-radiance. To help clarify the situation we present a simple exactly solvable toy model exhibiting both super-radiance and damping.
http://arxiv.org/abs/1407.5977
Is Quantum Gravity a Chern-Simons Theory?
R. Bonezzi, O. Corradini, A. Waldron
We propose a model of quantum gravity in arbitrary dimensions defined in terms of the BV quantization of a supersymmetric, infinite dimensional matrix model. This gives an (AKSZ-type) Chern-Simons theory with gauge algebra the space of observables of a quantum mechanical Hilbert space H. The model is motivated by previous attempts to formulate gravity in terms of non-commutative, phase space, field theories as well as the Fefferman-Graham curved analog of Dirac spaces for conformally invariant wave equations. The field equations are flat connection conditions amounting to zero curvature and parallel conditions on operators acting on H. This matrix-type model may give a better defined setting for a quantum gravity path integral. We demonstrate that its underlying physics is a summation over Hamiltonians labeled by a conformal class of metrics and thus a sum over causal structures. This gives in turn a model summing over fluctuating metrics plus a tower of additional modes-we speculate that these could yield improved UV behavior
http://arxiv.org/abs/1407.6010
Inflation Driven by Unification Energy
Mark P. Hertzberg, Frank Wilczek
We examine the hypothesis that inflation is primarily driven by vacuum energy at a scale indicated by gauge coupling unification. Concretely, we consider a class of hybrid inflation models wherein the vacuum energy associated with a grand unified theory condensate provides the dominant energy during inflation, while a second "inflaton" scalar slow-rolls. We show that it is possible to obtain significant tensor-to-scalar ratios while fitting the observed spectral index.
5 double column pages, 1 figure
http://arxiv.org/abs/1407.6928
Quantum Cellular Automaton Theory of Light
Authors: Alessandro Bisio, Giacomo Mauro D'Ariano, Paolo Perinotti
(Submitted on 25 Jul 2014)
Abstract: We present a quantum theory of light based on quantum cellular automata (QCA). This approach allows us to have a thorough quantum theory of free electrodynamics encompassing an hypothetical discrete Planck scale. The theory is particularly relevant because it provides predictions at the macroscopic scale that can be experimentally tested. We show how, in the limit of small wave-vector k, the free Maxwell's equations emerge from two Weyl QCAs derived from informational principles in Ref. [1]. Within this framework the photon is introduced as a composite particle made of a pair of correlated massless Fermions, and the usual Bosonic statistics is recovered in the low photon density limit. We derive the main phenomenological features of the theory, consisting in dispersive propagation in vacuum, the occurrence of a small longitudinal polarization, and a saturation effect originated by the Fermionic nature of the photon. We then discuss whether these effects can be experimentally tested, and observe that only the dispersive effects are accessible with current technology, from observations of arrival times of pulses originated at cosmological distances.
http://arxiv.org/abs/1407.7149
Self-gravitating Interferometry and Intrinsic Decoherence
Cisco Gooding, William G. Unruh
(Submitted on 26 Jul 2014)
To investigate the possibility that intrinsic gravitational decoherence can be theoretically demonstrated within canonical quantum gravity, we develop a model of a self-gravitating interferometer. We search for evidence in the resulting interference pattern that would indicate coherence is fundamentally limited due to general relativistic effects. To eliminate the occurrence of gravitational waves, we work in spherical symmetry, and construct the "beam" of the interferometer out of WKB states for an infinitesimally thin shell of matter. For internal consistency, we encode information about the beam optics within the dynamics of the shell itself, by arranging an ideal fluid on the surface of the shell with an equation of state that enforces beam-splitting and reflections. We then determine sufficient conditions for (interferometric) coherence to be fully present even after general relativistic corrections are introduced, test whether or not they can be satisfied, and remark on the implications of the results.
16 pages, 6 figures
http://arxiv.org/abs/1407.7295
Physical observability of horizons
(Submitted on 28 Jul 2014)
Event horizons are (generically) not physically observable. In contrast, apparent horizons (and the closely related trapping horizons) are generically physically observable --- in the sense that they can be detected by observers working in finite-size regions of spacetime. Consequently event horizons are inappropriate tools for defining astrophysical black holes, or indeed for defining any notion of evolving}black hole, (evolving either due to accretion or Hawking radiation). The only situation in which an event horizon becomes physically observable is for the very highly idealized stationary or static black holes, when the event horizon is a Killing horizon which is degenerate with the apparent and trapping horizons; and then it is the physical observability of the apparent/trapping horizons that is fundamental --- the event horizon merely comes along for the ride.
4 pages
http://arxiv.org/abs/1407.7243
The Evolving Block Universe and the Meshing Together of Times
George F R Ellis
(Submitted on 27 Jul 2014)
It is proposed that spacetime should be regarded as an evolving block universe, bounded to the future by the present time, which continually extends to the future. This future boundary is defined at each time by measuring proper time along Ricci eigenlines from the start of the universe. A key point is that physical reality can be represented at many different scales: hence the passage of times may be seen as different at different scales, with quantum gravity determining the evolution of space time itself but quantum field theory determining the evolution of events within spacetime .The fundamental issue then arises as to how the effective times at different scales mesh together, leading to the concept so global and local times.
23 pages,4 figures
http://arxiv.org/abs/1407.6993
Asymptotically Safe Higgs Inflation
Zhong-Zhi Xianyu, Hong-Jian He
We construct a new inflation model in which the standard model Higgs boson couples minimally to gravity and acts as the inflaton. Our construction of Higgs inflation incorporates the standard model with Einstein gravity which exhibits asymptotic safety in the ultraviolet region. The slow roll condition is satisfied at large field value due to the asymptotically safe behavior of Higgs self-coupling at high energies. We find that this minimal construction is highly predictive, and is consistent with both cosmological observations and collider experiments.
http://arxiv.org/abs/1407.7746
On background-independent renormalization of spin foam models
Benjamin Bahr
(Submitted on 29 Jul 2014)
In this article we discuss an implementation of renormalization group ideas to spin foam models, where there is no a priori length scale with which to define the flow. In the context of the continuum limit of these models, we show how the notion of cylindrical consistency of path integral measures gives a natural analogue of Wilson's RG flow equations for background-independent systems. We discuss the conditions for the continuum measures to be diffeomorphism-invariant, and consider both exact and approximate examples.
23 pages, 12 figures
http://arxiv.org/abs/1407.7766
Quantum collapse rules from maximum relative entropy principle
Frank Hellmann, Wojciech Kamiński, Ryszard Paweł Kostecki
We show that the von Neumann--Lueders collapse rules in quantum mechanics always select the unique state that maximises the quantum relative entropy with respect to the premeasurement state, subject to the constraint that the postmeasurement state has to be compatible with the knowledge gained in the measurement. This way we provide an information theoretic characterisation of quantum collapse rules by means of the maximum relative entropy principle.
5 pages.
[my comment: Kostecki has an interest in quantum geometry, with work in preparation provisionally titled Towards quantum information geometric foundations. All three authors have published papers in QG]
http://arxiv.org/abs/1407.7544
Re-Examining Astrophysical Constraints on the Dark Matter Model
Alyson Brooks
Recent high-resolution simulations that include Cold Dark Matter (CDM) and baryons have shown that baryonic physics can dramatically alter the dark matter structure of galaxies. These results modify our predictions for observed galaxy evolution and structure. Given these updated expectations, it is timely to re-examine observational constraints on the dark matter model. A few observations are reviewed that may indirectly trace dark matter, and may help confirm or deny possible dark matter models. Warm Dark Matter (WDM) and Self-Interacting Dark Matter (SIDM) are currently the favorite alternative models to CDM. Constraints on the WDM particle mass require it to be so heavy that WDM is nearly indistinguishable from CDM. The best observational test of SIDM is likely to be in the dark matter distribution of faint dwarf galaxies, but there is a lack of theoretical predictions for galaxy structure in SIDM that account for the role of baryons.
10 pages. Invited review article, accepted for publication in Annalen der Physik.
http://arxiv.org/abs/1407.8166
Loop quantum cosmology from group field theory
Gianluca Calcagni
(Submitted on 30 Jul 2014)
We show that the effective dynamics of the recently proposed isotropic condensate state of group field theory (GFT) with Laplacian kinetic operator can be equivalent to that of homogeneous and isotropic loop quantum cosmology (LQC) in the improved dynamics quantization scheme, where the area of elementary holonomy plaquettes is constant. This constitutes a somewhat surprising example of a cosmological model of quantum gravity where the operations of minisuperspace symmetry reduction and quantization can actually commute.
5 pages
http://arxiv.org/abs/1407.8167
Quantum cosmology from quantum gravity condensates: cosmological variables and lattice-refined dynamics
Steffen Gielen, Daniele Oriti
In the context of group field theory condensate cosmology, we clarify the extraction of cosmological variables from the microscopic quantum gravity degrees of freedom. We show that an important implication of the second quantized formalism is the dependence of cosmological variables and equations on the quantum gravitational atomic number N (number of spin network vertices/elementary simplices). We clarify the relation of the effective cosmological equations with loop quantum cosmology, understood as an effective (hydrodynamic-like) approximation of a more fundamental quantum gravity theory. By doing so, we provide a fundamental basis to the idea of lattice refinement, showing the dependence of the effective cosmological connection on N, and hence indirectly on the scale factor. Our results open a new arena for exploring effective cosmological dynamics, as this depends crucially on the new observable N, which is entirely of quantum gravitational origin.
6 pages
http://arxiv.org/abs/1407.8143
Realization of DSR-relativistic symmetries in Finsler geometries
Giovanni Amelino-Camelia, Leonardo Barcaroli, Giulia Gubitosi, Stefano Liberati, Niccoló Loret
Finsler geometry is a well known generalization of Riemannian geometry which allows to account for a possibly non trivial structure of the space of configurations of relativistic particles. We here establish a link between Finsler geometry and the sort of models with curved momentum space and DSR-relativistic symmetries which have been recently of interest in the quantum-gravity literature. We use as case study the much-studied scenario which is inspired by the κ-Poincaré quantum group, and show that the relevant deformation of relativistic symmetries can be implemented within a Finsler geometry.
26 pages.
http://arxiv.org/abs/1407.8084
How well is our universe described by an FLRW model?
Stephen R. Green, Robert M. Wald
Extremely well! The spacetime metric, gab, of our universe is approximated by an FLRW metric, g(0)ab, to about 1 part in 104 or better on both large and small scales, except in the immediate vicinity of very strong field objects, such as black holes. However, derivatives of gab are not close to derivatives of g(0)ab, so there can be significant differences in the behavior of geodesics and huge differences in curvature. Consequently, observable quantities in the actual universe may differ significantly from the corresponding observables in the FLRW model. Nevertheless, as we shall review here, we have proven general results showing that the large matter inhomogeneities that occur on small scales cannot produce significant backreaction effects on large scales, so g(0)ab satisfies Einstein's equation with the averaged stress-energy tensor of matter as its source. We discuss the flaws in some other approaches that have suggested that large backreaction effects may occur. As we also will review here, with a suitable "dictionary," Newtonian cosmologies provide excellent approximations to cosmological solutions to Einstein's equation (with dust and a cosmological constant) on all scales.
18 pages, 2 figures.
http://arxiv.org/abs/1407.8058
If time is a local observable, then Hawking radiation is unitary
H. Nikolic
In the usual formulation of quantum theory, time is a global classical evolution parameter, not a local quantum observable. On the other hand, both canonical quantum gravity (which lacks fundamental time-evolution parameter) and the principle of spacetime covariance (which insists that time should be treated on an equal footing with space) suggest that quantum theory should be slightly reformulated, in a manner that promotes time to a local observable. Such a reformulated quantum theory is unitary in a more general sense than the usual quantum theory. In particular, this promotes the non-unitary Hawking radiation to a unitary phenomenon, which avoids the black-hole information paradox.
11 pages, accepted for publication in Int. J. Quantum Inf.
http://arxiv.org/abs/1407.8028
The trivial solution of the gravitational energy-momentum tensor problem
H. Nikolic
In the literature one often finds the claim that there is no such thing as an energy-momentum tensor for the gravitational field, and consequently, that the total energy-momentum conservation can only be defined in terms of a gravitational energy-momentum pseudo-tensor. I make a trivial observation that such a conclusion can be avoided by relaxing the assumption that gravitational energy-momentum tensor should only depend on first derivatives of the metric. With such a relaxation, the Einstein equation directly leads to the result that gravitational energy-momentum tensor is essentially the Einstein tensor.
5 pages
http://arxiv.org/abs/1407.7896
Emergent gravitational dynamics in relativistic Bose--Einstein condensate
Alessio Belenchia, Stefano Liberati, Arif Mohd
22 pages.
http://arxiv.org/abs/1407.7891
Planck-scale soccer-ball problem: a case of mistaken identity
5 pages.
http://arxiv.org/abs/1408.0121
Thermally correlated states in Loop Quantum Gravity
Goffredo Chirco, Carlo Rovelli, Paola Ruggiero
(Submitted on 1 Aug 2014)
We study a class of loop-quantum-gravity states characterized by (ultra-local) thermal correlations that reproduce some features of the ultraviolet structure of the perturbative quantum field theory vacuum. In particular, they satisfy an analog of the Bisognano-Wichmann theorem. These states are peaked on the intrinsic geometry and admit a semiclassical interpretation. We study how the correlations extend on the spin-network beyond the ultra local limit.
11 pages, 4 figures
http://arxiv.org/abs/1408.0276
Asymptotic safety and the cosmological constant
Kevin Falls
We study the non-perturbative renormalisation of quantum gravity in four dimensions. Taking care to disentangle physical degrees of freedom, we observe the topological nature of conformal fluctuations arising from the functional measure. The resulting beta functions possesses an asymptotically safe fixed point with a global phase structure leading to classical general relativity for positive, negative or vanishing cosmological constant. If only the conformal fluctuations are quantised we find an asymptotically safe fixed point predicting a vanishing cosmological constant on all scales. At this fixed point we reproduce the critical exponent, ν=1/3, found in numerical lattice studies by Hamber. This suggests the fixed point may be physical while solving the cosmological constant problem.
34 pages, 9 figures
brief mention:
http://arxiv.org/abs/1408.0156
Inflation, quintessence, and the origin of mass
C.Wetterich
In a unified picture both inflation and present dynamical dark energy arise from the same scalar field. The history of the Universe describes a crossover from a scale invariant "past fixed point" where all particles are massless, to a "future fixed point" where spontaneous breaking of the exact scale symmetry generates the particle masses. The cosmological solution can be extrapolated to the infinite past in physical time - the universe has no beginning. This is seen most easily in a frame where particle masses and the Planck mass are field-dependent and increase with time…
...A simple model with no more free parameters than ΛCDM is compatible with all present observational tests.
21 pages, 3 figures
http://arxiv.org/abs/1408.0710
Exact solutions of the Wheeler-DeWitt equation and the Yamabe construction
Eyo Ita, Chopin Soo
Exact solutions of the Wheeler-DeWitt equation of the full theory of four dimensional gravity of Lorentzian signature are obtained. They are characterized by Schrödinger wavefunctionals having support on 3-metrics of constant spatial scalar curvature, and thus contain two full physical field degrees of freedom in accordance with the Yamabe construction. These solutions are moreover Gaussians of minimum uncertainty and they are naturally associated with a rigged Hilbert space. In addition, in the limit the regulator is removed, exact 3-dimensional diffeomorphism and local gauge invariance of the solutions are recovered.
13 Pages
http://arxiv.org/abs/1408.0778
Cosmic Matter Flux May Turn Hawking Radiation Off
Javad T. Firouzjaee, George F. R. Ellis
(Submitted on 4 Aug 2014)
An astrophysical (cosmological) black hole forming in a cosmological context will be subject to a flux of infalling matter and radiation, which will cause the outer apparent horizon (a marginal trapping surface) to be spacelike [5]. As a consequence the radiation emitted close to the apparent horizon no longer arrives at infinity with a diverging redshift. Standard calculations of the emission of Hawking radiation then indicate that no blackbody radiation is emitted to infinity by the black hole in these circumstances, hence there will also then be no black hole evaporation process due to emission of such radiation as long as the matter flux is significant. The essential adiabatic condition (eikonal approximation) for black hole radiation gives a strong limit to the black holes that can emit Hawking radiation. We give the mass range for the black holes that can radiate, according to their cosmological redshift, for the special case of the cosmic blackbody radiation (CBR) influx (which exists everywhere in the universe). At a very late stage of black hole formation when the CBR influx decays away, the black hole horizon becomes first a slowly evolving horizon and then an isolated horizon; at that stage, black hole radiation will start. This study suggests that the primordial black hole evaporation scenario should be revised to take these considerations into account.
21 pages.
http://arxiv.org/abs/1408.1238
Non-singular Cosmology from Evolutionary Quantum Gravity
Francesco Cianfrani, Giovanni Montani, Fabrizio Pittorino
(Submitted on 6 Aug 2014)
We provide a cosmological implementation of the evolutionary quantum gravity, describing an isotropic Universe, in the presence of a negative cosmological constant and a massive (pre-inflationary) scalar field. We demonstrate that the considered Universe has a non-singular quantum behavior, associated to a primordial bounce, whose ground state has a high occupation number. Furthermore, in such a vacuum state, the super-Hamiltonian eigenvalue is negative, corresponding to a positive emerging dust energy density. The regularization of the model is performed via a polymer quantum approach to the Universe scale factor and the proper classical limit is then recovered, in agreement with a pre-inflationary state of the Universe. Since the dust energy density is red-shifted by the Universe de-Sitter phase and the cosmological constant does not enter the ground state eigenvalue, we get a late time cosmology, at all compatible with the present observations, endowed with a turning point in the far future.
16 pages, 8 figures
http://arxiv.org/abs/1408.1449
Topological quantum field theory and quantum gravity
Steven Kerr
(Submitted on 7 Aug 2014)
This thesis is broadly split into two parts. In the first part, simple state sum models for minimally coupled fermion and scalar fields are constructed on a 1-manifold. The models are independent of the triangulation and give the same result as the continuum partition functions evaluated using zeta-function regularisation. Some implications for more physical models are discussed.
In the second part, the gauge gravity action is written using a particularly simple matrix technique. The coupling to scalar, fermion and Yang-Mills fields is reviewed, with some small additions. A sum over histories quantisation of the gauge gravity theory in 2+1 dimensions is then carried out for a particular class of triangulations of the three-sphere. The preliminary stage of the Hamiltonian analysis for the (3+1)-dimensional gauge gravity theory is undertaken.
http://arxiv.org/abs/1408.1444
Modelling the Evaporation of Non-singular Black Holes
Tim Taves, Gabor Kunstatter
We present a model for studying the formation and evaporation of non-singular (quantum corrected) black holes. The model is based on a generalized form of the dimensionally reduced, spherically symmetric Einstein-Hilbert action and includes a suitably generalized Polyakov action to provide a mechanism for radiation back-reaction. The equations of motion describing self-gravitating scalar field collapse are derived in local form both in null coordinates and in Painleve-Gullstrand (flat slice) co-ordinates. They provide the starting point for numerical studies of complete spacetimes containing dynamical horizons that bound a compact trapped region. Such spacetimes have been proposed in the past as solutions to the information loss problem because they possesses neither an event horizon nor a singularity. Since the equations of motion in our model are derived from a diffeomorphism invariant action, they preserve the constraint algebra and the resulting energy momentum tensor is manifestly conserved.
14 pages
http://arxiv.org/abs/1408.1994
Gauge theory of gravity and matter
Steven Kerr
(Submitted on 8 Aug 2014)
It is shown how to write the first order action for gravity in a gauge theoretic formalism where the spin connection and frame field degrees of freedom are assimilated together into a gauge connection. It is then shown how to couple the theory to spin-0, 1/2, 1 and 3/2 fields in a gauge invariant fashion. The results hold in any number of spacetime dimensions.
20 pages.
http://arxiv.org/abs/1408.2503
Checking the dark matter origin of 3.53~keV line with the Milky Way center
Alexey Boyarsky, Jeroen Franse, Dmytro Iakubovskyi, Oleg Ruchayskiy
(Submitted on 11 Aug 2014)
We detect a line at 3.539±0.011 keV in the deep exposure dataset of the Galactic Center region, observed with the XMM-Newton. Although it is hard to exclude completely astrophysical origin of this line in the Galactic Center data alone, the dark matter interpretation of the signal observed in Perseus galaxy cluster and Andromeda galaxy [1402.4119] and in the stacked spectra of galaxy clusters [1402.2301] is fully consistent with these data. Moreover, the Galactic Center data support this interpretation as the line is observed at the same energy and has flux consistent with the expectations about the Galactic dark matter distribution for a class of the Milky Way mass models.
10 pages, 4 figures, 3 tables
