Loop current method sign error in bridge circuit loop B
  • Thread starter guyvsdcsniper
    Resistors
6 replies · 2K views · last reply
guyvsdcsniper
Use the loop current method on bridge circuit to generate 3 loop equations
Kirchoff's law
Attached is the example I am working out of a textbook that involves using the Loop Current Method on a bridge circuit. In the pictures attached I am following section 1.6.2 which produces loop equations (1.24) for figure 1.9. Figure 1.7 provides the direction of current.
I am having trouble producing the same result as the book I am using for Loop B and C.
Following Loop A, we travel up the EMF,
##\varepsilon##, and then we reach ##R_1##. At this resistor, ##I_a## travels down the resistor and ##I_b## travels up it. Likewise, at ##R_3## ##I_a## travels down the resistor and ##I_c## travels up it. Traveling down the resistor leads to a drop in voltage which leads to a negative sign in associated with that voltage.
Following this logic, I receive the same equation for Loop A as seen in equation 1.24.
So now when evaluating Loop B, I will begin at Node 4. Again, at ##R_1## ##I_a## travels down the resistor and ##I_b## travels up it. This produces ##R_1I_b-R_1I_a##. Next we go down resistor ##R_2## and get ##-R_2I_b##. Finally we have resistor ##R_5##. ##I_b## travels up and ##I_c## travels down this resistor, giving ##R_5I_b-R_5I_c##. Simplifying this and setting it equal to zero gives:
$$-R_1[I_a-I_b]-R_2I_b-R_5[I_c-I_b]=0$$.
So my logic works for Loop A but for Loop B, this logic produces the opposite of what the book gives for the resistors that contain a superposition of current.
Could someone help me understand how I am approaching this wrong?
  • Bridge circuit diagram with resistors R1 to R5, battery EMF, nodes 1 to 4, and loop currents Ia, Ib and Ic marked as arrows, from a printed textbook page.
  • Printed textbook page showing the end of equation 1.23 with node equations, section 1.6.2 on the loop current method, and loop equations 1.24 for loops A, B and C of the bridge circuit.
  • Bridge circuit diagram with a battery of EMF epsilon and resistors R1 through R5, labeled with six currents I, I1, I2, I3, I4 and I5, with the external current I shown entering and leaving the bridge.
I'm not following your steps there. The references to up/down and the relationship to the signs are unclear.
Going clockwise around the loop, ##I_b## always has the same sign. You have
##R_1I_b-R_1I_a##, ##R_2I_b##, ##R_5I_b-R_5I_c##
So I disagree with your sign for ##R_2I_b##.
Well I was assuming that the current traveling through this circuit will follow the path as described in figure 1.7. I used that to assign the voltage drop polarities. So the positive end of the resistors are where the current enters and the negative end is where the current exits.
So when following the loop upward, we are going from the negative end to the positive end of the resistor, giving a positive voltage and vice versa.
I agree with your method, but somehow you are getting a wrong sign. I can’t pinpoint where without seeing your steps in gory detail.
I can see the potential for confusion from all those minus signs.
Do you see that all the ##I_b## terms should have the same sign in a given loop?
Hopefully this makes my thought process clear. I tried breaking down how I viewed each resistor when traveling loop B.
  • Handwritten bridge circuit with resistors R1 to R5, nodes 1 to 4, loop currents IA, IB, IC, and a handwritten Loop A equation and Loop B derivation with sign annotations per resistor.
I am finding that I only get the same result as the book when I assign the voltage drop polarity with respect to the loop I am following.
So when I follow Loop A clockwise, I get the assigned voltage polarity as seen in my previous post.
But when I start at node 4, and follow loop B and treat it as the direction current is traveling, this switches the polarity of ##R_1## and ##R_5## and gives me the same result as the book (1.24).
Could this be the problem I am encountering? It seems as thought voltage drop polarity with the "Loop Current Method" is dependent on the direction of the loop.EDIT:
This may seem convoluted but I think this explanation makes sense. Given the name of the method "Loop Current" I think its treating the direction of each respective loop as the current. So you have to determine the voltage drop polarity for each individual loop.
  • Handwritten bridge circuit diagram with three loop currents labelled A, B and C, resistors R1, R2, R3 and R5, and red polarity signs across the resistors; below it are two handwritten Kirchhoff voltage equations in terms of R1, R2, R5 and the loop currents.
