How Do You Calculate Idle and Blocking Probabilities in M/D/1/n Queues?
  • Thread starter Thread starter Turboshortbus
    Theory
Calculating idle and blocking probabilities in M/D/1/n queues involves understanding the Poisson arrival process and deterministic service process. The blocking probability can be determined by assessing when the arrival rate exceeds service capacity, while the idle probability occurs when the arrival rate is below service capacity. Average waiting time can be derived using formulas like the Pollaczek-Khinchine formula for boundary cases, but specific calculations for finite buffers require additional insights, such as Little's Theorem. Resources and references are available online for further study, and the calculations can be complex, often necessitating the use of statistical software or calculators. Efficient service processes are crucial to minimize queues and avoid customer losses.
Turboshortbus
Hello PF,
I have an assignment on M/D/1/n queues and between all the formulas and theory, I am completely lost. I need to be able to calculate the idle probability, blocking probability, and average waiting time for different buffer sizes n (0,1,4, etc.). I can find the answers for the boundary cases 0 and infiniti, but its the others I am clueless. Can anyone give me some tips to point me in the right direction?
Turboshortbus said:
Hello PF,
I have an assignment on M/D/1/n queues and between all the formulas and theory. I am completely lost. I need to be able to calculate the idle probability, blocking probability, and average waiting time for different buffer sizes n (0,1,4, etc.). I can find the answers for the boundary cases 0 and infiniti, but its the others I am clueless. Can anyone give me some tips to point me in the right direction?
With the M/D/n type queue you usually have a Poisson arrival process and a deterministic service process. For any given \lambda (mean arrival rate) you can calculate the probability that the actual rate of arrivals exceeds the service capacity using the Poisson distribution. Calculators are available online or in statistical software. This would be the blocking probability. The idle probability is when the arrival rate falls below the service capacity leaving at least one server idle. The stationary state is when the system is in equilibrium. Average waiting time is just 1/\lambda and k/\lambda is the average waiting time for the kth entity in the buffer. The buffer is simply the "waiting room" or allowable queue. The blocking probability is usually adjusted so that blocking only occurs when the buffer is full.
There's quite a few papers and articles available if you google queuing therory or Erlang's formulas.
Spelling and typo corrections: Apparently the word is "queueing" but my spellcheck accepts "queuing" and not "queueing". "Theory" is just a typo.
I have determined my utilizations and chance of blocking for various n size buffers but I am unsure how to calculate the estimated waiting times. I can use the pollaczek kinchen formula for n = 0 and infiniti but am unsure how to find the W(n) for finite buffers...any pointers anyone?
I think I should use Little's Theorem, but I don't have a formula for the queue length in a M/D/1/n system.
It doesn't look like anyone else is going to respond to your question so you'll have to put up with (or ignore) me just one more time. First this reference:
http://spiderman-2.laas.fr/esquimaux/Documents/md1n-transitoire.pdf
Note some of the formulas refer to the probability mass function of the Poisson distribution. The calculations are tedious and most people use tables or calculators.
I outlined a direction for a steady state solution in my last post which either you did not understand or found too superficial. I suspect the former because you keep asking for a solution for W(n) without specifying whether it's the mean waiting time or the distribution of waiting times. Waiting time is a random variable in this kind of queue.
In the steady state, the mean waiting time for the first arrival will be zero if the service process is efficient. However, because the arrival process is a random variable with a mean \lambda there will be queues as well as idle time for a fixed service capacity at various points. To make such a system more efficient a buffer is created that holds arrivals when queues develop which are then served during what would otherwise be idle time for the service process. I explained how to calculate the expected waiting time for the kth customer in the buffer in my last post.
It's clear that an inefficient service process will lead to an ever growing queue or to a long term excess service capacity. In a customer oriented situation, the former leads to customer losses because real queues are finite and the latter leads to financial losses.
You may know all of this, in which case others might be interested.
First trick I learned this one a long time ago and have used it to entertain and amuse young kids. Ask your friend to write down a three-digit number without showing it to you. Then ask him or her to rearrange the digits to form a new three-digit number. After that, write whichever is the larger number above the other number, and then subtract the smaller from the larger, making sure that you don't see any of the numbers. Then ask the young "victim" to tell you any two of the digits of the...
  • · Replies 29 ·
  • · Replies 16 ·
