When Does Particle Population Size Shift from Microscopic to Macroscopic?
  • Context: Graduate
  • Thread starter Thread starter BillTre
    Macroscopic
The discussion centers on the transition from microscopic to macroscopic particle populations in the context of thermodynamics and statistical mechanics. It highlights that while individual particles exhibit distinct behaviors, a population of approximately 100 units can be considered bulk, as established in a past MSc thesis in quantum chemistry. The conversation emphasizes the significance of finite-size effects and the thermodynamic limit, particularly in applications like nanotechnology, where properties of materials, such as nanoscale gold, differ significantly from their bulk counterparts. The unique optical properties of nanoscale gold particles, which can appear red or purple, exemplify these differences.
  • Understanding of thermodynamics and statistical mechanics
  • Familiarity with nanotechnology concepts
  • Knowledge of quantum chemistry principles
  • Basic optics and light interaction with materials
  • Research the thermodynamic limit and its implications in statistical mechanics
  • Explore the unique properties of nanoscale materials, focusing on nanoscale gold
  • Study finite-size effects in thermodynamic properties
  • Investigate the role of particle population size in determining material behavior
Researchers in physics and chemistry, materials scientists, and professionals working in nanotechnology who seek to understand the transition of particle behavior from microscopic to macroscopic scales.
BillTre
In biology and optics, macroscopic and microscopic are distinguished by being large enough (or not) to be seen by the unaided eye (or almost), vs. requiring a microscope rather than just a hand lens (or macrolense).
Fairly small things (like paramecia) can be easily seen without a microscope, depending on the lighting and other aspects of the setting.
In physics (as I understand it) these terms are used to distinguish between the thermodynamically driven behavior of large populations of particles (like a population of gas molecules) vs. the detailed behavior of each individual particle (microscopic; very data intensive).
What are the considerations with respect to this thermodynamics view, on when an increasing number of particles (particle population size) result in it being more appropriate to consider them as a population of particles rather than a collection of several single particles, each with its own distinguishable behavior?
Not expecting a sharp cut-off.
Back in eighties a friend of mine as part of his MSc thesis in quantum chemistry tried to calculate how some selected property changed with the size. Sadly the only thing I remember is that the conclusion was "for this particular substance, for this particular property, for this particular approach crystal larger than made of 100 units can be considered bulk".
So at least the question isn't new :wink:
I suppose one way that has been taken is to ask about the magnitude of finite-size effects. Calculations in this vein are usually done in increasing powers of inverse volume. Sort of a power series around the thermodynamic limit.
normal engineering thermodynamics (tanks of gas, heat engines built with cylinders and pistons) consider collections of ~10^23 molecules. That's why it works: the numbers are so inconceivably large that no individual effects remain.
This concenpt gets discussed in chemistry in the context of nanotechnology (and how at small enough size scales, the properties of substances can be very different from the bulk material). For example,
Nanoscale gold illustrates the unique properties that occur at the nanoscale. Nanoscale gold particles are not the yellow color with which we are familiar; nanoscale gold can appear red or purple. At the nanoscale, the motion of the gold’s electrons is confined. Because this movement is restricted, gold nanoparticles react differently with light compared to larger-scale gold particles.
https://www.nano.gov/nanotech-101/special
Perhaps the site cited above and other similar texts on nanotechnology could be good sources to consult on this issue.
A rough criterion takes into account the size of fluctuations in the thermodynamic properties of interest that follow from the statistical-mechanical approach: http://farside.ph.utexas.edu/teaching/sm1/lectures/node8.html
  • · Replies 62 ·
11K
