Magnetostatics: Magnetic Vector Potential
The discussion revolves around the magnetic vector potential and magnetic fields generated by current-carrying wires, specifically focusing on an infinite wire and later extending to two wires with opposing currents. The participants explore the mathematical relationships and equations governing these concepts.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of Ampere's Law to derive the magnetic field and the corresponding vector potential. There is an exploration of simplifying assumptions, such as the magnetic vector potential being a function of radius only. Questions arise about the conditions necessary for these assumptions to hold and the implications of the direction of current on the vector potential.
The discussion is active, with participants providing guidance on simplifying the equations and addressing the setup for multiple wires. There is acknowledgment of the need to consider the direction of currents and how they affect the vector potential. Some participants express appreciation for the assistance received, indicating a collaborative atmosphere.
Participants reference specific problems from a document and discuss constraints related to the setup of the magnetic vector potential, including the need for approximations in certain scenarios. The discussion includes the assumption that the distance between wires is small compared to the observation point.
KEØM
Give an expression for the magnetic field and show that a magnetic vector exists such as \vec{A}(P) = A(r)\hat{z} and \vec{B}(P) = \vec{\nabla} \times \vec{A}
For the infinite wire shown in figure 1.
Here is a link to the figure and problem statement. The problem is the second problem on the first page.
https://docs.google.com/fileview?id...UtOGNkYi00ZGQyLTkxOTktNWVjYzM2MGViNDg3&hl=en"
\vec{\nabla} \times \vec{A} = \left(\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z}\right)\hat{r} + \left(\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r}\right)\hat{\theta} + \frac{1}{r}\left(\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta}\right)\hat{z} curl in polar coordinates
\oint \vec{B} \cdot d\vec{l} = \mu_{0}I_{enc} Ampere's Law
First we must solve for the magnetic field at point P. Using Ampere's Law we get,
\vec{B}(P) = \frac{\mu_{0}I}{2\pi r}\hat{\theta} where the positive theta direction is into the page.
Now in order to find A we can set the curl equations equal to the magnetic field equation by curl(A) = B.
Doing so gives,
\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z} = 0
\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r} = \frac{\mu_{0}I}{2\pi r}
\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta} = 0
The answer to this problem (given to us by our instructor) is,
\vec{A} = \left(-\frac{\mu_{0}I}{2\pi}ln(r) + K \right)\hat{z}
and the only way I can get there is by saying that because A points most often in the direction of the current (which is the z direction in this case) then,
-\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}.
Then solving this differential equation gives the desired result.
Can someone please point me in the right direction as to how solve this problem in a more rigorous manner?
Do I need to use the equation \vec{A} = \frac{\mu_{0}}{4\pi}\int \frac{\vec{J}(\vec{r'})}{r}d\tau '?Many Thanks in advance,
KEØM
You already know that:
A_r = 0
and
A_{\theta} = 0
and
A_z = A(r)
since it was given to you in the problem. This simplifies your 3 diff eq's quite a bit.
Thanks for your reply nickjer. So because A is a function of only r then all other derivatives go away and because it is only in the z direction then all other components are equal to zero. This then allows me to let -\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}. Is there anything else I must say for that condition to be satisfied?
Thanks again,
KEØM
nope that does it:
\vec{\nabla} \times \vec{A}=-\frac{dA_{z}}{dr}
thus -\frac{dA_{z}}{dr}=\frac{\mu_{0}I}{2\pi r}\hat{\theta}
Thanks! I really appreciate the help kreil and nickjer.
KEØM
I now have a question concerning the third problem on that page attached.
Problem Statement:
We consider now two wires of axis (O,z) and separated by the distance (2a). The currents in the two wires are +I and -I (see figure). Show that the expression of the magnetic potential vector \vec{A}(P) is given by
\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)\hat{z}
(the observation point is located at P(r, \theta, z=0)). Note: The constant of integration is integration obtained by taking \vec{A}(O) = 0.
Relevant Equations:
Same as previous problem.
Attempt at a solution:
For this problem can I say the same as before? He did say that our answer should be of the form \vec{A}(P) = A(r)\hat{z}.
Thanks in advance.
You solved for the vector potential from a single wire. So for two wires you will just add the vector potentials from each. But be careful with the direction of each of the vectors.
I know from just looking at the answer that the -I current must be in the positive z-direction and the +I current must be in the negative z-direction but I don't know why.
In the first problem you solved \vec{A} for a current going in the +z direction. So use that to solve this next problem.
I think I got it. So because +I flows in the positive direction it must be negative and the opposite must be true for the wire with -I.
One more question:
For problem 4 on that document it says,
Problem Statement
The wires are now very close to each other. Determine \vec{A}(r,\theta) such as r >> a and by keeping the first and second order terms in (a/r).
Remember that (1 + \epsilon)^{n} = 1 + n\epsilon
and ln(1 + \epsilon) = \epsilon, \epsilon << 1
Now I know he wants us to approximate the answer by expanding\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)
with a Taylor Expansion in \epsilon = \frac{a}{r} << 1 but I don't see how to do this when the distance between the wires 2a never comes up in any of our answers.
I really appreciate all the help nickjer.
Now you will need to write out r_1 and r_2 in terms of r and a. I suggest using the law of cosines.
OK. Thanks again for all of your help nickjer.
