Manipulating an inequality in the bisection method
The forum discussion focuses on applying the Bisection method to determine the number of iterations required to achieve a specific accuracy of 10^-5 for the equation f(x) = x³ + 4x² - 10 = 0. The user initially misinterprets the inequality rules related to the theorem, leading to confusion about the correct bounds for n. Ultimately, the correct interpretation is established: the inequality should be set as 10^-5 ≥ (b-a)/2^n, confirming that n must be at least 17 iterations to meet the desired accuracy.
  • Understanding of the Bisection method in numerical analysis
  • Familiarity with the concept of convergence and error bounds
  • Basic knowledge of logarithmic functions and their properties
  • Experience with MATLAB for numerical computations
  • Study the Bisection method in detail, focusing on error analysis and convergence rates
  • Learn how to implement the Bisection method in MATLAB for various functions
  • Explore other numerical methods for root-finding, such as Newton's method and Secant method
  • Investigate the implications of different tolerances on the number of iterations required
This discussion is beneficial for students in numerical analysis, educators teaching root-finding algorithms, and anyone looking to deepen their understanding of the Bisection method and its applications in computational mathematics.
reed2100
This is a homework problem for a numerical analysis class.
Use the following theorem to find bounds for the number of iterations needed to achieve an approximation with accuracy 10^-5 to the solution of the equation given in part (a) lying in the intervals [-3,-2] and [-1,0], respectively.
Here is another solved example:
Determine the number of iterations necessary to solve f (x) = x3 + 4x2 − 10 = 0 with
accuracy 10^−3 using a1 = 1 and b1 = 2.
| Pn − p| ≤ 2^−n(b − a) = 2^−n < 10^−3.
Theorem 2.1
Suppose that f ∈ C[a, b] and f (a) ·f (b) < 0. The Bisection method generates a sequence
{ pn}∞
n=1 approximating a zero p of f with
| pn − p| ≤ b − a
2n , when n ≥ 1.
I'm going crazy trying to remember and make sense of the inequality rules. Here's what I tried first.
|10^-5| ≤ (1) / 2^n
1 / (10^5) ≤ 1 / (2^n)
2^n ≤ 10^5
n * ln(2) ≤ 5*ln(10)
n ≤ 5*ln(10) / ln(2)
n ≤ 16.6
Obviously this is incorrect, even just intuitively. As the number of iterations increases the accuracy should increase toward infinity, so you would think that it should say n ≥ 16.6, or that n is really just 17 at a minimum in order to meet the desired 10^-5 accuracy. In fact, I KNOW the answer is 17 iterations from using provided code in matlab. I'm just struggling to remember how to interpret and deal with this inequality to arrive at the correct expression.
Can anyone please show me the proper way to arrive at the proper inequality, step by step? The only guess I have at the moment is that I'm incorrectly interpreting |[p][/n] - p| or something. [p][/n] can be above or below p, so the non-absolute value could be negative or positive. So if you don't know what n is going to be, do you reverse the inequality and set that absolute value equal to the desired accuracy? Because you don't care whether the difference is one way or the other, so long as it's within the desired range? Any help understanding how to do this is greatly appreciated, thank you.
Clearly, your starting point should be ##10^{-5} \ge 2^{-n}##. The value of ##n## should make the error LESS than ##10^{-5}##. The inequalities are backwards from the beginning.
Thank you. With this and some more looking around I think I better understand how to read / work with the theorem now. I was misunderstanding the theorem and wasn't thinking it through properly. The value of |Pn - P| is supposed to be less than the specified tolerance, so since it's <= (b-a)/2^n, it follows that (b-a)/2^n <= tolerance, not tolerance <= (b-a)/2^n. Thank you for the sanity check, I really stumped myself for a bit.
  • · Replies 21 ·
  • · Replies 34 ·
9K
