Math vs. FE Method: Comparing Mechanical Engineering Focus
  • Thread starter Thread starter Trying2Learn
    Method
The discussion centers on the differences between Finite Element Method (FEM) courses offered by math departments and those provided by mechanical engineering programs. It asserts that while math courses focus on theoretical aspects such as differential equations and algorithms, mechanical engineering courses emphasize practical applications of the FEM, including connectivity, Jacobians, and Gauss Quadrature integration. Participants express concern that math departments do not adequately prepare students for the practical application of FEM in engineering contexts. The conclusion is that a balanced approach combining theory and practical application is essential for effective learning in FEM.
  • Understanding of Finite Element Analysis (FEA)
  • Familiarity with differential equations
  • Knowledge of Jacobians and Gauss Quadrature integration
  • Basic principles of mechanical engineering
  • Research the application of the Galerkin method in FEM
  • Explore hand calculations for simple structures in FEA
  • Learn about the stiffness matrix and its derivation
  • Investigate effective FEA software tools for practical applications
Mechanical engineers, FEM practitioners, and students seeking to bridge the gap between theoretical knowledge and practical application in Finite Element Analysis.
Trying2Learn
TL;DR
How would you describe the FE method
I have written FE codes.
I have seen FE classes from mechanical engineering
I have seen FE classes from the math departments
When offered from a math department, the focus is the theory (with a lot of attention paid to general differential equations)
They are good courses and they suggest, I think AN ALGORITHM
However in the Finite Element Method, to ME the operative word is METHOD
And I am hoping someone can say what I am about to say, more precisely:
The FE METHOD was developed by engineers (civil: trusses, frames, etc.; and mechanical: solids, plane stress, etc.) As such, it is a METHOD of applying the ALGORITHM in pre-set ways for mechanical engineering: to read in connectivity, set up Jacobians, set up Gauss Q. integration, set up the B matrix, B-transpose * B * B, etc. I don't think the math departments teach this properly for mechanical engineers. I have seen students take FE classes from math departments and come out without any idea that there really is an established approach to a METHOD.
Can someone help me say this better? (Or, maybe I am wrong?) I am not sure I have the right to abuse the word METHOD and ALGORITHM as I do.
Is it fair to say that the math course still leaves you with some decisions to make based on your specific application, whereas the ME course is already specialized to a particular application?
It would also not surprise me if the math course goes into more detail about how and why the method works.
Likes Trying2Learn
Well, when I was studying at the mechanical faculty, the FEM course was strictly about the math behind this method - vector spaces, weak forms, Galerkin method and basis/shape functions. Not a single word about applications of this mathematical method in mechanics. Now they teach the opposite - pure practice (how to use a particular FEA software). Neither of these approaches is good and the first one is literally terrible for mechanical engineers. It should be theory (not math but its application in mechanical problems) plus some practice. Like many other FEA engineers, I had to spend a lot of time on self-learning. Fortunately, apart from usually very academically focused books about FEA, there are also several blogs with a good introduction to FEM theory and after understanding the basics one may proceed to more advanced content included in classic books (I wouldn't recommend the trilogy by Zienkiewicz though).
I think that in order to understand how FEA software actually works, it's best to take a closer look at examples involving hand calculations of simple structures. Starting from springs, proceeding to bars/beams and finally flat plates. The latter are particularly important, among others, because they show how the stiffness matrix is obtained when the direct approach cannot be used and thus how it's actually implemented in FEA codes.
Likes Trying2Learn, cherish and berkeman
I have encountered a vertically oriented hydraulic cylinder that is designed to actuate and slice heavy cabling into sections with a blade. The cylinder is quite small (around 1.5 inches in diameter) and has an equally small stroke. The cylinder is single acting (i.e. it is pressurized from the bottom, and vented to atmosphere with a spring return, roughly 200lbs of force on the spring). The system operates at roughly 2500 psi. Interestingly, the cylinder has a pin that passes through its...
